2479 -
What MPG are you getting out of your starlet
turbo Grant replied to Nicholai's topic in Lifestyle General
I used to get around 200 miles out my old GT with about 180bhp boosting all the time if get less than that -
I'm pretty happy that running 2 different pumps will work. As the lift pumps not under any pressure as such so should flow enough. If I get a dirty lean miss fire and bits of piston on my spark plugs then the lift pumps not man enough Not sure about the pump inlet off the top of my head
Go for it! Some one need to try them out. Shorty needs a diffs for the goat
I've put a stock pump in the tank as a lift pump. Or you could use a facet solid state pump to feed the swirl pot. Or you could have a sumpted tank and no need for a swirl pot or lift pump as gravity will feed a inline high pressure pump
I found out about them from my mate who has an mgb. Thing a lot of them run them giving good results. It just needs to be fitted perfectly from what I understand
The normal walbro that people use and the aeromotive 340 are in tank pumps. If your going external pump your going to need a inline pump feed by a swirl pot or gravity. Or have a custom swirl pot made that house an intank pump. Picture in my build thread of how I've done mine
Think it's aeromotive do a 340 which is supposed to be quite good
This was looked at for the 4wd. They are cheap but. Unless they are fitted absolutely perfectly they will distroy the gear box. This put off the 4wd owned as you don't want to be buying a new one of them. Should give it a go. Get some feed back for us
People can always come see me
I sware you have had more bad luck with your car than the guy I work with
My paseo has been smoking for months now. I'm like one of the red arrows driving up the road in the morning. Done 15 litres of oil sinse it started smoking haha
Japfest2 should be where it's at. Open pit lane and all that. Will be crazy haha What happend to your car now?
I've got a pair of seats to go in. Not sure if I will be on track at Japfest. Havnt got any track time. Might be able to get some on the day and I'm happy with the car as it will be its first long drive outing I suspect
Nothing worse than a leaking tank. Petrols more expensive than a virgins blood now. Least you should have it back up and running for the good weather. Be good to have a good look at your car. Only had a guick look at jae from what I can remember haha
I couldn't decide what colour and see some nuts simaler on a mex the other day
Least he got the starlet bit right and didn't come up with a corsa or micra box haha Any way hope you get some thing sorted
Got some new things to hold the wheels on today
Coming along nice. Will be good once you get it back from td
I thought it was more for when you turn the car off. As the water slows down the cooling time to stop the oil in the turbo carbonising whitch means prolonging the turbo life. Should not be used as a substitute to leaving the engine running for a bit before shut down tho
The buckets I got off eBay but they were made by coltec. Not really much advantage as the ones you got are lighter. Mine use under bucket shims so any cam can be shimed up easy. Would be funny if your mrs old v was white and you went to some rugby thing and parked in a field
It's looking that way. Can't miss the first show of the year
What's wrong with micra's they work all the time
I'd start with a compression test see how that goes
Yep going to be an interesting drive to work for the MOT will be its first drive and ill have to map as I go haha
Glanza rear end look loads better I think
