H_D
    1867
Everything posted by H_D
  1. os geiken multiplate clutch is much better than the blitz - its can handle twice the abuse and power
  2. bump
  3. as I above I need the 3 bolt bracket that bolts onto the gearbox. not this part http://www.jdm-ep.co.uk/index.php?main_page=product_info&cPath=132_142&products_id=994
  4. Got some amber indicators off Russ, they arrived in good time and well packaged. Thanks Russ
  5. not sure abt the stock ecu but if you are planning to keep the pnp ecu in there just follow what I told you and report back, Until you do this you will not know if you genuinely have a issue.
  6. H_D
    Abs or non-Abs
    that's non abs
  7. remove your rrfpr - typical schoolboy error for pnp ecus - until you have physically driven the car after an ecu reset for between 50-100 miles you will never know its true values - once you have done this report back. I had similar issue with the following ecus - ZEP and JAM. however after a few miles of driving everything was fine.
  8. £5 from toyota
  9. go direct to toyota main dealer - they are £7 each
  10. they work well when its wet/rainy but rather shit in the dry
  11. H_D
    amber indicators lenses
    prices posted to Leicester please
  12. As above. I am after a set of amber indicator lenses for my V in good condition no cracks or chips please. Or if anyone wants to swap for my clear ones I have some mint ones.
  13. im running these 195 45 16 and they still look chunky
  14. H_D
    Oil on plugs
    is that across all 4 cylinders with all plugs removed?
  15. Car will run rich after an ecu reset and usually trims itself after 50-100 miles on pnp ecus
  16. Are u sure u bridged the correct ports?
  17. Hows it fuelling on boost? Hows it fuelling on boost?
  18. no they don't
  19. Go direct to toyota cost £45ish
  20. if the piston seal has perished it will cause the piston to get stuck. New calipers are very expensive. you would be much better off rebuilding the existing one
  21. all bearings are still available - oem and aftermarket. whoever said you cant get bearings is talking out of their backside
  22. http://www.toyotagtturbo.com/forums/showthread.php?95258-4-pin-TPS-Check-amp-Adjust http://www.toyotagtturbo.com/forums/showthread.php?100946-Tutorial-TPS-setup-Procedure-weeJohn-*
  23. Please check your PMs URGENTLY.
  24. lovely kit. does this fit with a stock radiator?
  25. yes you can. I did this on my hks actuator. I had to drill it out
