Rob H@RCH Engineering
    1683
  1. Thats a stock box unless it has a aftermarket lsd in it. only way to tell that is to pop a shaft out and have a look inside the casing.
  2. This is one my mate has just tuned for some one! https://www.facebook.com/photo.php?v=4411334084074
  3. I will be at J27 @ 2:15 ouch!! lol see ya there!
  4. This is what I'm saying I have seen Garrett inconel wheels that have melted due to tuning if they can be melted am sure pistons can!
  5. I'm not pointing no fingers there just seems to be a bit of a pattern! Fueling and knock levels can be spot on but bottom end failure and melted pistons would seam to point more to timing issues to me, I have been there my self a few times and seen the various results poor timing can cause. I got through 3 bottom ends back in 2003-2005 due to poor map timing.
  6. Gutted mate! dont brake it! it would be a crying same to brake it! But that 3 now in 2 months one on TGTT and 2 on here all mapped by TD some thing is going on!
  7. Lol I have both anyway so that don't matter!
  8. I have a few spair front hubs Rob if ya want to stick a bearing in on of them my dad has a 80ton press! And as we were saying the other day I have a caliper. May have other stuff too ya need if ya want to pop over one day. Keep it up and it will be done for Japfest!
  9. They fit my 1999 SR and the 100% fit that no problems I think different year cars must use different carriers because mine and my mates SRs both had Glanza discs fitted with no problems.
  10. Glanza discs will go straight on mate I was running glanza discs on my n/a for over 10 years lol you dont need to change anything just make sure you get the correct center bore.
  11. I got all them parts where ya from?
  12. Won't the head warp before the block lol that explains it all lol
  13. That is condensation that is quite normal if the oil in the engine is clean you are worrying about nothing! If it was the head gasket all the oil would be the same not just in the cap. I've just changed my catch tank and that was half full of water! It don't mean the head gaskets failed tho. This time of year is all ways worst for it.
  14. Most roller dynos measure axle torque and calculate horse power (remember they carnt directly mesure engine power before drive train losses hence whp being most accurate as this is what is directly measured!) were as dyno jet for example measures horse power and calculates torque. Most roller dynos know the mass of the roller, circumference of the roller and the moment of inertia they look at the rate the drum is accelerated and knowing this work out the applied force to the roller (axle torque) then this is devided by over all drive ratio which gives engine torque after drive train losses, horse power is then worked out from this (hp=torque x rpm / 5252) this is also why hp an torque lines will ALWAYS cross at 5252rpm on force scaled graphs Unless funny business has been going on like misleading operator fudging the numbers to make their work look better. Dynapack is just a hydraulic pump head with a digital transducer (pressure sensor) that directly measure axle torque. This is arguably the most accurate method as its not calculating the torque it's measureing it. Some roller dynos with low inertia have trouble using the normal roller method so they control the ramp rate and use a strain gauge on the bottom of the assemble to measure tortuously forces on the eddy brake assembly. There are also some dynos out there that struggle to give consistent readings, which is why they're so cheap. Not mentioning any makes ;) Hope this has been an interesting insight into the theory of operation of various dynos excluding standardisation algorithms for weather etc. Info courtesy of Will @ RDT ..... Who's tuned on and studied the operation of almost every dyno manufacturer out there and even developed additional control systems for dynos like wireless remotes for dyno jet America.
  15. You need to have one like the one you made for mr Veall's drag civic for every one to see!lol
  16. I'm going because I was bullyed into it!
  17. the GT axle bolts straight onto the starlet you just need the cables
  18. Cheers lads! Got the tracking sorted out today with my Dads megga supertracker its a top bit of kit! A look from the bottom first Then the tracking This is as I was adjusting it Then the before and after screen
  19. Got some more bits done on sunday it was a bloody long day too! only got finished at 6am! I started off with a nice pile of shiny! with my watch dog keeping watch! Got it all stripped off then took the hub/shock off in one lump Gave the arch a clean and some black waxoil to freshen it up a bit then fitted the arms with super pro bushes and the TRD ARB. I cleaned the TTE springs up and gave them a quick coat of paint to freshen them up! and fitted them in one lump, I got some nice low mileage hubs from Si so they got a coat of paint too they dint need it but got done just the same lol, they also came with as new bottom ball joints too! cleaned up the Wilwood's and got it all back together, sorry for the poor pick but it was close to 6am lol Just needs the tracking doing now! I also fitted my new catch tank from Dean at RW developments.
  20. 2nd This, I used to run Tein coils on the rear and stock up front and that was spot on, its no different to driving around with a boot full of bricks or a empty boot it will just change the characteristics of the drive a bit.
  21. It will be better still now Ive been told im going!!
