Whitenoize Posted February 11, 2015 Posted February 11, 2015 Could anyone that's done an auto to manual conversion tell me the full list of parts that I will need to do the job please Thanks Ryan Quote
mattyD Posted February 11, 2015 Posted February 11, 2015 Manual box, pedals, ecu, shifter cables, shifter......not sure what else lol Quote
Whitenoize Posted February 11, 2015 Author Posted February 11, 2015 Any idea is the fly wheel the same on an auto and will I need to swap the master cylinder? Quote
mattyD Posted February 11, 2015 Posted February 11, 2015 Oh yeah sorry bud, and them....also manual fly bolts as I think the auto ones are to long Quote
Whitenoize Posted February 11, 2015 Author Posted February 11, 2015 Awesome think I've got everything covered just wanted to make sure I want missing anything is it easy anuf to swap the auto clocks for manual one or is it a pain ? Quote
TrisK Posted February 11, 2015 Posted February 11, 2015 clocks are easy enough to change. just your will mash your wrists when you try and put the speedo cable back in Quote
Whitenoize Posted February 11, 2015 Author Posted February 11, 2015 clocks are easy enough to change. just your will mash your wrists when you try and put the speedo cable back in is it just a straight swap with the clocks mate? Quote
TrisK Posted February 11, 2015 Posted February 11, 2015 Engine stays in use the auto shafts you need box, flywheel, clutch, linkages, slave and master cylinders, pedal, shifter. All plastics stay the same. Bridge the two big female terminals in the center of the big plug that was plugged into the auto box and you need to jam the slider on the under side of the ign barrel up or the key won't turn I just center punched mine till it jammed up.http://www.ukstarletowners.com/topic/57966-any-guide-to-swap-auto-to-manual/ http://www.tercelreference.com/articles/auto_manual_conversion/auto_manual_conversion.html Theres some links for reading Quote
Whitenoize Posted February 11, 2015 Author Posted February 11, 2015 That's great thanks for that Quote
mattyD Posted February 11, 2015 Posted February 11, 2015 Pretty sure your going to need a manual ecu, hows a manual car gna work with an auto ecu? Quote
TrisK Posted February 11, 2015 Posted February 11, 2015 Pretty sure your going to need a manual ecu, hows a manual car gna work with an auto ecu?The car doesnt have sensors for what gear your are in. It has no idea what gear you are in. It doesnt care what gear you in. Maps are all done on MAP vs RPM. Gear is irrelevant You just have to bridge the connections so it thinks you are in Park or the car wont start. Quote
daniel_g Posted February 11, 2015 Posted February 11, 2015 Just remember daft things like clutch cover bolts and the springs to hold in gear cables etc.You can use all that from your GT, cables are the same. Shifter will bolt down no problem. Quote
TrisK Posted February 11, 2015 Posted February 11, 2015 Also the actual flywheel bolts are different, so get the bolts with the flywheel Quote
mattyD Posted February 11, 2015 Posted February 11, 2015 Sound, had a manual ecu in mine that was converted but if there's no need then not to worry Quote
TrisK Posted February 11, 2015 Posted February 11, 2015 well the ecu plugs are different from auto to manual. So if yo uwant to change the ecu, then you need to change the whole engine loom. Then some of the sensors are different, so you could have to change the whole engine basically. Quote
JamesD89 Posted February 11, 2015 Posted February 11, 2015 (edited) Got the full list here from when I done mine if you need it Ryan.Down to the very last bolt Pm me and il fire it over. Edited February 11, 2015 by JamesD89 Quote
Whitenoize Posted February 11, 2015 Author Posted February 11, 2015 Got the full list here from when I done mine if you need it Ryan.Down to the very last bolt Pm me and il fire it over. think I've got everything tbh mate as I've just broke my gt but thanks for the offer dude Quote
mikey4410 Posted February 11, 2015 Posted February 11, 2015 I had a manual car that had an auto ecu in it and it ran like a bag of shite.afrs were all over the place at best.not good for the engine Quote
_shaun_ Posted February 11, 2015 Posted February 11, 2015 From memory there's a 2 pins on the auto ecu you have to spice to make it work but I've not done it so not sure which Quote
Andi-pandi Posted April 19, 2015 Posted April 19, 2015 I've just done mine last week. you also need the radiator bottom hose and thermostat outlet otherwise the pipes rub on the clutch place and lever. to get it started you need to bridge the big pins in the plug at the gearboc end. there is a diagram on this MR2 site... http://www.mr2.com/forums/threads/4643-auto-gt-manual-swap/page2 Quote
