just went for the first drive and it is pouring out blue smoke and the turbo isnt spooling
how do you setup a external wastegate and im not running any form of boost control?
  • Replies 992
  • Created
  • Last Reply
Top Posters In This Topic
so this weekends progress
well on friday i recieved my new rad hoses and samco pipe to come off the turbo
think its tidied up the bay abit
then cut the intercooler piping to custom fit the K24 turbo
then fitted the radioator filled it up and started the car up which i shouldnt of done!
i didnt no you had to prime the turbo up before hand
i went for a 2minute drive and its was pouring out blue smoke after the drive, i then primed it and took it for a 30second drive and it seemed fine but after letting it idle for 5mins its starting smoking again so possibly knackered the oil seals :D
i also have a massive bost leak and the car is only running about 0.1bar so havnt even felt k24 power and it already looks like the turbo will have to come off
im gutted!
im going to take all the intercooler piping off, see if there is any oil in there and re-clamp it all to see if i can get rid of the boost leakand then go from there
here is how i left it at the moment ready to strip down again next weekend
if anyone has any suggestions on why its smoking other then seals please let me no
im gutted!
i went for a 2minute drive and its was pouring out blue smoke after the drive, i then primed it and took it for a 30second drive and it seemed fine but after letting it idle for 5mins its starting smoking again so possibly knackered the oil seals :p
im gutted!
Have a look round all the pipe joins for signs of oil. If the turbo is shitting oil you might see it blown out your air leak. Have you run it to operating temperature yet?
Was txting him earlier grant, sounds like a big boost leak, like when you pointed out the clip i missed on my fmic when the vf24 lost all boost. You got the right attitude though ollie, strip down and redo it :D
Really like your V man, makes me feel guilty about how dirty mine is! but seriously I hope its nothing more than the seals mate.. i want to see some K POWA!!! :D
Just taken all the intercooler pipes off and the airfilet off, there is no oils in any pipes and the oils feed return pipe had loads of oil in it, so I'm quite happy no damage has been done to the turbo, I also forgot to put washers on the de cat so there was a gap around the bolts
Im going to re-fit all the intercooler piping and make sure it's as tight as possible then see what happens :)
Fed up now!
So still smoking and very little boost, I took the car to 5k rpm and had a bit of chatter but very faint
Going to check the wastegate for any damage and then im stuck
Hopefully shorty is coming over Sunday, I'm sure I have missed something small but no clue what so sure shorty will find it :D
I also tried a vac line from the wastegate to the inlet mani and still nothing, what part of the inlet mani should I put it too?
any part of inlet mani to the bottom of the waste gate i dont see how it would work with out the vac line tbh your exhaust gas pressure would need to be like 0.7bar lol
