EP91_STARLET Posted December 30, 2012 Share Posted December 30, 2012 what performance modifications can be made to the starlet SR ep91 4E-FE engine? example: what cams, ect would fit? any advice is great, thanks Quote Link to post Share on other sites
ryan lang Posted December 30, 2012 Share Posted December 30, 2012 Engine:5EFHE cams (not 5EFE)Lightened pulley setsHead skim for compressionPorted headValve springs (there are some uprated valves springs for 4EFTE that can be used in the 4EFE. Eg: speedvision, cruise)Exhaust:4-2-1 corolla bugeye exhaust manifoldOBX racing 5e manifoldHotshots 4e manifold (rocking horse shit, hens teeth etc)Custom mani back exhaust (or cat-back)HeatwrapFuelling:Corolla bug eye injectors (beige/brown in color)Fuel Pressure Regulator (to help with map)After market Uprated Ignition leadsSpark plugs NGK heat range 6 or 7)Could go coilpacks if going nuts but probably not needed)Inlet:Corolla bug eye inlet (tubular manifold)4efte inlet manifold4efte Throttle BodyCooling:Civic alloy dual/triple core radiator (personal preference on core)Air filter (apexi is tried and tested, but whatever you can afford)Low temp thermostatDrive train: Lightened flywheels (various after market ones available)If you go for an off the shelf flywheel, you may need to buy the equivalent FTE clutch kit because the n/a lightened flywheels are really hard to come byCorolla G6r 6 speed gearbox (requires shifter unit and cable mount brackets, possibly the actual selector cables) i may be wrong but its do-ableLightened and balanced crank (if your going all out why not. should get the clutch and flywheel balanced at the same time as the crank)LSD (they are available for the n/a 5 speed but rare. same as the 6speed. best off buying a glanza box and lsd if you dont go 6speedManagement:Best way to go is aftermarket ecu, Emanage, Motec, Megasquirt etc (key modification to get the best out of these mods, if your going this crazy)THEN to control all the gained power (probably only around 30bhp if your lucky)Brakes:Levin Twinpot callipers and corolla d4d discs (unsure if they are the correct discs, but there are enough people on here runnign sets to find out)Celica st205 Twinpots (think they are the same as the levin twinpots)Celica st185 big pot calliper (unsure on discs but will refer back to this when i do)GT/Glanza carriers and disc'sThen there are the bigger aftermarket kits like wms, k-sport willwood etc. (bit overkill but if you like flashy then go for it)Suspension/Chassis:Whiteline adjustable rear anti-roll barFront and rear strut bracesCoilovers (dont go lowering springs if your buying for performance)I found the c-pillar bar helped aswellAnti lift kitUprated front anti-roll barPolybush engine mountsAny other various strengthening barsThe biggest difference maker is weight saving. so what ever you dont need, get gone (rear seats, right through to smaller batteries and taking a dump before travelling etc)AND MOST OF ALL: keep it serviced and looked after!I hope this has helped you, if i can think of anything else ill add to this list Ryan Quote Link to post Share on other sites
daniel_g Posted December 31, 2012 Share Posted December 31, 2012 Oooft, thats a fair amount available mods there ^ Shame nobody goes to that extent though. Would actually love to buy a JDM N/A ep82 and go all out. Almost bought that soliel (< spelling) that was for sale awhile back. Kicking myself now, he only wanted 300 quid for it. Quote Link to post Share on other sites
ryan lang Posted December 31, 2012 Share Posted December 31, 2012 same mate i did alot of the above, but ran out of jobs to pay for it so had to sell it all on i did have a bought/fitted and to buy list in my build thread, but its gone for some reason :s lolbut above covers most of it Quote Link to post Share on other sites
ro55ifumi Posted December 31, 2012 Share Posted December 31, 2012 (edited) If it's an NA then just do the handling mods, you will have to spend a fortune to gain 30bhp and unless set up by a tuner you will more than likely run less power!!!The NA's that have been done on here have not seen massive gains at RR days but the owners have been disappointed ;)Wait and save a couple of years then buy a Turbo!!John Edited December 31, 2012 by ro55ifumi Quote Link to post Share on other sites
ryan lang Posted December 31, 2012 Share Posted December 31, 2012 i was disappointed because we couldnt get it back on the dyno after sorting the flooding issue from the fpr Quote Link to post Share on other sites
Amjad Posted December 31, 2012 Share Posted December 31, 2012 Nice list there Ryan!I'd back up what John's said, just make it handle! With engine performance a K&N panel filter, Corolla/FTE inlet, and maybe cat-back is where I'd leave it!For braking, GT/Glanza Carriers and discs are a sufficient upgrade for the 4efes Quote Link to post Share on other sites
H_D Posted December 31, 2012 Share Posted December 31, 2012 stick an FTE in the sr.could be done for less than £1000 Quote Link to post Share on other sites
Jack-CTR Posted December 31, 2012 Share Posted December 31, 2012 http://www.ukstarletowners.com/index.php?showtopic=8661&st=135#could always go down this route Quote Link to post Share on other sites
Xpect Posted December 31, 2012 Share Posted December 31, 2012 With pulleys, headwork, tubular intake together with the stock tb widened to 50mm, Obex 4-2-1 Exhaust, Green Twister Filter and cold air induction, Glanza S Fuelrail and Emanage "motion" made like 115bhp. Quote Link to post Share on other sites
EP91_STARLET Posted December 31, 2012 Author Share Posted December 31, 2012 ahh cheers mate thats the best possible answer thankyou i will start upgrading and keep you posted, once again thanks alot. great help Quote Link to post Share on other sites
EP91_STARLET Posted January 1, 2013 Author Share Posted January 1, 2013 do you know where i can get hold of the above exhaust manifolds? i cant find corolla anything anywhere! Quote Link to post Share on other sites
Xpect Posted January 1, 2013 Share Posted January 1, 2013 The 4-2-1 Corolla Mani isn't from the Bug-Eye Corolla E11 but from the normal looking Corolla E10. From the 4E-FE Gen1 and not Gen3. In our Starlet we have the Gen2 Quote Link to post Share on other sites
Amjad Posted January 1, 2013 Share Posted January 1, 2013 Bit of a no brainer here but check your spark plug gaps, just widened mine from 0.9mm to 1.2mm and it has a bunch more torque now Quote Link to post Share on other sites
shorty Posted January 1, 2013 Share Posted January 1, 2013 I had a jdm 421 mani and a jdm ep85 100ps engine with all the full set up and ecu injectors etc etc could sell em for love nor money, but the pikey scrap van that came round was more than happy to take em away and get em of me drive for me. no wonder their rare lol no one seems to want em when their there lol. Quote Link to post Share on other sites
daniel_g Posted January 1, 2013 Share Posted January 1, 2013 I dont know why nobody took them off your hands dude, that could have been an awesome wee setup for a 91. Quote Link to post Share on other sites
Addymk2 Posted January 2, 2013 Share Posted January 2, 2013 That list Ryan knocked up should be a stickied thread on its own Quote Link to post Share on other sites
cherrye10 Posted October 20, 2013 Share Posted October 20, 2013 On 12/31/2012 at 4:10 PM, Xpect said: With pulleys, headwork, tubular intake together with the stock tb widened to 50mm, Obex 4-2-1 Exhaust, Green Twister Filter and cold air induction, Glanza S Fuelrail and Emanage "motion" made like 115bhp. I would be happy having that. More than double that of a 1N!! and if someone can make another 15 it will be equivalent to astock 4efte Quote Link to post Share on other sites
onnaj1000 Posted November 18, 2014 Share Posted November 18, 2014 (edited) Hi guys, I got myself an E11 bugeye tubular intake manifold some time ago that a friend of mine has glassblasted and i've painted it past week. I've also got an E11 as E10 throttle body as well. Should i only use the E11 manifold or should i also use the E11 throttle body? How many gains can i expect from only the manifold? I know it won't be 20 horses, but i'm curious if it might be around 5-10 hp or so?? thanks Pictures (not completely satisfied with the results, but it's difficult to paint!): how it was: how it is now: Edited November 18, 2014 by onnaj1000 Quote Link to post Share on other sites
onnaj1000 Posted November 26, 2014 Share Posted November 26, 2014 No one? Quote Link to post Share on other sites
mikey4410 Posted November 26, 2014 Share Posted November 26, 2014 probably a few bhp up top maybe if lucky Quote Link to post Share on other sites
Phil Posted November 26, 2014 Share Posted November 26, 2014 On 11/18/2014 at 6:11 PM, onnaj1000 said: Hi guys, I got myself an E11 bugeye tubular intake manifold some time ago that a friend of mine has glassblasted and i've painted it past week. I've also got an E11 as E10 throttle body as well. Should i only use the E11 manifold or should i also use the E11 throttle body? How many gains can i expect from only the manifold? I know it won't be 20 horses, but i'm curious if it might be around 5-10 hp or so?? thanks Pictures (not completely satisfied with the results, but it's difficult to paint!): how it was: how it is now: have seen that manifold used before i thinks. made like 500hp. but it was on a 5e turbo. Phil Quote Link to post Share on other sites
fiddlersport Posted November 26, 2014 Share Posted November 26, 2014 for the time and effort and costs, stick a 4efte in , been down that road and its all fun in the beginning but in the end the boost is the best bang for buck ! Quote Link to post Share on other sites
onnaj1000 Posted December 5, 2014 Share Posted December 5, 2014 (edited) I'm not going the 4EFTE route, at least not yet and not in this Starlet ;-) Just wondering if i could also swap a Glanza S ECU together with the Corolla mani? That could possible be a 10 hp upgrade which is about 15% extra. Edited December 5, 2014 by onnaj1000 Quote Link to post Share on other sites
Lopesfc Posted June 3, 2015 Share Posted June 3, 2015 On 12/30/2012 at 10:59 PM, ryan lang said: .....Fuelling:Corolla bug eye injectors (beige/brown in color)Inlet:Corolla bug eye inlet (tubular manifold)4efte inlet manifold4efte Throttle Body........RyanHi. Nice topic. Like to know if the Corolla bug eye that you talk about is this onehttps://c1.staticflickr.com/5/4075/4787821814_4631ba35cd_b.jpg ThanksLuís Quote Link to post Share on other sites
