H_D
    1866
Everything posted by H_D
  1. The type of thermostat you have will determine when the fan comes on. I think the standard thermostat is supposed to trigger at 82deg and then you get the aftermarket ones which trigger at lower temps,
  2. Nice GT dude...what sort of power did u make on the KKK?
  3. H_D
    Inlet mani gasket
    As above i need the following for my V (genuine toyota only please) I know there are 2 different types, I need the one which blanks off the extra water passage on the head. Thanx!
  4. Thanx guys...the car has had lots more work done over the past 6 months so this current thread is not a true refelction of how it stands at the moment, Will do a proper update very soon.
  5. can i have one with the following message laser etched on the front.......yes i have paid my tax, now go fix some f****** potholes. Im using a plastic one with that message on it at the moment and its gotta be the best one i have ever had or seen...lol http://www.ebay.co.u...#ht_3799wt_1257
  6. I have just literally copied and pasted my old thread from TGGT but will be updating it properly this weekend,,,, For those that dont know here goes............. 16inch Ultralite G-spec alloys in white, Full setup of KYB Shocks and springs, HDI front mount intercooler 9mm blitz ht leads, Polished cooling panel, HKS actuator, jap performance d-cat pipe, HKS high power silent exhaust, Nomad racing dump valve, Apexi Boost gauge with apexi pod Recaro bucket seat JDM style (driver side) HKS turbo timer 1 off custom built aluminum vent cover for those rainy days Apexi 1.3bar radiator cap Forge motorsport aliminium oil catch tank Zisco performance mild steel ram horn manifold Air filter relocation kit HKS Teflon coated braided brake lines zep racing ecu Clear cam cover Ported ct9 turbo Walbro 255lph fuel pump TurboSmart boost controller De-badged and Flushed radio antenna (looks much better) Zisco rear strut bar Im sure i have missed a few things out and im sure there will be a few more to come. some new bits n bobs! Loads more to come hopefully ready for summer 2012!!!! Hello all, As above i thought i would share some pics, Any feedback and thoughts welcome! The block has been bored out to 75mm, new block plugs, Arp crank studs and re-linebored also chemically cleaned and fully tested etc... The head has been chemilcally cleaned crack, presssure and vacume tested bench and flowed etc with identical combustion across all 4 chambers, valve seats re-cut with cnc and a 1 off direct fit custom head stud kit (not 4a-ge studs as they are not a direct fit) and cruise springs also ported and polished on exhaust side (still awaiting cams and solid buckets) Pistons rods all Arp connectors, bearings and reground crank fully balanced Sump and strainer chemically cleaned Lots more has been done but i have not had the time to update the thread...Hopefully all will be revealed this weekend when i get some spare time!
  7. Thanx for confirming that guys! Probably the fastest time I have ever had a response on a forum...lol
  8. I cant seem to access TGTT from my p.c or phone. Has anyone else had any issues?
  9. Cuz its better than ruining a glanza...lol
  10. Might as well change decat to exhaust gasket too!
  11. The fucktard that proposed this needs to be ran over.....But wait this will make my car dirty so i will have to wash it
  12. working till 5pm and im not allowed to go home early even though i have no work to do today
  13. Looking good....I have the same wheels on mv V in white (ultralite G-spec)
  14. Thanx for the replys - I didnt buy it in the end as all the wheel arches were rusted and it was a cat d write off! i ended up spending £850 on a pushbike lol
  15. Ok so im looking to buy a 1998 ep91 N/A for the winter, I going to view it tonight, Is there any common problems on these i should look out for?
  16. cant go wrong with a bit of bling bling. I sent mines on a spa day with her best mate she loved it!
  17. Welcome...I really enjoyed reading this
  18. are you loosing any oil/water? It might be worth taking the turbo off and checking for oil on the exhaust side and shaft play. Hope this helps
  19. Im pretty certain its a dealer only part...You will have to call toyota or try idrees on here
  20. This is most probably my favorite non starlet on the forum...Absouloutly mint....I bet shes a beauty to drive
  21. H_D
    Petrol rc car
    Is the drivetrain on that shaft driven or belt driven
  22. i put up a wanted thread for a door handle ages ago and nobody got back to me and i still need 1
  23. Wher abts in leicester???? I know a place that does detailing it costs approx £80
  24. great vid...well done
