This car was running 230bhp @ 1 Bar of boost
Spec/Modifications;
Wepper ram horn external manifold with a TD04 and a black tial waste gate
6 Puck paddle clutch put in only 800 miles ago
New battery
A triple coiled monster radiator from Tuning Developments with blue Samco hoses
Monical blue HT leads with new disy cap and rota arm
NGK spark plugs
D1 spec battery holder
Upgraded front mount with Greddy adjustable dump valve, hard and soft settings
Go fast bits boost controller at 1 bar of boost making it 230hp with a Greddy emanage blue and was mapped by Tuning Developments
D2 coilovers
D1 spec wheel nuts
Monoblock Light Racespec Proiect D
Grooved front discs and yellow stuffed pads
Custom exhaust and flamer kit
Standard front strutbrace
HKS turbo timer
Tom's gear knob
Two fly speakers in the front and rear
Walbro fuel pump
HID's fitted
Toad alarm
Was running nicely, until this morning when the hose from the top of the rocker to the oil catch can split and then oil went all over the show and was coming out through the breather too.
Cylinder number 2 was only showing 50 Psi so will wait and see what it is. I'm sure it wont be cheap though :<
I did do a Cylinder leakage test and it was all good.
Just luck of the draw I guess, I'd like to think anyway... I don't thrash the nuts out my cars, had plenty of stis, mr2 tubbys etc. and always been fortunate that nothing catastrophic has ever happened.
I think I'll buy a compression tester kit though for future cars.
My mechanic is always busy for weeks. Is there anywhere in the South East I could go and get it dropped off and picked up from, that people could recommend if it does turn out to be the piston which seems like it will be?
Just a thought at the moment to get it repaired quickly if I can source the parts needed.
Edited by timmy2take
It requires a complete engine strip down to change the piston...
If it hasn't damaged the bore....
Best bet is to get a replacement engine, go from there...
x2 for this
unless you want to go forged/more power
Phil
No not me. I'm Timmy
I did read plenty of people rrunning 1 bar of boost around 230bhp on standard internals so I thought this would of been ok.
Still not sure which way I'm going to go with it. Can't see any engines for sale at the moment.
(No offence but it's hard work looking through all the for sale ads, why not just have a traders area and a private sales area?)
Some thing has gone a miss I've been running 233.4 for about 2.5 - 3 years now and it's been spot on. Just shit luck I'd say :(
I too ran 242bhp without issues on stock internals. Breaking pistons is a known weak spot in the 4efte although I still put it down to fueling... I'd consider stripping it and replacing the piston if the bore is okay. However the easiest option is to buy another engine.
your not the lad on fb who said he was going to buy a car that's running 230bhp on standard internals and was asking for engine advice, of which most said run it on low boost. name was William?
That's me haha! I bought mine on Saturday, had a few problems with my boost controller but turned it off and it's been running sweet :) seems to be going pretty well! Mental little car!!
Exactly what i'd do to as well from experience
Put wanted thread up pal , there was a few on starlet parts on facebook
