turbo Grant
    2479
  1. You want to wire it up so the air is sucked throw the rad and blown out the back of the fan
  2. Only one wire to the oil pressure switch. That shouldn't be wrong. Could be the strainer in the sump blocked a bit. The oil change could have dislodged some shit
  3. Cheap, but no fun with an auto box!
  4. I think it need eye lids for the toms grill?
  5. You need to sort some better pics out man!
  6. The cj mamifold by the looks
  7. It's stamped 5E with the engine number on top of the block. If you looking at the engine with the bonnet open its on the right hand side
  8. Could be the thermostat stuck open. Doesn't take ages to warm up?
  9. Did the tb fit on ok without any air leaks because of the difference in parts. I had a simaler problem when I fitted the GT inlet and tb to my paseo. The GT tb was too big for the original pipe so I cut up a stock GT air pipe that comes off the air box. Your going to have to get a silicon joiner and cut the inculcation pipe in half and put the joiner in or you could space your air box over
  10. Does sound like a cracked head. As when it gets warm the crack will open up. Have you tryed re torquing your head bolts now you have do some miles
  11. If it revving up and downi wouldn't say it's a vac leak whats the management on it?
  12. Can take done more later. It's just made of alloy with folded edges. Going to make a new one or weld it up at some point make it a bit more sturdy
  13. I use the hot jet was down the self car wash place. Done it on loads of cars at work and a few of mine. I just put plastic bags over every thing. Jet wash it all off remove bags. Good idea to spray every thing in wd40 after. Had a miss fire after I done my Renault 5 bay, took the dizzy off wiped it out and it was fine
  14. A glanza system will fit on an sr will have a different flange at the front tho.
  15. You looking at an obx? You will need to mod that a little to fit on a 4e. then you could mate it up with a glanza exhaust system with a bit of work.
  16. Looks smart. Does the limited have the button inside to adjust the suspension?
  17. Will the inlet accept a 90mm throttle body? When you have monster cams you loose vaccum and a stable idle
  18. I see how it is then, normal haha
  19. I'm confused who's pictures are going where?
  20. Totally missed this one. Welcome to the forum Its ok. Have a twin starlet till it gets sprayed
  21. Some good pics. The green GT looks the same colour as mine Some good pics. The green GT looks the same colour as mine
  22. Nice result. What cam timing marks you using?
  23. I suspect he has a big smile on his face
