MustakimQZ Posted February 26, 2016 Posted February 26, 2016 Looks like you're the fastest car out there. Brilliant mate Quote
RobSR Posted February 28, 2016 Posted February 28, 2016 Nice stuff - tyres were definitely doing the job! Quote
abbott Posted February 28, 2016 Author Posted February 28, 2016 Looks like you're the fastest car out there. Brilliant mate Was great fun chap and not to sound big headed the only thing to go past me was a friends time attack evo and a ex seat race car more.Nice stuff - tyres were definitely doing the job!Yes would recommend all day long. MORE VIDEOS TO COME Well following my previous post with the car being revovered from brands due to a failure of somthing on my last session which i returned to the pits with a loss of boost, drove flat and a noise coming from the engine.I started off the weekend with giving the car a good clean after the track day.Then pushed it in the garage and jacked the front end up and put it on axle stands. Started by removing the powersteering and alternator belds. Then went on to removing the top cam belt cover which started the story of whats happened.1) part of the lower cover had broken and gone round the cam belt and ended up at the top sitting on the cam belt and melted.2) went on to removing the crank pully and lower cover and revealed even more plastic.3) looking up from the bottom of the car i noticed that the engine mount had come away from the block noticing only one bolt was in there and that just pulled out with my fingers, one bolt snapped in the block and 3rd bolt was not there. Pulled the mount out and left with a snapped stud in the block.4) because the engine starts up fine at brands but was flat and had a noise thought we would check the timing once its was in the position it clearlly showed the the belt had jumped 2 teeth which explains the loss of boost and engine feeling flat. So retimed, started up and bang on issue solved. New cam belt required but going to do a whole kit with tennsions.looking close at the mount the noise came from where it dropped on to the bottom belt cover which then broke and went round the cam belt and the mount ended up sitting on the tennsionor pully which caused rubbing.A good friend helped me out today and removed the snapped stud out the block which is a bit of a life saver as was thinking i may need to drop the engine out and drill the stuff out. Gave it a brake cleaner up and removed the cam belt kit ready for the new to be installed once orded. Quote
Charlie28 Posted February 28, 2016 Posted February 28, 2016 Glad it wasn't anything major bud! Car looks the nuts on track! Quote
abbott Posted February 28, 2016 Author Posted February 28, 2016 Glad it wasn't anything major bud! Car looks the nuts on track! yes I feel a little relieved and glad its not a bad fix. thanks chap will get some more videos up shortly Quote
RobSR Posted February 28, 2016 Posted February 28, 2016 Blimely, that could of ended a lot worse! Get the thread lock on there next time Quote
MustakimQZ Posted February 29, 2016 Posted February 29, 2016 Lucky you mate! Could have definitely been worse. By the way how did you get the snapped stud out? Quote
abbott Posted April 16, 2016 Author Posted April 16, 2016 Blimely, that could of ended a lot worse! Get the thread lock on there next time Yes mate very thankfull. Defently lock tighting those buggers inLucky you mate! Could have definitely been worse. By the way how did you get the snapped stud out?Yes mate for sure. Manage to tap it out with a flat head tap took 30minutes and was a releafe not to remove engine Got a new cam belt kit, bottom belt cover and got a new mount. Got the car back together and locked tight the mount bolts in so hope that will be prevent it happening again as the car has been through a lot of strain with track days. Following getting it all back together and everything running fine i booked the car in with rob to do its yealy leak down/compression check which was the following week and results were good and better than last year. Since then the car is back in the garage waiting for the next outing which will be soon i hope .Just a little update as to where the project will be going next and let the pics do the talking with a couple bits ive collected and will update as and when it happens.Updates to follow soon Quote
