H_D
    1867
Everything posted by H_D
  1. phwoooooooooooossssshhhhhhhhh lol
  2. 1.2 bar on a ported ct9b all day long i been running this boost pressure for ages now and it still pulls really well no smoke...no joke lol
  3. did you re-graese the piston and sleeve on the dumpvalve when cleaning it? as this can cause it to stick open and close on and off boost
  4. so whos definatly coming? as i dont wanna be the only one that turns up whats the postcode
  5. its all about BANZAI mag anyway
  6. Clean out your idle controll valve and also check for any vacume leaks, Hope this helps!
  7. H_D
    Tropical fish
    i have tropical and marine fish will put some pics up later
  8. camskill.com is your best bet mate i wouldnt bother going for cheaper parts if they are not genuine toyota bits
  9. 1) LukeSR 2) Josheyboy006 3) N80Jamie 4) tkdellis 5) H_D
  10. Cheers mate thats all i needed to know!
  11. Its a simple fix, take the rocker cover off and push the new seals in, i would use a hight temp silicone paste aswell to insure the seals are air tight
  12. I have noticed a little bit of oil seeping from the underside of the dizzy, is there some sort of seal or washer in there that could be causing the leak i have not taken it off to have a look as i dont want it to mess with the timing, Regards H_D
  13. hello and welcome!
  14. cant make it japshow on this day
  15. £30 for 3 power runs £35 if you want AFR on the dyno graph aswell
  16. Let me know if yout want meet up before driving down
  17. anyone up for this?
  18. So i take it u will be at the japshow finale this month.
  19. hello boys and girls My mate runs a tuning company in leicstershire called future motorsports. He is holding an event on 05/09/2011 its gonna be a german VS jap rolling road shoot out. The event starts at 1930. The last rolling road event he had was an absoloute success with a good few hundred cars that turned up (there was even a cat fight lol). If any one on the forum wants to attend they are more than welcome to do so. The more cars the better the more starlets EVEN BETTER. For more info visit : http://www.facebook.com/?ref=home#!/gr...gid=29783948587 Regards H_D
  20. H_D
    zep racing ecu
    check all the connections and the wiring carefully on your knock sensor i can guarantee u there is a faulty connection or a break in one of the wires. Be patient and take your time
  21. H_D
    zep racing ecu
    The thing with the zep is it is more sesitve to picking up fault codes than the standard ecu...i bet if u put the standard ecu in it will not detect a fault code.....trust me mate ive had 2 zep ecus in the past and im running one as we speak, When i had my 1st zep ecu it kept bringing up code 12 which realted to rpm signal so i put the stock ecu in and it was gone, i decided to clean up all the clips an connectors around my distributor as well cheking the connections....1 of the connections did not look so good so i had i soldered and re-installed the zep and the eml light dissapeared but this fault never came up on the stock ecu...hence the zep is more sensetive to picking up fault codes, My mate also had code 12 come up and he thinks it went away after changing his dumpvalve but it came on again after a few weeks...again it was a dodgy connection on the dizzy wiring
  22. H_D
    zep racing ecu
  23. H_D
    zep racing ecu
    Its in the engine bay fusebox, it should be labelled on the actual fuse box cover....this is the proper way to install a self learning plug and play ecu...dont take any silly shortcuts do a proper job and u should get proper results. Hope this helps!
  24. Have we got stand there and is there space for me!
