the quiet achiever Posted January 12, 2011 Share Posted January 12, 2011 hi all i finally got it all together &revised the twin-pot caliper/disc upgrade without a spacer hope it helps those who are having problems ep91_disc_brake_up_grade.pdf Quote Link to post Share on other sites
mk1kurt Posted January 12, 2011 Share Posted January 12, 2011 so what i need st185 calipers.. 318 bmw disc's.. but i dont understand what i need to modify to make them fit ?kurt Quote Link to post Share on other sites
the quiet achiever Posted January 12, 2011 Author Share Posted January 12, 2011 kurtm849 said: so what i need st185 calipers.. 318 bmw disc's.. but i dont understand what i need to modify to make them fit ?kurthi there is no modification needed it all fits on like an OEM set-up the only engineering required is a shim/ washer under caliper mount because of miscalculation in measurement &a spigot adapter to centre disc on hubdoes this make sense lyle Quote Link to post Share on other sites
lukEp Posted January 12, 2011 Share Posted January 12, 2011 That's fucking awesome fella thank you very much, this will help ally of people upgrade there brakes without the hassle if I could give you rep I would Quote Link to post Share on other sites
micky boy Posted January 12, 2011 Share Posted January 12, 2011 My computer wont let me see the link can someone convert it to a normal link lol Quote Link to post Share on other sites
LukeSR Posted January 12, 2011 Share Posted January 12, 2011 Its a pdf file Micky, just download adobe reader Quote Link to post Share on other sites
micky boy Posted January 12, 2011 Share Posted January 12, 2011 Cheers for that Luke i can see it now ..That is awesome, thank you very much for shareing with use i think i might give it ago Quote Link to post Share on other sites
Starbuck Posted January 12, 2011 Share Posted January 12, 2011 N00B question - but can this work for ep82s. I know it says 91 on the link??? Quote Link to post Share on other sites
Josh@TunerLifestyle Posted January 12, 2011 Share Posted January 12, 2011 really would like to give this a go but it looks so complex! wat do you mean by make a donut and this part :machining tip :machine to press on hub &it stays on hub when you remve disc or machine to press indiscafter trial fitting new parts I found I had mis calculated the hat/offset by 3mm no biggy I justcan anyone do this or is it something a specialist would need to look at?cheers josh Quote Link to post Share on other sites
5T4R7ET N/A Posted January 12, 2011 Share Posted January 12, 2011 nice one mate, was planning to do this soon. ^^^ i thing the spigot for the ep82 will be slightly different because ep82's have a 54mm bore, otherwise it should be the samesomeone confirm? Quote Link to post Share on other sites
the quiet achiever Posted January 12, 2011 Author Share Posted January 12, 2011 josheyboy006 said: really would like to give this a go but it looks so complex! wat do you mean by make a donut and this part :the spigot on hub &disc are different sizes so machine a donut up to centre the disc machining tip :machine to press on hub &it stays on hub when you remve disc or machine to press in make the spigot adapter to fit tight on hub or disc so if you take disc off the adapter stays on the hub or it comes offwith the disc after trial fitting new parts I found I had mis calculated the hat/offset by 3mm no biggy I just shim out the caliper to centre on disc i used a couple of thick washers &longer mount bolts can anyone do this or is it something a specialist would need to look at? i have a small lathe so i make my own stuff but any engineering shop can do it hope that clears things for youcheers joshhi joshreally would like to give this a go but it looks so complex! wat do you mean by make a donut and this part :the spigot on hub &disc are different sizes so machine a donut up to centre the disc machining tip :machine to press on hub &it stays on hub when you remve disc or machine to press in make the spigot adapter to fit tight on hub or disc so if you take disc off the adapter stays on the hub or it comes offwith the disc after trial fitting new parts I found I had mis calculated the hat/offset by 3mm no biggy I just shim out the caliper to centre on disc i used a couple of thick washers &longer mount bolts can anyone do this or is it something a specialist would need to look at? i have a small lathe so i make my own stuff but any engineering shop can do it hope that clears things for you lyle Quote Link to post Share on other sites
Josh@TunerLifestyle Posted January 12, 2011 Share Posted January 12, 2011 sort of get it now! if i was to buy the disks calipers and all the stuff that dosent need machining , how much would you charge to machine up a donut whatever it is? im just useless at stuff like that lol but if i can get the bits ready so it will all just bolt on id probs give it a go cheers for the info!josh Quote Link to post Share on other sites
Amjad Posted January 12, 2011 Share Posted January 12, 2011 What would be the likely total cost of this kit? Quote Link to post Share on other sites
the quiet achiever Posted January 12, 2011 Author Share Posted January 12, 2011 Amjad said: What would be the likely total cost of this kit?hi not sure on parts supply over there . but in oz calipers 2nd hand =$200 +o/haul kit $70 disc $240 pr engineering ???depends on whether you can do it your self rough guide only lyle Quote Link to post Share on other sites
Raffi Posted January 18, 2011 Share Posted January 18, 2011 As I understand it. The calipers are from a celica GT4 st185, and so are the pads. And the discs are from a BMW e30 318 (260mm and bolt patterns are 4x100mm, disk thickness 22/21mm, vented)Is this correct? The part number for the dics, is it for original discs or some other make?I am, maybe going to try this, it all depends on how much I can get the calipers for. Quote Link to post Share on other sites
mk1kurt Posted January 18, 2011 Share Posted January 18, 2011 Cheers raffi summed it up nicely cheers mr achiever Kurt Quote Link to post Share on other sites
the quiet achiever Posted January 18, 2011 Author Share Posted January 18, 2011 Raffi said: As I understand it. The calipers are from a celica GT4 st185, and so are the pads. And the discs are from a BMW e30 318 (260mm and bolt patterns are 4x100mm, disk thickness 22/21mm, vented) hat/offset =35mmIs this correct? The part number for the dics, is it for original discs or some other make?I am, maybe going to try this, it all depends on how much I can get the calipers for.rda make the disc `s in australia so what ever co you have over there should be able to cross reference them to there part no Quote Link to post Share on other sites
Aus_EP91 Posted January 19, 2011 Share Posted January 19, 2011 You need to have a centre ring made up (this isnt easy for everyone) for the disc as the hub carrier on the starlet is 55mm and the BMW IS QUITE larger. Doing it this way you dont need a back spacer BUT you need someone to machine that ring in the middle, which isnt easy for everyone to get done. And you HAVE to use this centre spiggot spacer with this option, if you dont the outcomes of not using it will be far worse than if you just use larger studs and a spacer.I guess thats the trade off. Quote Link to post Share on other sites
BoGlE Posted February 7, 2011 Share Posted February 7, 2011 So how big do i need the shim/spacer to be to centre the disc? Quote Link to post Share on other sites
the quiet achiever Posted February 8, 2011 Author Share Posted February 8, 2011 BoGlE said: So how big do i need the shim/spacer to be to centre the disc?hi your hub dia is 55 mm or 54mm the dis is 66mm so the spigot bush is 66mmOD &55mm ID 10mm thick lyle Quote Link to post Share on other sites
BoGlE Posted February 8, 2011 Share Posted February 8, 2011 Ok thanks for that Quote Link to post Share on other sites
5T4R7ET N/A Posted August 18, 2012 Share Posted August 18, 2012 the link in the first post doesnt work so try this insteadhttp://www.datafilehost.com/download-20823fa3.html Quote Link to post Share on other sites
monty1991 Posted April 15, 2013 Share Posted April 15, 2013 could someone fix the link for me please? Quote Link to post Share on other sites
HOK Posted September 29, 2013 Share Posted September 29, 2013 On 4/15/2013 at 6:05 PM, monty1991 said: could someone fix the link for me please? 2 nd this please. Quote Link to post Share on other sites
Neo95 Posted October 18, 2013 Share Posted October 18, 2013 On 1/12/2011 at 11:50 AM, the quiet achiever said: hi alli finally got it all together &revised the twin-pot caliper/disc upgrade without a spacerhope it helps those who are having problemsep91_dis...up_grade.pdf Sorry to be a pain but I carnt seem to get the link working any ideas people. Also how hard is this to do?? Thanks Neil Quote Link to post Share on other sites
