Clinternational Posted September 18, 2012 Posted September 18, 2012 (edited) Hi there all, im also from the netherlands 26 years old. Being here an member for a long time I bought an ep70 last year because some maniac with a big american car drove into my door while driving in reverse. So his bumper bounced into my door. And my ep81 was busted/wrecked at 10/20mph lolSPECSHad the engine 2E-E tuned up with TRD parts, engine had only run 60.000 milesHead revision.Head ported flowed and polished.New waterpump & timing belt & pulleyTRD Camshaft 280 DegreeTRD Cam pulleyTRD Valve springs.TRD Head gasket 0.6mmPaseo JDM Pink 172cc injectors ( Ultra sonic cleaned )Unknown exhaust manifold from steel 4 - 1. wrapped in thermotec isolation.Flywheel was machined down to 4.7 kilo'sNew clutch OemNew pressure plate also OemCustom choke controle2 Inch exhaust from header to rear with home made open mufflers. also an nissan custom throttle body between as exhaust volume controller.Nitrious Oxide System WET15 BAR / 217 PSI Water injection.Range Rover Air filter unit.Tripple core king size cooler / radiatorBosch Wideband AEMOil temperature meter.Mocal oil adaptor plate.Oil coolerCustom piggyback overide function. Stationair, Economical and race/nos function. All controllable with potentiometers.Disabled the manifold/throttle body heater ( how can you get a cold air intake with manifold/throttle body heater on )ONDER THE CARTRD Front and Rear bushingsWhiteline antilift/castorCusco pillowball ( spherical bearing ) panhard rodOem springs rearLowered Springs in front 50mmStrut bar Custom front with brake master cilinder stopperCustom rear strutbar.Rear ep82 discs conversionCustom goodridge brake lines.Custom front brakes. Camry V6 / GT4 60mm piston calipers with camry brackets, ferodo ds2500 brake pads, Toyota Prius 4 x 100 Drilled brake discs 25mm thick and 255mm. Want to keep my 14 inch wheels.25mm Brake master cilinder ( stock 19mm )Whiteline Front lower arm bar.22mm Whiteline swaybar front19mm Whiteline swaybar rearCusco Camber plates.EXTERIEURGTT turbo wing + tailgate + lights3 x window tinted.A whole lot of shizzle.2 x Groundzero amplifiers Uranium and nuclear series4 x Groundzero Nuclear kickbass in the door.2 x Groundzero Uranium kickbass in the rear panel2 x Visaton tweeters 12db1 x Hifonics bandpass subwoofer1 x yellowtop optima + PowercapDiffrent nozzlesShot at 2012-09-18Shot at 2012-09-18Shot at 2012-09-18Shot at 2012-09-18Shot at 2012-09-18Shot at 2012-09-18Shot at 2012-09-18Shot at 2012-09-18Shot at 2012-09-18Shot at 2012-09-18Shot at 2012-09-18Shot at 2012-02-25I did weight the car at the scrapyard. It weight 900 kilo's 1984 LBSAnd it had an camco alarm systemCar gone end of story for now.Friend of mine came to pick up the rest, what's left of it.Did get 40 quid for a emty chassie.NEW Story but going furtherI bought an 1986 ep70 with an 1E engine for 500 quid. Kinda rusty chassis. But tax free driving lolThe car looks boring!Shot at 2012-02-25Shot at 2012-02-25This must be transfert only the rear swaybar and brake units. Trailer arms are to long.The TRD bushings that are insert into these are stil in. The axle is laying in the old iron garbageShot at 2012-02-25Front brakes have to go on the ep70 aswelShot at 2012-02-25Empting the carShot at 2012-02-27Welding the car to reinforcing the chassisShot at 2012-03-03Shot at 2012-03-04Extra strutbar from SSShot at 2012-03-05It's quite difficult welding those overlaps. Because the are alway's leftovers from glue kit paint and it smells very bad heating those up.Shot at 2012-03-05Trying to clean it. So it welds betterShot at 2012-03-05Coating the weldsShot at 2012-03-05Little rustShot at 2012-03-05Had to buy some anti rust i think more then 3 cans or so, and coating for the weldsShot at 2012-03-06This does heatwrap in 3 years lol. The exhaust pipe also shows a little rust :SI bought it new 3 years ago but ehm!!Shot at 2012-03-06Shot at 2012-03-06I aint going to tow someone so no need for those. Weldings did burn in quite wellShot at 2012-03-12Looks like new my dad did use correless on a celica from 1974 the headlights on the car had alot of rust. 9 years later he looked again and they look just the same way as when he painted them with correless, So