H_D
    1867
Everything posted by H_D
  1. H_D
    WYNNS engine flush
    I have heard many horror stories about flushing 4efte engines the deposits can block the sump starainer causing a your block to cease up due to lack of oil flow and pressure
  2. leicester was f**** up, lots of damaged cars and properties and some major roads got flooded,
  3. if your lookin to run 400bhp+ then go for a bigger inlet manifold and TB if not then there is nothing wrong with the stock one its more than capable!
  4. I dont think any trader in the uk stocks ZEP parts...TMD used to but sadly gone now
  5. he got it 2nd hand directly from speedvision it was one of their test units which had covered 3000 miles befor he got it
  6. My mates been using speedvision hybrid for almost 5 years and not had any issues at all and it still pulls well with no issues,
  7. the only way to find out the spline count is to take the old ones off and count the splines.
  8. not sure about the size but camskill do the genuine toyota ones for approx £8
  9. crap unless if you replace the plastic piston inside with a metal one which can hold thicker rubber seals and also change the spring to a stiffer one.
  10. The best way to do it is to remove the bulb and probably the easiest without cutting wires
  11. H_D
    Ignition leads
    As the thread states...im after a NEW set not used, Thanx anyway buddy,
  12. H_D
    Ignition leads
    Im after a full set of NEW ignition leads preferbly TRD or NGK or anything else thats decent. Im not interested in magnacor as i have had problems with these in the past. Does anyone know where i can get these from. Thanx H_D
  13. H_D
    Missing Fuses
    I noticed I have 3 missing fuses in the fuse box under the steering wheel on my V. The missing fuses are ECU-B 5AMP - IGN 5AMP - DEF-I/UP 5AMP.....Should they be in there or is it ok to run the car without them.
  14. Its a 1 hour job and the replacement exedy clutches are apporx £70....£240 is way to steep even if the garage supplies you with replacement gear box oil and clutch fluid.
  15. Forget mild steel and stainless....im going for scedule 40 its bombproof and used in alot of rally cars
  16. Any chance of getting a closer pic of the serial number on the plaque so we know which one it is incase it comes up for sale again
  17. il try n find out who it is de-montfort uni is very local to me. was it a HKS dump valve by any chance cuz there is loads of fake ones flying around leicester at the moment i even saw them selling boxed as new for £60 at a car boot last week lol
  18. Im from leicester and have plenty of local links in the motor trade who deal with uk spec and imports.....never heard of him! What are you after?
  19. Im in! 1) Drongo boi 2) Matt Richmond 3) Socks 4) H_D (sunday only)
  20. . really...do u keep it on a leash! might get my little fising rod out and see if i can catch any fish in my tank lol
  21. im at work as we speak and i keep staring out the window as my office is right next to mallory park race track, the sun is shining and i can hear engines whining...lol
  22. Your best bet is to call them and ask...it says oem in the discription so not sure i dont think its a toyota one but i dont think tunning developments will list cheap or crappy parts as they are a well reputable company im sure many people on the forum will agree with this
