Pikey009 Posted October 24, 2015 Author Posted October 24, 2015 Nice one cheers buddy. I'll be getting an emanage blue in the future so that should maximise the gains as I've heard these uk spec engines are easy to get near 100bhp. Plus then when I bolt a turbo to it I'll already have the Ecu sorted. Are there any alternatives to the emanage blue price and performance wise? Quote
morgey Posted October 24, 2015 Posted October 24, 2015 Not sure if theyvwork with these but the corolla boys use det3 piggy backs but they run a afm not a map sensor but cant see why it wouldnt or couldnt be made to work.Yeah with an ecu it shouldnt be far off. With rolla intake and good exhaust it should hit over 90hp as that what the 4efe corollas have stock and theyre almost the same engine But on a factory ecu so a remap should see over that. Quote
Pikey009 Posted October 24, 2015 Author Posted October 24, 2015 I might be able to get hold of the import na ecu so would just run that for a start. Was it just the intake and Ecu that was different in the import cars? Seems like easy cheap gains for a start and I know 90hp wouldn't exactly set the world alight but it's better than 76 Quote
morgey Posted October 24, 2015 Posted October 24, 2015 Im not sure what the main differences are tbh. A piggy back is always the best option to get the most out of it but the early ecu is going to be better than the uk one Quote
daniel_g Posted October 24, 2015 Posted October 24, 2015 To run the early 100ps ECU you ideally need to matching pink injectors, the Gen1 FE also used the FTE style inlet and TB. Differnet exhaust mani, but use a 5EFHE exhaust mani or a good aftermarket one.Also the Gen1 had a FTE flywheel (get it lightened), 212mm clutch, rods are thicker (possibly GT rods in the Gen1) and also the crank is a turbo crank.Get that lot dropped in your SR and it will be awesome! Quote
Pikey009 Posted October 24, 2015 Author Posted October 24, 2015 Jesus ha ha that is an epic reply, thanks. Had no idea that there was such a difference! Think I'll just go for the emanage and Corolla mani for now then Quote
Pikey009 Posted October 24, 2015 Author Posted October 24, 2015 Really appreciate all the help by the way so thanks everyone. Pretty clued up with gt4's but not as much with the starlets! Quote
Pikey009 Posted October 24, 2015 Author Posted October 24, 2015 No mate the guy for some reason still hasn't taken the advert off eBay Quote
mart1 Posted October 25, 2015 Posted October 25, 2015 Thought you was selling it haha with having the same pics up. Quote
Pikey009 Posted October 25, 2015 Author Posted October 25, 2015 (edited) Ha no mate I plan to keep this for a long time or at least until bean sells me my old gt4 back ;) Love all jap but Toyota is where my heart lays Edited October 25, 2015 by Pikey009 Quote
Starlet flex Posted October 25, 2015 Posted October 25, 2015 Nice thread dude.Be good to see the new interior in. I'm after the same interior for mine but they just seem hard to find.Keep it up Quote
Pikey009 Posted October 25, 2015 Author Posted October 25, 2015 Thanks mate. Yeh does seem pretty hard to come by and I can't see the plastics being easy source but I'll probably spray them and re trim the fabrics to match. I've got a load of stuff on order from various places so just waiting for it all to turn up! By the end of next month it should have:Late spec front and rear seatsCrystal headlightsAll belts including oil, filter and water pumpCustom stainless back box with genuine tte tail pipe Wind deflectorsAnd maybe the plastics sorted along with a deep engine clean if I get time Quote
Pikey009 Posted October 25, 2015 Author Posted October 25, 2015 Dan I've got the chance to have a 4paw Ecu- do they def use the different injectors and turbo inlet? As my 4paw had a Corolla inlet on it. I don't want to damage anything Quote
daniel_g Posted October 25, 2015 Posted October 25, 2015 (edited) Dan I've got the chance to have a 4paw Ecu- do they def use the different injectors and turbo inlet? As my 4paw had a Corolla inlet on it. I don't want to damage anythingWhat year of 4paw?The stuff i mentioned was all on a Gen1 FE EP85The EP95s (well the late Gen3 ones) have corolla inlets, dark green injectors, knock sensor, 4 wire o2 sensor, DIS ignition etc.. basically set up for economy rather than power.Gen1 stuff is what you want!You got a pic of the ECU youre getting? I have the numbers here i'll match to mine Edited October 25, 2015 by daniel_g Quote
Pikey009 Posted October 25, 2015 Author Posted October 25, 2015 It's the later one- it's from my old 4paw and def had the Corolla mani. So it won't give me any extra power then? Here's a pic Quote
daniel_g Posted October 25, 2015 Posted October 25, 2015 I doubt it would do anything worth noting tbh. Did it have the DIS / coilpack ignition system? If so then that ECU wouldnt even run on your car with a dizzy setup.Gen1 100ps ECU from a Gi / 85 / Soleil is the one you want. Its got a higher rev limit than a UK ECU aswell.Or just get an EMB wired in job done Quote
daniel_g Posted October 25, 2015 Posted October 25, 2015 Saying that if its the 95 i think it is then it wasnt the very late spec (so still used a dizzy setup)Id you have it to hand fire it on, it will be better suited to the Corolla inlet if you plan to go down that route anyway. Quote
Pikey009 Posted October 26, 2015 Author Posted October 26, 2015 I've got a pic of the engine bay when I had the car and it's running a dizzy. So that 4paw was running 10bhp more than my sr and it just had the Corolla inlet and Ecu sounds like decent gains to me Quote
daniel_g Posted October 26, 2015 Posted October 26, 2015 (edited) I've got a pic of the engine bay when I had the car and it's running a dizzy. So that 4paw was running 10bhp more than my sr and it just had the Corolla inlet and Ecu sounds like decent gains to me Yeah i know the car, used to be Geos girlfriends 95. May aswell fit it then yeah, not sure if they were the only differences, (injectors too maybe) but if you reckon theres 10bhp in it then its worth a go Edited October 26, 2015 by daniel_g Quote
Pikey009 Posted October 26, 2015 Author Posted October 26, 2015 (edited) Yeh that's the one. Well the pic you showed says 85hp compared to 76 the uk cars put out. Im just not that sure about the Ecu maybe I would be better getting a piggy back and tweaking out a little more power along with the Corolla mani. I know they're only small gains but the cars so lite I imagine it'll make a difference. I've heard two separate tuners getting around 100 from them so not bad gains for the car really Edited October 26, 2015 by Pikey009 Quote
daniel_g Posted October 26, 2015 Posted October 26, 2015 Yeh that's the one. Well the pic you showed says 85hp compared to 76 the uk cars put out. Im just not that sure about the Ecu maybe I would be better getting a piggy back and tweaking out a little more power along with the Corolla mani. I know they're only small gains but the cars so lite I imagine it'll make a difference. I've heard two separate tuners getting around 100 from them so not bad gains for the car reallyIf the ECU is cheap / free if you already have it? Then yeah fire it on why not see if it does make a difference.Then you can always get an EMB down the line.Its defo possible to get 100 outta them without too much work Quote
Pikey009 Posted October 26, 2015 Author Posted October 26, 2015 Yeh I guess so, it might be worth a punt Quote
