it will be steam cleaned, only once mapped, in fact I like it dirty bay.lol..
cheers fo comments guys..
russ and mikey theirs a big bank hol meet somewhere in Essex, I should be bring the glanza to that if you guys fancy a convoy?
always up for a meet mate my cars practically done now so im up for it :)
  • Replies 458
  • Created
  • Last Reply
Top Posters In This Topic
yea sure thing russ matey..
well my intercooler and rad are taking bit longer to make, which is annoying..
but my tuner been on their backs today, so it will be done for bank holiday wkend.
its sctually slimmer then the japspeed core i had before, but just its 4 inches taller, so its get far greater airflow.
plus less piping.
still working on it even at nights after work.LOL
another small update with pics..
intercooler brackets welded on, wiring loom has been cut away, where I don't need certain things..
ive extended the headlight loom thru the wheel arch and is covered in Teflon coating.
heres pic..
then made a new addition to front bumper..
using bonnet pins it is now quick release for track days/ nasty bumps at local meets and cruises.
again heres pic
again all comments welcome..
oil cooler will be fitted next week as well, with a remap to suit new mods.
Is that a water line thats goes directly over the downpipe? Might want to move it, the hose can't withstand the heat from DP.
The highest
heat resistance on a hose I have seen is 260°C / 500°F. DP is way over 500°C / 932°F. No way its going to hold.
I like the front, looks great!
right shes done guys...
mapping went well.. made 296atw at 1.5 bar as before made 284..
flywheel is 318 at 1.5 bar as before was 300.1 at 1.5 bar.
had big chat to my mapper on the phone, the inlet has made the power band more top end, and has increased torque, and its not as nice below 2.2k as the stock item, but above 4k it makes a huge difference, and the inlet temps are lower by 8 degrees.
That's probably to do with better intercooler and inlet, not just one item making the difference.
Lag is exactly as was before even tho got a 70mm throttle body on..
when mapping compared to before, my tuner told me he took 4% ignition out and 8% more fuel in so clearly the engine is getting a lot more air, so nice to be able to do an accurate comparison..
Top end he showed me it makes a huge difference, boost and power doesn't drop off like before at 6600rpm, it stays all the way to 7300rpm..
picture time...
Oil cooler location shown in this pic.
Side on..
Once again comments welcome
cheers Maddox, mid range to top end is certainly faster then before..
but yes ive sacrificed low down power and a little bit of low down torque, but from 3k the pick up is pukka, definite improvement.
also forgot to add dyno cell temps today were 29.4c when mapped end of april before japfest it was 15.7..
