whitestar Posted September 29, 2012 Posted September 29, 2012 There's the question. I have a fujitsubo power getter cat back, apexi power flow intake and JAM ecu so no fuel cut on the way...Just worried about the restricted mani, so how much boost can I run?Cheers! Quote
akyakapotter Posted September 29, 2012 Posted September 29, 2012 port it bud will be fine for 1bar with supporting mods Quote
Simon Posted September 29, 2012 Posted September 29, 2012 Have you still got your catalitic converter fiited?Swapping this for a good de-cat (blitz is the best) would free the turbo up a lot more and you will find you will already see the boost rise as the turbo would not have to work so hard. I would do this before swapping the manifold or turning the boost up. If you cannot run without a cat in Finland there has been a SARD sports cat on the yahoo auction if you have deep pockets. Quote
whitestar Posted September 29, 2012 Author Posted September 29, 2012 Thanks for a quick reply guys! Yeah been thinking of porting the oem one....Just have to ask prices first. I'd still like to keep it on the streets for 1-2 months before putting it away for the winter, so taking the mani off now doesn't seem like an option. I still have the cat in it's place and I'd gladly take a blitz decat if I could find one, but again I might go td04 next year so don't really want to spend too much money on ct9 mani and/or decat.That's why I was asking how much could I turn the boost up without damaging the engine. Quote
Simon Posted September 29, 2012 Posted September 29, 2012 Heat build up is the main issue, the CT9 just turns into a heat pump after turning the boost up to anymore than 1.1 bar. That's what i found on the rollers with my first Glanza. As the cat restricts the turbo if will be having to work much harder to produce 1 bar of boost with it in causing more heat. If it were me i wouldn't turn the boost up much above stock. Quote
whitestar Posted September 29, 2012 Author Posted September 29, 2012 Yeah, been thinking something like 0.8. Would that be safe? Quote
wssoR Posted September 29, 2012 Posted September 29, 2012 Keep it at .6 until you've got a descent mani and decat, it's not worth the risk Quote
whitestar Posted September 29, 2012 Author Posted September 29, 2012 Ok mate, maybe that's better. Cheers to you all! Quote
A L 3 X Posted September 29, 2012 Posted September 29, 2012 As above, even with ported Mani I turned mine down to 0.6 till I got a wepr kit as I was unsure about running more Quote
Max9650 Posted October 17, 2012 Posted October 17, 2012 What's the worst that can happen if u run too much boost on standard mani? It will just melt? Any damage? My starlet is 0.8 on a standard mani since I've had it.. Over a year, maybe it's been ported? Quote
ste91 Posted October 17, 2012 Posted October 17, 2012 Too much boost on standard manifold and you can kiss goodbye to piston #3.I think that was it anyway, I've been away from the Starlet scene for a bit. Quote
pick1 Posted October 17, 2012 Posted October 17, 2012 What's the worst that can happen if u run too much boost on standard mani? It will just melt? Any damage? My starlet is 0.8 on a standard mani since I've had it.. Over a year, maybe it's been ported?It's all chance mate depends how much u trust your engine I ran mine at 1.8 bar for years with standard mani and mine still going strong and now running tdo4 at a bar Quote
Broony Posted October 18, 2012 Posted October 18, 2012 Manifolds don't kill engines!! boost does!! there is a lot of miss-information here!! Quote
DavidAshton Posted October 18, 2012 Posted October 18, 2012 Manifolds don't kill engines!! boost does!! there is a lot of miss-information here!!Wrong, the restriction in the third runner causes too much heat build up and kills piston 3. 0.8 bar is the trusted boost level on a stock manifold. 1 bar has seen piston 3 melt on plenty of engines due to increased heat build up at 1 bar. Quote
Broony Posted October 18, 2012 Posted October 18, 2012 Wrong, the restriction in the third runner causes too much heat build up and kills piston 3. 0.8 bar is the trusted boost level on a stock manifold. 1 bar has seen piston 3 melt on plenty of engines due to increased heat build up at 1 bar.Worng i think not! you backed up my reply with your answer i simply stated its not the manifold that kills your engine am i right?? Its boost that does again you stated that in your answer. Quote
TrisK Posted October 18, 2012 Posted October 18, 2012 Worng i think not! you backed up my reply with your answer i simply stated its not the manifold that kills your engine am i right?? Its boost that does again you stated that in your answer.No because 1 bar on say a WEPR manifold is less likely to melt piston 3where as 1 bar on a standard manifold is likely Quote
DavidAshton Posted October 18, 2012 Posted October 18, 2012 (edited) Its the heat build up caused by the manifold that kills the engine, but ii suppose the heat wouldn't be there if you didnt increase the boost so we are both correct.Long story short dont run a bar on a stock manifold! Edited October 18, 2012 by DavidAshton Quote
Broony Posted October 18, 2012 Posted October 18, 2012 (edited) ^^ I wasnt doubting thatYup agreed just becareful boys ;) Edited October 18, 2012 by Broony Quote
lukEp Posted October 18, 2012 Posted October 18, 2012 I've got a external waste gate/screamer Zisco mani for sale. Quote
Bluebear Posted October 18, 2012 Posted October 18, 2012 I've got a external waste gate/screamer Zisco mani for sale.....Oh aye? Tell me more. Quote
Amjad Posted October 18, 2012 Posted October 18, 2012 Port it well and it should be fine at 1 bar Quote
pig666eon Posted October 18, 2012 Posted October 18, 2012 (edited) there is restrictions in clyinder 2 and 3, the 3rd being more restrictive, if you dont take them out then you will get a build up of pressure on the cylinder rings and they will wear out along with cracking the manifold, if you port it then both the above should be heavily reducedremoving both and giving the others a good porting then it will be fine to run as much boost out of that ct9 as you want, in most cases the ported mani will spool up quicker because of the shorter runnersthe jam ct9 manifold was a replica of the oem one just ported, it also blocked out passage between 1/4 and 2/3 to stop any pressure going back into the other runners Edited October 18, 2012 by pig666eon Quote
