Abbotts Greddy TD05 Track Glanza
  • Replies 585
  On 2/26/2016 at 1:19 PM, MustakimQZ said:
Looks like you're the fastest car out there. Brilliant mate
Was great fun chap and not to sound big headed the only thing to go past me was a friends time attack evo and a ex seat race car more.
  On 2/28/2016 at 8:44 AM, RobSR said:
Nice stuff - tyres were definitely doing the job!
Yes would recommend all day long.
MORE VIDEOS TO COME
Well following my previous post with the car being revovered from brands due to a failure of somthing on my last session which i returned to the pits with a loss of boost, drove flat and a noise coming from the engine.
I started off the weekend with giving the car a good clean after the track day.
C4FAE307-68B5-402B-8F5F-A974FBDE72DA_zps
EF831C95-C649-40A4-BB17-67E1A46CD3E7_zps
20C58DE8-9636-4D54-828B-28F8FB02C5AE_zps
3DE5C17E-B84E-4399-8F97-F6AAC14FEB95_zps
2E0D2978-A8C4-432E-977A-01523C8FAFC2_zps
3C87F491-F750-452D-8B73-B91FCF427BF1_zps
Then pushed it in the garage and jacked the front end up and put it on axle stands. Started by removing the powersteering and alternator belds. Then went on to removing the top cam belt cover which started the story of whats happened.
1) part of the lower cover had broken and gone round the cam belt and ended up at the top sitting on the cam belt and melted.
2) went on to removing the crank pully and lower cover and revealed even more plastic.
DB5823E1-BA22-45BB-A97A-3A775FB88A28_zps
83509EA7-CD52-48CD-92BF-5703A3353F3A_zps
3) looking up from the bottom of the car i noticed that the engine mount had come away from the block noticing only one bolt was in there and that just pulled out with my fingers, one bolt snapped in the block and 3rd bolt was not there. Pulled the mount out and left with a snapped stud in the block.
1848A066-FD36-41D2-925A-071F7A9FE846_zps
0730FBA4-C35E-4694-AA19-85CFC5E6C85C_zps
4) because the engine starts up fine at brands but was flat and had a noise thought we would check the timing once its was in the position it clearlly showed the the belt had jumped 2 teeth which explains the loss of boost and engine feeling flat. So retimed, started up and bang on issue solved.
New cam belt required but going to do a whole kit with tennsions.
looking close at the mount the noise came from where it dropped on to the bottom belt cover which then broke and went round the cam belt and the mount ended up sitting on the tennsionor pully which caused rubbing.
A88B1498-0F61-46E4-9700-48F6DAF872B3_zps
E8454075-C1F2-4FD2-9010-85C20C0868AC_zps
A good friend helped me out today and removed the snapped stud out the block which is a bit of a life saver as was thinking i may need to drop the engine out and drill the stuff out. Gave it a brake cleaner up and removed the cam belt kit ready for the new to be installed once orded.
  On 2/28/2016 at 6:10 PM, Charlie28 said:
Glad it wasn't anything major bud! Car looks the nuts on track!
yes I feel a little relieved and glad its not a bad fix.
thanks chap :) will get some more videos up shortly
  • 1 month later...
  On 2/28/2016 at 10:11 PM, RobSR said:
Blimely, that could of ended a lot worse! Get the thread lock on there next time :)
Yes mate very thankfull. Defently lock tighting those buggers in
  On 2/29/2016 at 9:19 AM, MustakimQZ said:
Lucky you mate! Could have definitely been worse. By the way how did you get the snapped stud out?
Yes mate for sure. Manage to tap it out with a flat head tap took 30minutes and was a releafe not to remove engine :)
Got a new cam belt kit, bottom belt cover and got a new mount.
FD323A72-43DD-432A-B1DD-36CA3BF2DDF2_zps
68C0D2C7-7A7A-41E8-9AFB-B108C57A2D83_zps
BA2CAC74-B407-4E24-98DA-815CF855BEA2_zps
Got the car back together and locked tight the mount bolts in so hope that will be prevent it happening again as the car has been through a lot of strain with track days. Following getting it all back together and everything running fine i booked the car in with rob to do its yealy leak down/compression check which was the following week and results were good and better than last year.
Since then the car is back in the garage waiting for the next outing which will be soon i hope :).
Just a little update as to where the project will be going next and let the pics do the talking with a couple bits ive collected and will update as and when it happens.
F0B9E26C-C56D-4FA2-9282-F394715CB279_zps
06D56F29-4057-4A73-9E14-AF0D9AFBA950_zps
Updates to follow soon
  • 3 months later...
Not alot to update on as the car has hardley been used since feb after the engine mount failure
The ep82 track car shell went off to a good friend which is now in the process of having a full weld in cage.
A608C0D3-F000-4BA4-9788-F473D4E12F2F_zps
On from that i ordered some new brake pads front and rear as there due for a change shortly.
75DB78C9-17EC-415D-8371-913D208D0ACC_zps
Another reason why i have not had much time is due to being apart of my friends time attack team supporting him this season. The 3rd round at brands hatch Time Attack i took the starlet for a drive down for the day couple of snaps where taken.
676B602C-5663-4747-9F1C-729F57C30DC0_zps
363C07B0-DA32-4ACA-8CEA-4755A5B24E5F_zps
A friend of mine from the starlet days years ago Rikko got in contact through ebay as he had some interesting things for sale while he was back from work abroad. So popped up for a catch up and took a couple of things off his hands which he had for sale.
Route 6 clutch slave cylinder never used just left in its box juat need to give it a little clean.
6C98F4B6-AC45-4C51-9144-EE49B80211C0_zps
5efhe bottom end
Not sure what the plans are with it just a opportunity to purchase this and leave it on the shelf maybe mmmmmm!
5E7D8186-DCF6-4AD0-A6A3-737D3EE8AEFD_zps
B60222B0-53EC-429A-BA96-6FB8135D2051_zps
67835191-6B86-4ACF-B8D6-6161654519F0_zps
The glanza is coming up for a oil change shortley so spoke to wardy who kindly sorted me out some royal purple xpr 10w40 race oil heard alot of good things about this oil and thought it was time to give it a go. So ordered up some new filters from toyota ready for the change in a few weeks.
0F885E72-9B57-4F2D-BFAF-B5FB3A6C5C5A_zps
0EC5EF7F-2ABF-4502-9A31-2F858C880BD5_zps
The car is going in for work to have a slight change on setup next week updates to follow
Last week got my delivery of a Tial Blow off valve thanks to mike at tuning developments
7F84C3E7-668C-4694-9D5A-E69D44F131E6_zps
Saturday i set off early to travel up with my brother to RW Developments to drop my car off to Dean. The car is to have some changes to its current set up so left the car with him to carry out works we have been discussing along with a few other bits i wanted doing.
Quick pic at the services and final destination.
DB82EB7C-E475-42C6-B863-7A0BF429A7E6_zps
A24582A5-BAF6-4D24-9F3A-DD65089C6A5E_zps
Hope to have some updates soon
  • 3 weeks later...
Cars still in at RW Developments and will return to me at beginning of September
Small update to whats going on
New cores
31DE5665-38A4-481D-85F1-AB8B7E8AB099_zps
13C866A7-BF37-473F-89F9-A17F7988B2ED_zps
More pics to follow shortly 😊
Beginning of the week a couple of bits turned up from Japan
Cusco carbon brace
B8D48171-C526-43BA-8A20-3960B7B144AB_zps
2F1D2A0E-29F5-42DE-BAAD-9F1E24BACC0A_zps
261FEB79-BDA7-4465-996B-600A64A10C58_zps
AD062611-469E-44EF-AB4B-1D75490D24EE_zps
Also a friend imported me a Recaro SPG bolster protector.
E12A3570-A981-46F9-B3DF-C3690383E15B_zps
Then early this morning this happened i went off to meet stockrod at the m25 juction near mine as hes desided to strip his car and was offered a few bit so took the opportunity to purchase some bits
Another set of JDM wheels to add to the collection Weds sport SA90 15x7
2133B19E-62C9-491F-8F7A-2B93BFC2030F_zps
Mint set of front lights
A3B9671C-8407-476F-BF1E-E9D07E529F21_zps
Spare set of Drive shafts and starter motor and new bonnet catch
CF7FE979-2388-4078-9887-5F90865335FE_zps
Edited by abbott
  • 4 weeks later...
  On 8/21/2016 at 11:46 AM, epcashin said:
love this glanza
where did you buy yhe willwood pads ?
thanks dude
rally design is the best place to get the pads
  On 8/22/2016 at 11:42 AM, jiggaman_16 said:
Custom curved end tanks i assume? Honda SFWD style i hope. Curved end tanks offer the very best flow in my opinion.
yes mate it will be that design should be collection this weekend so should have an update
  On 8/22/2016 at 11:44 AM, TimD said:
Will you be at Croft in this on the 18th?
unfortunately not Tim
  On 8/22/2016 at 2:52 PM, jellybaby said:
Love
Them wheels if u want rid at any point give me a shout :)
lol! I will let you know dude
We'll progress update has come round and collected the car on Friday evening and spent a couple of hours helping Dean Finishing final touches and disussing what's next on the list for him with my car.
Custom back door intercooler
09A30276-D88C-4E21-A3CA-EE76CE096119_zps
24FDE614-46DD-476A-A6CE-4C4335D24327_zps
Custom 2.5" boost pipe with Vband blowoff valve take off and only 3x silicone joiners for whole intercooler.
E5B5A674-074A-4FE9-8B3F-9FC942AC9BE3_zps
D1DEEB20-F01A-4DB9-BE53-2379A85CFAFE_zps
Custom rad with Spal fan
83FC4087-7E35-4794-84F1-40566DF59A79_zps
FE4E7414-EF96-409B-A047-961B0F889FDA_zps
5E4ECFF4-BC28-4F00-8CAE-F16FEC7FE38C_zps
5AA1B447-CB05-4A51-B96C-23401B6976BE_zps
Custom rad bracket too suit
5B840910-C8F6-4929-9B46-EE052EABC626_zps
Custom air filter shroud (phase 2)
(phase 1 will be for sale)
8DA50007-E389-454B-A194-2908D42811B4_zps
C64346D8-758E-4FA6-B903-5AC6963A1ECA_zps
Modified screamer pipe
EFC1593D-D2BD-406C-9958-485D82FE6B2F_zps
Along with all the custom items there were a few other little mods which you will see in the below pictures
* Coolant hose clips replaced with Murray clamps
* Vacum line replaced with an fitting and braided lines
* all new Murray clamps for intercooler hoses
Few pictures of the car going together
CD8B5A0F-20D0-4559-9ECE-FD65EFB97BC0_zps
F17700EE-BF57-4B0B-B49E-C7210421EC77_zps
A468AEA9-2708-4E81-86FB-73ACF7C28FAA_zps
A9A08CD2-7E2E-4962-997A-393B57F48A6C_zps
Drove the car home that night leaving Deans at 2:15am and getting home at 5am. The next morning got up and just wanted to get up to my garage and have a good look in the light and take some pics.
7F713B1C-D073-47FC-A9DF-3F3981536862_zps
C76BAC0B-FA4B-4E64-AEBB-650543AFC9A1_zps
25C019B9-7644-42E3-842B-65AC30F01386_zps
D10D09AC-67F4-492A-9771-501C6400DCF3_zps
E27C51C2-B074-4A25-A269-B4918392E9E9_zps
952EC1E3-82A0-4F3E-80EC-247C591A5BC4_zps
6AA3C7E3-B43F-475A-90FA-7F389E993BDC_zps
More updates to follow in October
