Rick's 1996 5E-FHTE Glanza V
Its been a long time in the making...
Pictures
The day i bought it....
And how she is now...
Engine
5E Decked Block
5E Balanced Crank
4E Ported & Mirror Polished Head
Clevite77 uprated Bearings
Pauter Forged Rods
Ross Forged Pistons
Ross Racing Rings
Cruise Power Headgasket
Cruise Power Valve Springs
JAM Racing Cams
JAM Racing Underbucket Shim Kit
SARD 550cc Injectors
Ported & Polished 5E-FHE ACIS Dual Runner Intake Manifold
4A-GE Ported Throttle body
SARD Fuel Regulator
SARD MAG+ Sump Plug
SARD MAG+ Oil Filter
Greddy TD-06 Turbo
Cruise Power Manifold
Cruise Power Downpipe
Cruise Power Screamer Pipe
Fujitsubo Power Getter Exhaust
HKS S/S Racing External Wastegate
Custom FMIC
Cruise Power FMIC Hard Piping
Walbro 255lph Fuel Pump
Clevite 77 Uprated Oil Pump
Greddy Airinx Filter
ULTRA 7mm Plug Leads
Silk Road Engine Torque Damper
Custom Polyurethane Engine Mounts
Custom Made Alloy Catch Tank
Venhill Braided Throttle Cable
Aeroquip -AN Fittings and Braided Lines
NGK Iridium IX Grade 8 Plugs
Royal Purple 10w30
All Hotpipes Thermal Wrapped
All IC pipes Reflective Wrapped
Drivetrain
OS Giken Flywheel
OS Giken T2SB Twin Plate Clutch
OS Giken Release Bearing
Earl's Braided Clutch Line
Quaife ATB LSD
TC Short Shifter
TC Cable Bushings
TC Shifter Mounts
Royal Purple MaxGear
Electronics:
Cruise Power Wiring Loom
HKS FconV Pro Gold ECU
HKS 3 Bar MAP Sensor
Modified 5v Throttle Sensor
Greddy Profec B II
Greddy Turbo Timer
Defi Link Gauges with CUII (Boost, EGT, RPM)
HKS 46 gauges (Oil Temp/Pressure)
NGK Wideband AFR
Battery relocation in boot.
Exterior:
Complete 98 Spec Factory Bodykit with Carbon Fibre Front Lip
TOM'S Sideskirts
Varis Carbon Fibre Cooling Bonnet
Carbon Fibre JAM Racing Eyebrown
98 Spec Rear Lights (Black)
Clear Side Repeaters (Black)
OMP Bonnet Pins
Carbon Fuel Door
Interior:
Cruise Power Shift Knob
Recaro Seats
NRG Billet Snap off Hub
OMP WRC Dished Steering Wheel
Carbon Fibre Glovebox
Carbon Fibre Centre Console
Carbon Fibre Binacle Surround
Factory optional arm rest
Chassis:
Kayaba SR Shocks
RS*R Springs
Cusco Panhard Rod
Whiteline Adjustable Rear Anti Roll bar
Polyurethane Front Rollbar mounts
TRD Front Upper Strut Tower
Whiteline Antilift Kit w/ Castor Bushes.
Tanabe 4 point Under Brace
ZEP Racing Floor Bar
ZEP 3-Point Rear Upper Strut
Brakes:
Levin SuperStrut Floating Twinpot Conversion
3G Discs
Endless Pads
Braided Lines
Cusco BMCS
Rolling Stock:
15" Black Work RS-Z
Toyo T1-R
Pair of 15" rims with R888s for track
  • Replies 617
  • Created
  • Last Reply
Top Posters In This Topic
i was just thinking about this car today as a matter of fact , i was speaking to harrison a while ago nad he said you were building a td 06 powered monster and wondered why i heard nothing on tgtt.com , your name was vt rick on there wasnt it ?
you havnt heard of it on tgtt because i dont post on there at all.
i dont subscribe to how they've decided to run the show over there now.
im pretty confident that she'll be in the top 5 most powerful starlets in the UK.
man reading this has brought a smile to my tired face!!!! really excited to see some updated pics and to see this project finally coming together!!!!!!!! i hope it all goes perfectly for u man when u finally get to take her for a spin!!!!!!!
all the best with the final steps Rick mate!
Phil.
Was close :)
What EP's in the country are over 350hp atw??
The only engine I know is Dave Warbrushes old 330bhp motor didnt know there was EP's with more than that in the UK :unsure:
Amazing spec list mate, is gonna be fucking awesome when you get it all finished and mapped.
When do you reckon full boost will be with the TD06??
ok mate , fair play , really inspired me and got me interested this build has . excellent work , look forward to the pics
hang on, who edited my post?
i never put that....
i said tgtt is full of cunts, or something similar.
also, update on the car.
ihateenginemounts.com
