1683 -
The most effective way of stopping it coming back is to use a spot sandblaster. It will remove very little of the metal but gets deep into it to remove the corrosion. Or you can use rust converter stuff that like an acid that kills the corrosion and stops it then paint over the area. Grinding takes too much of the steel away for me on panels that are very thin to start with. One thing to be sure of is you get the treatment well into the joint of the two panels as thats were it will have started. This is what I would use http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_179549_langId_-1_categoryId_165594
Project shrek 5E GT
Rob H@RCH Engineering replied to turbo Grant's topic in EP80/EP82 Progress Blogs
That kit looks megga!! I think it looks good left that colour too! -
Ive just got the wifi bacpac for my gopro so thought I best try it out connected to the Iphone. I dont know who the bloke in the Celica was but he made it entertaining but some of his overtakes were a bit well you will see!! http://www.youtube.com/embed/6ReRbP_9-EA
crank pulley setting. help needed guys
Rob H@RCH Engineering replied to PaulStarletSR's topic in Engines
needs to be at 4E if only running the cams or any one running cams with more lift would be affected too! I run the fhe cams in one of my old builds on the 4e marks. -
I would be up for this!! not been to towers for years
Looking good mate!! not long now and you will have BOOST!!!!! to say you dont have a garage you have done bloody well there mate!!
- 685 replies
Id say it was for the center bolt for the oil filter housing. I could be wrong but I think thats about the only thing that big.
Im working 6pm till 6am and have been since friday night!
New mud flaps and club stickers fitted!!
Rob H@RCH Engineering posted a topic in Photography Gallery
Some picks with the Carbon Goodies carbon mud mud flaps and new club stickers fitted. http://s87.photobucket.com/user/turbosr_2006/media/toylet/CarbonGoodies002_zps25a8ca94.jpg.html'> http://s87.photobucket.com/user/turbosr_2006/media/toylet/CarbonGoodies003_zpsfd3dba52.jpg.html'> http://s87.photobucket.com/user/turbosr_2006/media/toylet/CarbonGoodies005_zpsb54c2975.jpg.html'> http://s87.photobucket.com/user/turbosr_2006/media/toylet/CarbonGoodies006_zps4bd726e9.jpg.html'> You can just see the carbon weave around the edge! http://s87.photobucket.com/user/turbosr_2006/media/toylet/CarbonGoodies008_zps0768f8da.jpg.html'> -
Got FLAPS!!!! Thanks to Carbon Goodies (RICK) http://s87.photobucket.com/user/turbosr_2006/media/toylet/2c3e1d84-23cc-4746-9791-8d842efedf0d_zps3dcae401.jpg.html'> http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zps5e6c26e9.jpg.html'> http://s87.photobucket.com/user/turbosr_2006/media/toylet/004-1_zps148afb2b.jpg.html'> http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zpsb9c895eb.jpg.html'> This is genuine Carbon too!!! sandwiched in rubber or something similar so they are very flexible. http://s87.photobucket.com/user/turbosr_2006/media/toylet/007-1_zps8206c70f.jpg.html'> http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zpsea17f56c.jpg.html'> http://s87.photobucket.com/user/turbosr_2006/media/toylet/010-1_zpsf7513db9.jpg.html'> Ups thats my hellper Fitting is nice and easy for every one too!! The rear brackets use one of the original liner bolts and then the 4 self tappers that come with the kit. http://s87.photobucket.com/user/turbosr_2006/media/toylet/016_zps7d7633c4.jpg.html'> once you have them mounted hold to flap up to the bracket and mark them for the holes where you want them to go and then drill out the holes 6mm and bolt them up! I drilled one then used that as a guide to drill the second one so they end up exactly the same. http://s87.photobucket.com/user/turbosr_2006/media/toylet/017-1_zps1116f62a.jpg.html'> The fronts are all predrilled for ya so you just bolt the flaps to the bracket, take out the 2 arch liner bolts and bolt them on!! One thing I did have to do was cut the fronts down as they would have dragged on the floor at the length the come but this will depend on your ride height to what length you will need them. Out of the box http://s87.photobucket.com/user/turbosr_2006/media/toylet/015-1_zps8dcb014f.jpg.html'> Cut down. I only took 3/4 inc off them so there still pretty low so I may take some more off them yet. http://s87.photobucket.com/user/turbosr_2006/media/toylet/014-1_zps0294c4ea.jpg.html'> And the finished job!!! http://s87.photobucket.com/user/turbosr_2006/media/toylet/019-1_zps77018a0f.jpg.html'> http://s87.photobucket.com/user/turbosr_2006/media/toylet/022-1_zps2638fc81.jpg.html'> http://s87.photobucket.com/user/turbosr_2006/media/toylet/024-1_zps40b22d67.jpg.html'>
I will be there! going out the night before too so I will have to be a good boy and not drink too much!!
It perfectly normal for them to make a noise like that even the n/a engine does it I think its down to the noise from the cam and the air flow through the baffle plate in the cover.
I work 4 on 4 off, 6pm till 6am regular nights with the odd bit of over time. I get 21 days hol so in all I only work about 5 month out of 12 l!!
Cheers lads!! and yes it does spool very well for a TD05 16G im hitting full boost for 4000 or just over and as for traction its not too bad on a good dry day but it depends because some times I still get spin in 3rd and 4th depending on the road surface! John yes I have plenty of japfest convoy video just need to finish chopping it down theres about 3 hours of video to go at!! plus the wind noise was realy bugging me on it hence trying to reduce it ready for JF2!!!!
DGR coil overs anyone!!
Rob H@RCH Engineering replied to Rob H@RCH Engineering's topic in Lifestyle General
yep not with a pick of a pile of kits lol -
Cheers lads I'm running a Greddy TD05 16G with blitz nur spec and tial V band waste gate
just come across these!! only just posted so I guess he did get them. https://www.facebook.com/groups/468173396549649/
I did this one as I'm trying to cut down the wind noise this is what it came out like http://youtu.be/t63aGpthyKw
As Jay said is always best to use a fuse the closer to the battery the better this is where I put mine its the black box on the front of the battery box. http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zps78b8c6c3.jpg.html'>
Rocker cover baffle
Rob H@RCH Engineering replied to Glanza Mac's topic in 4E-FTE Engine Discussions
I ground off the lugs that hold it in place then drilled and tapped it 6mm to bolt it back in with a small bead of silicone now it can be taken out when ever needed. Don't forget to stud lock the bolts tho ya don't want them falling out! -
Rocker cover baffle
I have done this there is some photos in my build tread on how I did it. It takes time but its quite easy to do! -
Well got it all finished off today and moved the sub around in the boot http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zps78b8c6c3.jpg.html'> The wiring running under the car http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zps15711b8e.jpg.html'> http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zpsb5b5a312.jpg.html'> http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zpsf532397d.jpg.html'> And the finished bay, It looks so much better with out the massive battery in there! http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zpsa62d0cc7.jpg.html'>
