  • Replies 191
Posted Images
What ecu? weak actuator, boost leak. 1 bar as above is magic number. Those HKS actuators are a good option they are alot stronger. They hold better. Don't forget I run external wastegate on a ebc as I say you should be whizzing over the 200 mark
It's the Blitz Access K1-200V ECU, boost was over 1 bar so there is a problem there somewhere.
The way the torque drops away so suddenly doesn't seem normal and makes me think something boost related.
Boost curve would help, don't think it's ignition being retarded because the power doesn't really plunge north too quick. If your boost stays stable maybe something is letting boost leak past
If that's a hub dyno the power is quite realistic. Here's mine on hub dyno with Tongs GT spec ct9, 0.95bar
The result was 107kw(145whp)@5960, torque 198nm@4510.
What ecu Jay?
It is a hub dyno, but having it back to back with the standard turbo, makes me think something is not right.
I'm pretty sure the blow off valve connection to the intake pipe is leaking so I will start with that.
I don't have the boost curve unfortunately!
  • 7 months later...
  • 8 months later...
  • 1 month later...
  • 1 year later...
  • 5 months later...
  • 10 months later...
