Well here we go!
I have finally got my new car! Its a Toyota Starlet GT Turbo 1995 quadlight in white!
I had a couple of mates come with me to look at it in high wycombe and tbh it was a dog. Mechanically sound but cosmeticly needs a good going over. Priced at £2250 and got him down to £1750 but still wasnt happy so we left. The next day i had a call from the seller saying he would let it go for my original price which was £1500 sorted!
My mate and the missus drove me down to it last saturday to go and collect it so here are the pics when i got it
Pics of the damage
So i thought i would get started straight away on making the car my own smileegg.gif
First things first, get rid of those horrible shopping lists!!
I needed nails so enilisted the missus to help lol
Got rid of the rear Starlet and GT Turbo stickers aswell
Then i started to go about cleaning smileegg.gif Took the wheels off and jet sprayed the arches and the wheels because i have never seen anything so MINGING!! (apart from the missus in the morning laughegg.gif)
BEFORE
AFTER
Add some nice new shiney blue wheel nuts
Then i wanted to strip it as i love the stripped look!
BEFORE
AFTER
Decided to give it a bit of a clean as it was minging aswell!
So here it is overall!
Have also been Hammeriting the boot and seat pans in white and so far the first coat looks very good!
Also i have a De-cat/screamer pipe to fit, lower arm and going to get timing belt done next week smileegg.gif
Plans over the next couple of months will be Coiilies, front and rear ARB's, Polybushed, Adjustable panhard rod, Rear strut brace, c-pillar bar and cross section braces.
Watch this space for more updates!
Edited by Wardy
  • Replies 250
cheers guys! Just trying to make it look clean and simple but with some goodies. Focusing on the bits like suspension and brakes first before i start adding serious power as i want the rest of the car to cope
  • 1 year later...
  • 3 months later...
I have now completed the boot
Now to the outside of the car, I recently bought some JD Tuning tow eyes for front and back of the car. They came powdercoated in red so i decided to sand it all down and put my own personal touch to it to more match the car, sooo out came my dads left over ford diamond white lol! and this was the finished result with JD Tuning Graphic attached.
Fitted to the car
Also that same day i fitted my Screamer Pipe and Decat and it sounds really good! Pops the odd flame or two winkegg.gif No pics as of yet
Some pics i took the other day
I had standard springs and dampers on the Starlet so i decided to go and speak to Jerrick from MeisterR and grab a set of coilies which are very highly rated!
Heres the old ones
They were mullered! It was leaking oil and flying around like a bouncy castle!
Fitted
Rides and handles amazingly! absolutly love them! Fully adjustable for dampening rate, spring rate, toe in and out, Camber +/-
Then a month after that the gearbox went bang! So me being me i thought why dont i look at getting something different winkegg.gif Indeed i did!
I bout a EP91 Gearbox which has shorter ratios and has just been reconditioned with hiding inside a ATS 2 way LSD smileegg.gif
Old box
Pictures of the new one!
Clutch
Then i decided to upgrade the intercooler to a front mount intercooler
Heres a few pics of it at the moment
Then i decided hmmm.... LSD, Coilovers and slightly stripped, it needs to lose more weight!! So heres what happened!
Add a rear strut brace and c-pillar bar
Plus some 4 point takata Harnesses
Old and New Whiteline Panhard Rod
New Whiteline 24mm Front ARB
Also comes with Polybushed drop links
Then i got hold of some lighter front wishbones with polybushed bushes and Anti Lift kit, These also gave it a slight bit of negitive camber.
A few Pictures of Me and Mark411 at Cadwell Park
Some very low resolution pictures of me going round Cadwell
After going round cadwell park i thought to myself i need brakes! I boiled my brake fluid and my standard brakes just wasnt up to the job! and i wanted just a little more power for now aswell so i started on the exhaust system by buying a secondhand custom made manifold
Add some heatwrap
Then a Side Exit Exhaust
That is also heatwrapped and chucks out constant flamage!
Few other little bits included a full service, iridium plugs, new 8.5mm HT Leads Front mount airfilter
Also to keep it cool i got a Civic twin core radiator
Also a Spal 12" Fan
Now to my braking!
rears were done first so i got some normal sizes rear discs but grooved with O.E Spec mintex pads
Fitted
Then i wanted something a bit more special and wanted to go different from the rest of the crowd so i bought these smileegg.gif
They are WMS 4 Pot calipers with 277mm x24mm discs and Ferodo DS3000 Pads and all i can say is they are AMAZING!!
Fitted
Then i had a bit of a problem with my turbo where is was smoking on idle so we all put our heads together and thought it must be the turbo oil seals so i bought another one for £40 and Brad gave me a hand fit the new turbo at the farm in a barn! 3 hours later and no smoke smileegg.gif
Turbo
Now i have just bought some new wheels, They are SSR Speedstars in white and are very nice! Just have to get some 10mm spacers to fit over my new brakes :S
Some other little updates
New SSR wheels and R888 tyres ;)
Some random pics i took
Bought a 6 point Roll Cage off of Rinseep and got it bolted in but now has been sent off for paint :)
Need to bash the rest of the sound deadening out and then Hammerite the front white
Also fitted some polybushed engine mounts as the old ones were fudged!
Cheers guys, its looking a bit sorry for its self at the moment but it will all fall together eventually!
  On 10/21/2012 at 8:38 PM, hughes21 said:
Looking good mate . Where you from sure I've seen this in Folkestone a few times ??
You probably have mate i go down there at the weekend sometimes :)
Busy day on the GT saturday! I decided to have a go at the sound deadening!
First it looked like this
Then i bashed, hammered, chistled and even sliced my fingers open for it to look like this!
I then got a drill and a steel brush wheel to get rid of the crap which lay underneath.
Looks a bit better and with the seats in
Now just got to tape up and sort the loom out ready for hammerite :)
