688 -
Everything posted by Patches
It's a good point actually, were these cars using aftermarket intake manifolds which came with aftermarket throttle bodies? I think I'll still go ahead with this as for me its all about keeping the costs low. I've never had anything made with a CNC machine before so if anyone has any experience/advice I'd love to hear it
Just wondering if anyone has attempted to do something like this? http://www.nzefi.com/product/toyota-1uz-fe-idle-speed-control-solenoid-conversion-kit/ I've ordered a throttle body to wax stat gasket off Toyota so am planning on scanning this in to design an adapter plate in CAD similar to the above link. The wax stat system is shite and I don't fancy forking out £1300+ for a DBW system, capable ECU etc so this seems like a cheaper alternative. Should provide a nice stable idle while reducing heat in the intake.
Not had the time to look at it again. My next step was to run my own wiring from the ECU to the plug at the clocks as at the moment i'm using the original wiring but i've either wired into the wrong place or its not suitable for the low current. Got a list the size of my arm of things to sort before I get to that.
Got the car booked in to get the new wheels fitted and got an alignment (it badly needed the camber sorted) and decided to get corner weighting done at the same time as it wasn't much extra. Total car weight is 957kg which isn't too bad. The car handles much better now as you can imagine, no longer feels like it handles turning one way better than the other. Really impressed. How it's sitting now, really happy with how the wheels look.
The oil pressure switch is at the bottom right of the engine. It has a single wire going to it.
Have you set the base ignition timing with a timing light? If not I would do that first to ensure its firing the correct cylinders at the right time
Anything worthy of an update now?
A few updates I fitted the fuel pressure sensor on the return line, after the regulator. This is the completely wrong place to put it! I need to move this to the feed line, I switched to using traditional fuel equation for the time being and can now run boost The mayo was just condensation from sitting for a long time so no need to panic there. The cars getting used a lot despite loads of wee jobs left to do in terms of tidying up. Road tuning is pretty hard with traffic and my limited free time so I've not completed the mapping yet. Need to set aside a full day and borrow a mate to finish this. May hire a dyno depending on free cash. And I got these delivered the other day
Yeah its worth checking the wiring at the o2 sensor as well as this can get a bit worn over time. Is your AFR ok on boost?
I had a similar issue, I replaced my o2 sensor with a non genuine one and it never fixed the issue. I then fitted a powerfc with the hand commander which read out the voltages for all sensors and the new o2 sensor was reading 0V. Turned out the sensor didn't work. £90 for a genuine sensor and problem solved. I'm not saying this is your solution but that's what I had to do in the end.
Can't see any pictures since you mentioned trying from your google account
Have a look at what bilt hamber have on their site, some of their products are great for treating rust https://www.bilthamber.com/corrosion-protection-and-rust-treatments/deox-gel
How are you finding those daniel? I think one/many of my mounts are worn but I'm not keen on having more vibrations
Hi Grant, Welcome to the forum! You should definitely get some pictures up both old and new
I use this site to find part numbers, just select your car from the options at the top and then you'll be able to see diagrams as well as part numbers http://japan-parts.eu/toyota/jp/
That could be Mike84
Yea I raised these issues also, admins need to get the finger out and fix these issues. Its no wonder why people are using facebook instead
Anyone used one of these wheel bearing tools?
Patches replied to Patches's topic in Alignment & Alloys
Cool man I'll give that a go first then. Hopefully this resolves the issue -
ah right, was thinking i might need it to press the hub in? Heard that the bearings can split otherwise, could be wrong -
I've got a rotational noise coming from my disc hitting my caliper bracket after a wheel bearing change. I've got a spare hub to swap in so I'm going to try that next but think I'll need one of these tools to swap it. https://www.ebay.co.uk/itm/Heavy-Duty-Front-Wheel-Hub-Drive-Bearing-Removal-Tool-Set-Kit-FREE-DELIVERY/261319029295?hash=item3cd7d3f22f:g:4lkAAOSwn45Z3I5p anyone used one of these on their starlet?
I've got one for 98 spec sitting about somewhere. Pm me if you're interested
That'll be an auto throttle body, assuming you mean for starlets? Quite hard to come by, if you're going standalone then you can use a skyline gtr TPS on the manual 3 pin throttle body. Works really well, few people on here have done it. Just have to cut the spindle down slightly and tap some threads in holes which already exist.
Worth asking Toyota, think these can be had for a reasonable price
Awesome stuff man! Glad to see an update on this. Great choice of ECU, been looking at e-throttle myself keen to see how this goes. Haven't seen anyone else using one on this forum. What are your plans for the conversion? Welding on a new throttle flange to the intake? I was looking at gt86 pedals and bosch motorsport e-throttle body if i was to do it myself
It was the best high power starlet build I ever almost seen