i trust this product.Shot at 2012-03-12Again hole in the floor. kinda rustyShot at 2012-03-16Allready fixed this.Shot at 2012-03-16Again more rustShot at 2012-03-16Shot at 2012-03-16Shot at 2012-03-16Shot at 2012-03-16Shot at 2012-03-17Shot at 2012-03-17New piece cuttingShot at 2012-03-17Shot at 2012-03-17Again more welding to reinforcingShot at 2012-03-22More welding ( inside outside )After welding kitting the welds, All rust and paint removed, Then painting with correless then spraying 1 liter motip stone chips in each side.Then 3 layers of motip Bitummen undercoating each sideBracket for the Role cage and also here welding it further and further until under dash.Shot at 2012-04-20Shot at 2012-04-20After that i loved my ep81 dash so much i added it into my ep70Shot at 2012-04-20Custom brace, piece of pipe with nuts welded into them.Shot at 2012-04-21I removed All the wiring. The only wiring is the loom to the back of the car. I added a few more wires to it for LPG, Heating for the nos bottle, Rear trunk opener througout an button on dash. Sensor for alarm. Remote cable for EFI fuel pump. and few loose wires.Shot at 2012-04-20The shift stick is shorter than stock so the swing is shorter. Plastic unit out of the p8 saves weight, Shot at 2012-04-21Very cute a ep82 dash into a ep70. Nothing is the same lol. Making some new airducts lolShot at 2012-04-24Shot at 2012-04-24Shot at 2012-04-24Shot at 2012-04-24Shot at 2012-04-24Shot at 2012-04-24Shot at 2012-04-24Shot at 2012-04-24Shot at 2012-04-24Shot at 2012-04-24Shot at 2012-04-24Shot at 2012-04-24Shot at 2012-04-24Shot at 2012-04-26Shot at 2012-04-26All the vents works expect the middle ones. Front window must be cleared with the blower as for the MOT / APK. The other ones are extra option for the winter.Spraying my carpet black again. Instead of grey.Shot at 2012-04-20Mounting the Aluminium wiechers RolcageShot at 2012-04-24Shot at 2012-04-24Shot at 2012-04-26Shot at 2012-04-26Alarm function open trunk I used an Oem door switch as they are beter then those cheap ass iron stuff that rust very fast.Shot at 2012-04-27Shot at 2012-04-27Did wanted power windows for my ep70 and engine bay openers ( shocks )Electric Trunk opener.Shot at 2012-05-01Shot at 2012-05-01Simpel doorlockingShot at 2012-05-01Shot at 2012-05-04Shot at 2012-05-04Shot at 2012-05-04Shot at 2012-05-04Shot at 2012-05-04Shot at 2012-05-04Batterij in the back yellowtopShot at 2012-05-04 Edited July 28, 2014 by Clinternational Quote
Clinternational Posted September 18, 2012 Author Posted September 18, 2012 (edited) rest follows cant upload to much pictures Edited September 18, 2012 by Clinternational Quote
SiCaln Posted September 19, 2012 Posted September 19, 2012 very cool stuff so far, very impressed Quote
Clinternational Posted September 19, 2012 Author Posted September 19, 2012 placed the battery in the rear for weight & space in the engine bay, The alarm camco systems RS850 is also beeing installed because of the Central door locking Remote trunk opener, Function knowing how hot it is in the car, starting the car remote, and with timer, anti jack function bla bla bla.Expanding the rolcage, i like safteyShot at 2012-05-08Shot at 2012-05-14Shot at 2012-05-14Cross behind the seats Shot at 2012-05-28I've learned that if the american car has driven faster, i'd be having him on my laps. So fixing this isueShot at 2012-05-28Again more and more rust, Treathed with FERTAN turns rust into steel ? don't know if that's true Shot at 2012-05-28Shot at 2012-05-28Mounting the ep82 GTT brake discs on the rearShot at 2012-05-28The handbrake cables are slightly longer because of the diffrents on the trailer arms. ep82 is longer vs ep70Shot at 2012-05-28All done, There are a few mods needed here but no real problems, New seals used new grease.I've noticed that the diffrents between disc and drums are. Drums are good on low speed driving.Discs on the rear slows the car on higher speed much better then drums.Shot at 2012-06-01New brake fluid into the 25mm Brake master cilinder. Shot at 2012-07-29Building an EFI fuel pomp into my ep70 tank. Finding the lowest place, Got an plastic can and dropped it into the tank.Otherwise if you turn hard enough in a corner when driving, The fuel