abbott Posted July 24, 2016 Author Posted July 24, 2016 Not alot to update on as the car has hardley been used since feb after the engine mount failureThe ep82 track car shell went off to a good friend which is now in the process of having a full weld in cage.On from that i ordered some new brake pads front and rear as there due for a change shortly.Another reason why i have not had much time is due to being apart of my friends time attack team supporting him this season. The 3rd round at brands hatch Time Attack i took the starlet for a drive down for the day couple of snaps where taken.A friend of mine from the starlet days years ago Rikko got in contact through ebay as he had some interesting things for sale while he was back from work abroad. So popped up for a catch up and took a couple of things off his hands which he had for sale.Route 6 clutch slave cylinder never used just left in its box juat need to give it a little clean.5efhe bottom end Not sure what the plans are with it just a opportunity to purchase this and leave it on the shelf maybe mmmmmm!The glanza is coming up for a oil change shortley so spoke to wardy who kindly sorted me out some royal purple xpr 10w40 race oil heard alot of good things about this oil and thought it was time to give it a go. So ordered up some new filters from toyota ready for the change in a few weeks.The car is going in for work to have a slight change on setup next week updates to follow Quote
abbott Posted August 3, 2016 Author Posted August 3, 2016 Last week got my delivery of a Tial Blow off valve thanks to mike at tuning developmentsSaturday i set off early to travel up with my brother to RW Developments to drop my car off to Dean. The car is to have some changes to its current set up so left the car with him to carry out works we have been discussing along with a few other bits i wanted doing. Quick pic at the services and final destination.Hope to have some updates soon Quote
abbott Posted August 21, 2016 Author Posted August 21, 2016 (edited) Cars still in at RW Developments and will return to me at beginning of SeptemberSmall update to whats going on New coresMore pics to follow shortly 😊Beginning of the week a couple of bits turned up from JapanCusco carbon braceAlso a friend imported me a Recaro SPG bolster protector.Then early this morning this happened i went off to meet stockrod at the m25 juction near mine as hes desided to strip his car and was offered a few bit so took the opportunity to purchase some bitsAnother set of JDM wheels to add to the collection Weds sport SA90 15x7Mint set of front lightsSpare set of Drive shafts and starter motor and new bonnet catch Edited August 22, 2016 by abbott Quote
epcashin Posted August 21, 2016 Posted August 21, 2016 love this glanzawhere did you buy yhe willwood pads ? Quote
jiggaman_16 Posted August 22, 2016 Posted August 22, 2016 Custom curved end tanks i assume? Honda SFWD style i hope. Curved end tanks offer the very best flow in my opinion. Quote
jellybaby Posted August 22, 2016 Posted August 22, 2016 LoveThem wheels if u want rid at any point give me a shout Quote
abbott Posted September 13, 2016 Author Posted September 13, 2016 love this glanzawhere did you buy yhe willwood pads ? thanks duderally design is the best place to get the pads Custom curved end tanks i assume? Honda SFWD style i hope. Curved end tanks offer the very best flow in my opinion. yes mate it will be that design should be collection this weekend so should have an update Will you be at Croft in this on the 18th? unfortunately not Tim LoveThem wheels if u want rid at any point give me a shout lol! I will let you know dude Quote
abbott Posted September 26, 2016 Author Posted September 26, 2016 We'll progress update has come round and collected the car on Friday evening and spent a couple of hours helping Dean Finishing final touches and disussing what's next on the list for him with my car.Custom back door intercoolerCustom 2.5" boost pipe with Vband blowoff valve take off and only 3x silicone joiners for whole intercooler.Custom rad with Spal fanCustom rad bracket too suitCustom air filter shroud (phase 2) (phase 1 will be for sale)Modified screamer pipeAlong with all the custom items there were a few other little mods which you will see in the below pictures* Coolant hose clips replaced with Murray clamps* Vacum line replaced with an fitting and braided lines* all new Murray clamps for intercooler hoses Few pictures of the car going together Drove the car home that night leaving Deans at 2:15am and getting home at 5am. The next morning got up and just wanted to get up to my garage and have a good look in the light and take some pics.More updates to follow in October Quote
RobSR Posted September 26, 2016 Posted September 26, 2016 Awesome work by all. Who did the crackle black on the catch can / head cover by the way mate? Quote
00joeindastarb0 Posted September 26, 2016 Posted September 26, 2016 Amazing work! as always mate Quote
Phil Posted September 27, 2016 Posted September 27, 2016 Fantastic Abbott Always enjoy the updates Phil Quote
SiCaln Posted September 30, 2016 Posted September 30, 2016 Were those SA90s my old ones? Looking awesome dude Quote
