ashep91 Posted May 18, 2017 Posted May 18, 2017 Does anyone know where I can buy a full set of genuine Toyota engine bearings for my 5e build Quote
daniel_g Posted May 18, 2017 Posted May 18, 2017 Go for ACL. They might even be cheaperHave you had your crank measured? Quote
wickedep Posted May 18, 2017 Posted May 18, 2017 genuine toyota is much stronger and durable than ACL duraglide in my experience. ACL race is a different story, but nobody stocks for 4/5e. our own car which is now making in excess of 450whp has been using genuine toyota bearings from day one. the one time i decided to use ACL was the only time bearings gave out. we have more than few other local lads also making in the 350-400whp range on toyota oem. beware of duplicate Toyota bearings. at least over here you do find them. so maybe buying direct from Toyota is best bet. just sharing my experience with you guys. do with the info what you will Quote
ashep91 Posted May 18, 2017 Author Posted May 18, 2017 Local engine shop doing all the work ect been around for years Quote
gorganl2000 Posted May 18, 2017 Posted May 18, 2017 (edited) your best bet is toyota dealer itself...but sometimes you have a long wait if they are out of stock try this place...but you will need part numbers for the bearings you require (the website is cheaper)https://partsouq.com/ http://www.ebay.com/itm/117011101202-Genuine-Toyota-BEARING-CRANKSHAFT-11701-11012-02-/182382066614?hash=item2a76d17bb6:g:UgcAAOSwdjNZGILH&vxp=mtr i recently got some Genuine Toyota 5e bearings from them in VERY fast time at a great price here is another ebay sellerhttp://www.ebay.com/itm/Toyota-OEM-Crank-Shaft-Main-Bearing-Set-11701-11012-03-/152552599167?hash=item2384d7ee7f:g:nCoAAOSwtZJY9RFW&vxp=mtr those are all 5e bearings-----you can determine which numbers/mark/grade you need and contact them Edited May 18, 2017 by gorganl2000 Quote
Calum122 Posted May 19, 2017 Posted May 19, 2017 Cheers Sacha, I always thought ACLs were supposed to be replaced every 25k and wondered why people didn't use genuines. Quote
gorganl2000 Posted May 19, 2017 Posted May 19, 2017 11701-11012-01 MARK 1 11701-11012-02 MARK 2 11701-11012-03 MARK 3 11701-11012-04 MARK 4 11701-11012-05 MARK 5 crankshaft bearing part numbers - 5e 13041-11010-01 MARK 1 13041-11010-02 MARK 2 13041-11010-03 MARK 3 connecting rod bearing part numbers - 5e you can always double check on www.toyodiy.com Quote
daniel_g Posted May 19, 2017 Posted May 19, 2017 Cheers Sacha, I always thought ACLs were supposed to be replaced every 25k and wondered why people didn't use genuines.Was not aware of this and was advised to run ACL. Ohwell haha. Quote
gorganl2000 Posted May 19, 2017 Posted May 19, 2017 i've always used toyota genuine bearings as well...never had any issues over the yearsits to the point where i refuse to build an engine without them i'm sure the other reputable brands have credibility and success stories,...but for me its genuine toyota bearings or nothing Quote
ashep91 Posted May 19, 2017 Author Posted May 19, 2017 Does anyone know who manufacturers the bearings for Toyota usually there's a sister company that manufacturer it then Toyota stamp there name on it Quote
Fozzie Posted May 19, 2017 Posted May 19, 2017 I seem to remember someone mentioning that Taiho made Toyota bearings... Quote
patman Posted May 19, 2017 Posted May 19, 2017 Was not aware of this and was advised to run ACL. Ohwell haha.See even though I got toyota bearings in mine I was always told ACL's only needed changing every 25k if they were used for racing or track, so who knows now. Quote
ashep91 Posted May 19, 2017 Author Posted May 19, 2017 Most people I've talked to who have been modifying starlets for years have said definitely use Toyota bearings over acl or similar brands Quote
wickedep Posted May 20, 2017 Posted May 20, 2017 I seem to remember someone mentioning that Taiho made Toyota bearings... yes correct... TAIHO Quote
AdamB Posted May 21, 2017 Posted May 21, 2017 See even though I got toyota bearings in mine I was always told ACL's only needed changing every 25k if they were used for racing or track, so who knows now. They need checking / replacing every 25k. They're a softer material, don't forget Toyota would have designed the engine to last 150k miles. Quote
elikhan Posted July 11, 2018 Posted July 11, 2018 Anybody know the part number for 0.25 Taiho bearings? Asked the dealer but they just gave me MK1/MK2/MK3 options and couldn't tell me measurements/if they could supply undersize without a part no. Quote
GP82 Posted August 6, 2018 Posted August 6, 2018 OEM all the time! There are 1000+ HP Toyota E series race engines running Toyota bearings! These motors are stripped for inspection after every other race and put back together with the same bearings! Quote
