H_D
    1866
Everything posted by H_D
  1. I have used Athena H/G on both of my forged engines - not had any issues at all. the 1st engine is still going strong after almost 5 years.
  2. As above, Is there any way to visually confirm this?
  3. make sure the timing marks on the pulley and bottom cambelt cover are clearly marked. I use tip-ex
  4. H_D
    td04 turbo
    as above- must be in working order. Thanks.
  5. H_D
    td04 turbo
  6. H_D
    4e-fte camshafts
    Thanks for the replys and p.m's everyone. I have managed to source some locally
  7. H_D
    4e-fte camshafts
    As above. Needed asap please. Thanks
  8. H_D
    ARP head bolts
    You need to check them with a stretch gauge to see if they are still within tolerance to be re-used
  9. stick to the decat
  10. You need clutch fluid not oil - best to use genuine Toyota fluid
  11. H_D
    Crank Pulley Part No
    that image looks like a 5e crank pully not a 4efte one
  12. G3 compound paste and a D.A polisher takes 2 mins. or just G3 compound paste on a rag takes the best part of 15 mins
  13. its quiet easy but may leave a sticky residue on the window. if this happens just wipe the glass with paint thinners and it will remove the residue
  14. remove the glass and use a heat gun
  15. pm sent
  16. Thanks for the speedy reply Stu
  17. Looking at getting this triple core civic rad http://www.ebay.co.uk/itm/All-Aluminum-Radiator-56MM-3-Row-CORE-FITS-Honda-Civic-EG-EK-92-00-High-per-/271905213192?hash=item3f4ed04b08:g:UbAAAOSwnDZUBn5f Just wanted to know if they need any modifications to fit? Will my stock fan work with it? I am aware I will need a mounting kit. Seen some listed on trader websites priced 3-4 times higher so just looking at cheaper options. thanks
  18. Got an engine mount bracket off him, he even sent the bolts with it. well packed and fast delivery
  19. Anyone know where I can get a NEW set of timing belt pulleys? Thanks in advance.
  20. H_D
    Knock sensor for 4efte
    Just to let you know gt and glanza knock sensors have different loom plugs
  21. Thanks for the replies everyone. I have managed to source one. Thanks for the replies everyone. I have managed to source one.
  22. os geiken multiplate clutch is much better than the blitz - its can handle twice the abuse and power
