turbo Grant
    2479
  1. Should look nice with those wires removed. Makes it so much cleaner with standalone and custom loom
  2. The pads should fit as the discs are made smaller to make up for the calliper sitting 15mm closer to the centre point
  3. Picked up my temp sensor from my grandad last night. Screw cut a weld in alloy boss on the lath for me. Also been playing with the fuel pump. Started making a mounting plate for it
  4. Do they fit up with the hubs ok? Should just need some spacers and discs to suit then
  5. People just tend to cut the pipes off and just loop it with a bit of tube
  6. Only has 3 wires connected so you would have to pop another terminal in if using 4 wires
  7. Will pop one up very soon
  8. The paseo runs a 4 wire tps might be the same plug
  9. I've got a couple of custom shim kits for regrinds. Might get another set of cams
  10. Had it since November with no problems. Done a fair bit of welding with it. Chucked it in the car and drive to shorty's with it at the weekend can't complain about it really. Was a good price and does what I want it to
  11. Going to look good once you got all your bits on
  12. Your a lucky guy getting this gt, the green is a loverly colour
  13. This is the turbo that the auz guys run. They seem to think the td04 is laggy
  14. Really getting on this now. I need a starlet back. Keep thinking of buying one for a daily but I shouldn't
  15. Another part awaiting its new home on the old goat
  16. Got my fittings and bracket on the fuel pump. Will be finding its new home in the car during the week. Also got a cusco lower brace off Simon
  17. You must have nearly all the toms bits you can get. Looking smart. Need the wings painted tho
  18. This is no lady haha
  19. I found filter relocator made it pull hard all the way to redline.
  20. Should have lots of room for some short pipes. Rotation bracket I've done before on my old GT
  21. Yeah it's doable. Pipe works easy what rad you got?
