H_D
    1867
Everything posted by H_D
  1. Didn't realise you was from Leicester mate. I'm also from leicester
  2. DHL will contact you to make the import duty payment once they have your item
  3. Remember to add an extra 20% to the total.
  4. This one is the one that rattles http://www.rhdjapan.com/orc-309d-single-plate-metal-clutch-kit-ep82-ep91.html This is the silent type http://www.rhdjapan.com/orc-309d-silent-single-plate-metal-clutch-kit-ep82-ep91.html
  5. 5E and 4E crank pulleys are different - iirc the 5e crank pulley has spokes on it and is not solid like the 4efte ones
  6. yes it will be more than plenty. its one of those things you just fit and forget about they are really strong and can handle some proper abuse
  7. fyi clutches are rated by how much torque they can handle not HP
  8. use an alignment/tracking company who use hunter equipment - they have the proper geomentry settings for imports
  9. I have run stock clutches on applications between 150hp-200hp with a dodgy gearbox (shaft play, crunching between 2nd,3rd & 4th gear and popping out of 5th gear) and never once have destroyed a clutch. Spec clutches are weak regardless of what people think I have seen them fail many times on many different cars.
  10. Any competent engine builder will always get the crank balanced before fitting, they will also weigh your rods and pitons to ensure they are all of an equal weight. If the engine was build by TD im sure it would have been done properly
  11. between £600-£1000 depending on which one you go for
  12. just bite the bullet and order an ORC 309D from RHD japan or an os geiken multiplate if you can stretch your budget. I would also stay away from competition clutches
  13. spec clutches are utter shite, not just for starlets but also for audis and evos. stay well away from them. just check some reviews on google and see for yourself
  14. spec clutches are utter shite, not just for starlets but also for audis and evos. stay well away from them. just check some reviews on google and see for yourself
  15. may also be worth making adapter plates so people can run different turbos without having to change manifolds
  16. maybe try removing the boost controller and run off spring pressure, see if that helps at all?
  17. *Glanza*
  18. if the bulb is bridging on itself it will make your fuse blow. change bulbs again and report back they are only 99p each
  19. Thanks Gorgan. I assumed this would be the case but just wanted to know what I was getting myself into before I agreed to do it
  20. no problem at all, please let me know when you can. Cheers
  21. as above, if anyone has any complete rear calipers that have ceased please let me know. cash waiting. Thanks.
  22. I need to change the steering rack on a mates EP91 V, has anyone done this before? any help or guides will be much appreciated as always. Thanks.
  23. it will always be hot as its close to the engine
  24. Cheers mate - I normally use RHD but nengun seem a bit cheaper
  25. anyone used nengun? are they reliable?