will draw away from its filter and there will be no gasoline to pump, Therefore the plastic can in the tank. And the fuel pomp & filter in the can This is a p9 pump holder and fuel pipe with banjo, Welding it into the p70 fuel plate.Shot at 2012-06-01Finding the fuel lines from the tank and do something with it. From pump to engine bay 10mm (3/8) fuel line.Shot at 2012-06-01In the mean while i change the fuel pump to an jap spec supra pump.Shot at 2012-06-19Shot at 2012-06-01I also drilled out the banjo bolts. they were 6mm lol. now 9mmShot at 2012-07-29Fitting it back in the tank. Did cut a hole with a iron scissor but i need to figure something out to cover the huge hole.Shot at 2012-05-28Removing the old engine, 1E engineShot at 2012-06-05Dirty engine bayShot at 2012-06-05CleanShot at 2012-06-05Shot at 2012-06-05Shot at 2012-06-05Had a leaking clutch master cilinderShot at 2012-06-05Removing the complete suspension and restShot at 2012-06-07Lots of old iron.Shot at 2012-06-07This has to be welded aswel. making an drawingShot at 2012-06-07Shot at 2012-06-07Everything where you see brown there has been welded the overlapsShot at 2012-06-19This engine mount has a little error. fabrication fault ? This mount did not line op straightShot at 2012-06-19EP82 Clutch master cilinderShot at 2012-07-29New rubbers and new grease.Shot at 2012-06-19Spraying the engine bay. The car is going to be an maserati antraciet metallic MATT colour. With an Matt varnish.Shot at 2012-07-29Removing the old worn bush from the trailer armShot at 2012-07-29No rubber or polyurethane bushing. Steel onlyShot at 2012-08-10Shot at 2012-08-10Shot at 2012-08-10Shot at 2012-08-10Shot at 2012-08-10Shot at 2012-08-10Fitting whiteline rear swaybar & Cusco latterol rod. Coated this with linnen and then sprayed it 4 times with a varnish clear coat.Shot at 2012-08-10Custom coiloverShot at 2012-07-29Spraying the hood on the other sideShot at 2012-08-10This thing you use at home where your light bulb is centered.Shot at 2012-08-10Custom air induct intake Shot at 2012-08-13Spherical bearing for the wisebone Shot at 2012-07-29Shot at 2012-07-29Shot at 2012-07-29Castor has been improved over the whiteline antilift/caster unit. A higher castor improves overal neg.camber at turning in the corners.. Think of mercedes or bmw.Shot at 2012-07-29Fitting bmw Hood shocksShot at 2012-08-10Doors sprayed from the inside. Shot at 2012-08-13 Quote
Clinternational Posted September 19, 2012 Author Posted September 19, 2012 Working power window on my ep70/>http://youtu.be/e6QVfGeP0lMEcu mod with another crystal. 8000 RPM but useless as the timing is incorrect./>http://youtu.be/hPJIglzYlwoPulling up. Few years ago. with my EP82 car weighted 1970lbs Did race against an seat ibiza cupra R with 2.0 liter 16 valve and weight 2400 pounds. It was een draw ( not shown on movie. ) Later when i installed NOS 35bhp nozzle. I got wheelspin in 1st gear until 4th gear with 14 inch rim tyre 185/50/14 tire.The other time i used NOS my clutch slipped it was new so where the pressure plate.. It turned blue So i've bought TRD 212mm clutch and TRD pressure plate. So in an need for an 4efte flywheel. Also im working on an Custom supercharger! With an Garret AR70 Housing. 61mm inducer. 82mm exducer.But i have to lower my compression, Did an compression test and every cilinder had about the 13 bar (188 psi ) of pressure, Stock is 9.5 bar. ( 137 psi )/>http://youtu.be/GXYYBph-zkwabout 8 seconds to 60mph my mr2 3SGE did the same lol Quote
SiCaln Posted September 20, 2012 Posted September 20, 2012 some awesome work here, very impressed, wont the bushes be a bit severe though? Quote
Taggy Posted September 20, 2012 Posted September 20, 2012 Cracking work and welcome to the EP70 club Good to see someone taking a different approch to my ep70 conversion, i like it Quote
Clinternational Posted September 20, 2012 Author Posted September 20, 2012 Thanks for the reply's, SiCaln: Thanks Those bushing are indeed rock solid, I don't have a clue how the comfort will be haha. That's why i choose custom coilovers for the front. Spring rate has to be kept low for comfort, also an oem shock is needed for this.Front springs are 200LBS and 8 inch long. I also got 300lbs laying arround. But when an swaybar is also added, spring rate will change because the swaybar forces the wisebone to go down because of its tension. Still got 1 TRD rubber in both wisebone On the rear i also used oem fixed springs and shocks, Don't like a bumpy ride because most aftermarket coilover kits are about 4 / 6 kgf. I will drive this car on public road so i really wanna know how the car handles. Taggy: Thanks , I like to change everything hihi. I always got new ideas. Really would like to know how strong the 2E-E engine is . also means it can be blown haha. But then i'll move on the my other engine ideaToo high i asume ?Fixed3 plates, Left EP9 middle TRD EP82 Right EP70I choosed the left one it's flatt, The other ones are higher. almost 1 inch diffrentLeft spring EP9 Right spring EP70 No diffrent in here, Only the rust and construction year.Going to get this cooler shorter to fit the EP70 in the future. Handmade in the UK All lock/key holes, window wiper hole, are closed they've been welded, doors also. Quote
turbo Grant Posted October 9, 2012 Posted October 9, 2012 A lot of work gone into this. Going to be a minter Quote
Clinternational Posted March 27, 2013 Author Posted March 27, 2013 Back again, had some weird problems getting on the forum. Do not know why! kinda strange. Tried it with IE and Chrome and firefox but non worked. Thanks for the reply's Tailgate in the primer New carpet more primer Playing with pipes. Yeej got an 4efte flywheel from somebody here @ forum. Thanks! ( rare here in NL ) As my other flywheel was 4.7 kilo machined down.Ii left this one at stock weight. Duo to the loss of RPMAs i shift the car, it came under its powerband. Instead of making the car more revvier&faster it became out slower lol. So it had only disadvantages. As it was extremly nervous. 212mm flywheel mounted & TRD clutch and TRD pressure plate as the oem clutch was only burning up Flex exhaust piece ( reinforced ) Having some trouble fitting the 2E-E engine duo to a fail engine bracket. Its not straight.Solved the problem by receiving another engine bracket the one in the tunnel. And for the offset a cast one off an 1E engine. for the timingbelt side. Some new oil that loves high RPM The hotter the oil, the easier to shift. Welding the flex ss piece between the pipes Making my own silencer again from SS, drilling more then 400 holes. Kinda idiot Welding an AEM uego bung/nut onto the exhaust pipe. Some thermotec wrapping Look at the holes pffff darn that did take some time All SS so last forever i asume. Complete exhaust with T piece mounted. For exhaust gas valve Exhaust onder the car, There is a steel simons silencer added & Volkswagen Golf 3 end silencer fitted. Normally there aint space for a regular silencer i created some space for this.Banging with an hamer Vacuum controlled exhaust valve, At wide open intake throttle the exhaust valve is also wide open. And the exhaust gasses makes a shortcut. Is controllable the hose that's controlles the actuator can be set on/off with a ball valve. Exhaust tip. 1/8npt into mocal oil sandwichplate Some extraordinary oil coolingdevice with special clamps Home made display holder. Display's measure Oil en water temp digital. New spark plugs from japan. BPR 7EY 2 degree colder, and adjusted the gap from 0.8 to 0.4. ( engine runs much better especially at low RPM, respons is quicker! ) Custom underbrace. ( lowerarm bar) Weld it when it was under the car with an 360degree disc so both sides got the same degree. Custom top brace. Wiper arms were very ugly and rusted. Cleaned them, spray into 2 layers anti-roest, and then 6 layers of sprayputty then 3 layers matt black Fixed the headlights, duo to damaged chrom layer, MOT = wrong light reflection. New layer + some extra wool on my door and rear panels Other color for the turn signal in the bumper Car in the primer Coated the thingy with sky leather. Coated the other thingy into matt Modified the grill Plug and play, had 3 bags. total 15 male and 15 female. Used them almost all. Elektric window plugs Sky leather on the door Switch out of UK mounted into the thingy Coated the bottom with this kit pistol on air Door panel lights Some party leds Mounted the brace for the oil catch can. Extra leds Fan was going to die, weird noises! Had an renault twingo fan laying arround. Golf 3 wing cut in 2 pieces for fitting on my starlet Made a new brace for my battery Winding copper Fitting the copper into this pipe, Coolermaster aero 7 of my old computer. This one blows very hard, and cools the water running thru it. For my water injection More to come! Quote
_shaun_ Posted March 27, 2013 Posted March 27, 2013 epic work so much respect for people who can just fabricate any parts they want/need Quote
Clinternational Posted April 7, 2013 Author Posted April 7, 2013 Thanks you all for the replys. The car needs a colour, 1 window needs film, 2 other seats, they are granma hight and looking for an turbo right know.Want to archive 200HP out of a stock 2E-E engine.Waterinjection will help me to get rid of detonation and heat!.Don't wanna try NOS then when the turbo is mounted hihi. What i remember is, that my engine is still alive after nos. +- 35hp gain. So im mounting an turbo to get always 35hp gain. The engine can be blown but i don't care for that. Ending up with an hole in the piston, or broken crank, rods,The pistons won't melt i hope. Engine had only +- 60.000 miles so it's fresh i quess any of you have a 4efte map sensor laying arround ??And or an budget turbo ? Quote
Clinternational Posted June 1, 2013 Author Posted June 1, 2013 Well time for an update. And thanks for the response Water injector nozzle. Hot rust spot. Removed all the rust and coated it, then add a new clip for the window frame. Door cardridge complete I needed to fix the chrome in my headlight and added an led strip into it. The cornerlights glow and also blink for direction. As my previous experiance was that the rubber seal from the central door locking motor easily breaks. Then it's able for water to get between it and malfunction the motor and unlocking. Also with cold weather it freezes. So fixed this. Want to keep my door panels in good order, if they get wet they mold, . plastic bag was too much work. As this is easier. Wiper and stuff Kill switch. to activate another batterie. Because all key locking has been removed.If the primairy batterie fails during winter or something else, i can activate the secondary batterie. Some wiring. With easy terminals There is coming another fire extinguisher on the other side, And first aid kit. Car Going change the plates to another location. It's really ugly yellow plates.Still need tint the rear window. Quote
Clinternational Posted October 14, 2013 Author Posted October 14, 2013 Going to upload more pictures tomorrow!!!!!!! Quote
garrygt Posted October 15, 2013 Posted October 15, 2013 All i can say is wow.....what an amount of work. Great build mate will be keeping an eye on this. Quote
Clinternational Posted October 16, 2013 Author Posted October 16, 2013 Jeej almost done. laptop batterie emty lol all gone!!!!!!!!!!!!!!! here we go again. Ready to run, Had to get some parts at the scrapyard. And saw this, Looool Paste A microswitch to the intake housing. And welded a little ball to it so it can activate the switch. This is for my 3 way piggyback system.. Econemy mode. Race mode, And with NOS function. Had some MOT/APK failure duo to high emission 5% is a little bit high it has to be 1 %Problem was 2 leaking injectors. So the oem 155CC are fitted instead of the 172CC New waterinjector nozzle bought. BETE PJ10 Finest with less then 50 Microns. Got some Tee pieces for NOS bottle heater. 2 6mm hoses will go into the car en winded with copper arround the bottle. And temperature controllers for the water injection. Fitted new tyres @t my brothers garage. Can do alot hereToyo proxis CF1 185 65 14. a little bit high, but comfor is also nice.Old yokohama's A series 185 50 14 went to the front of the car. Hose for the bottle heater. And T3 Turbo AR 42, needs rebuild. Anybody got some parts left over ?????????????? Housing looks good, maby some polishing ? Turbine housing also looks good. ( only wastegate is missing outlet exhaust side ) external ? Turbine side little busted Turbo had piston ring problems. Some idiot tried to get it loose with the wrong tool. Backplate scrap Bearing house is E okay Bought the turbo for 8 quid, lol More will come. hope my laptop stays on. Quote
