pick1 Posted March 25, 2013 Posted March 25, 2013 Let me guess you all sign a waver before they mess about with your car!Thought that was pretty standard at tuning companies nowa days Quote
Rob H@RCH Engineering Posted March 25, 2013 Posted March 25, 2013 With Will at RDT that I use he offers a full pre dyno inspection, bore scope to check every thing is good in the cylinders, checks plugs, static timing, cooling system for leaks and so on and thats around 60 quid if you have that done before the dyno there is no disclaimer to sign and generally if its built to a good standard he dont bother ether but if its all bodged together then yes you have to sign one! Thought that was pretty standard at tuning companies nowa days Quote
AdamB Posted March 25, 2013 Posted March 25, 2013 (edited) Me personally would get the fuel system checked, this would rule out any mechanical failures with whats happened.After thats eliminated it would be due to the timing, then fingers can start being pointed. Like I had said previously, either not enough timing was in the map causing excessive EGT's, or the base static ignition timing wasn't checked. Edited March 25, 2013 by AdamB Quote
Ricky@Race-Tech Posted March 25, 2013 Posted March 25, 2013 EGT's aren't the issue. Too much timing has been used in the above case. Quote
mattyD Posted March 25, 2013 Posted March 25, 2013 I still think all 4 injectors maxed out, lets be honest as soon as she was finished you ragged the fuck out of it on injectors that blatantly couldnt flow enough and ran lean.......still shit news mate after all the hard work was put in. Have any of the fueling components been looked at yet? Pressure is on now to get her done and seen at japfest Quote
Rob H@RCH Engineering Posted March 25, 2013 Posted March 25, 2013 That much timing would show up In EGT temps tho if its hot enough to melt pistons that would show in the EGTs clearly. The turbo would be mad hot too. Quote
lew777 Posted March 26, 2013 Posted March 26, 2013 Suppose revving the fuck out you car from cold wouldnt help if thats how you treat your car . Quote
Mike@TD.co.uk Posted March 26, 2013 Posted March 26, 2013 Base timing was checked and set before tuning commenced. Ignition timing levels were not excessive, as stated in the previous thread, we do not go to the extremes with a customers car, there are many variables to allow for which means we leave a safety margin. If this damage has happened so quickly, then we would have been aware of the issue whilst on the dyno for several hours, and then also out on the road afterwards. The motor was silent through det cans and was running A1 when it left, you road tested it yourself before deciding to still tow it home. Without seeing the car, and from what you have explained to me via PM, I would look into your fuel system on the car with a view towards fuel starvation at extended periods of extreme load. Probably also worth picking up a stronger, more stable EBC. Thanks Mike JonesTuning Developments Ltd Quote
Taggy Posted March 26, 2013 Author Posted March 26, 2013 Well i have had a change of plan, I really need to keep the rebuild costs down especially as i now need a new set of forged pistons so I have emailed tuning developments if i can take the car back to them to get fault tested for no charge. Cant really afford to pay another £250 to put it back on the rollers again, im bloody skint now. That way they get a chance to see if its something that's failed or if indeed they missed something, i dont see why they shouldnt. Quote
Taggy Posted March 26, 2013 Author Posted March 26, 2013 Hmm what i also find interesting is two different tuners have different opinions on what they think has gone wrong, Ricky says timing, TD thinks fuel starvation, hmmm i wonder who is right. Quote
micky boy Posted March 26, 2013 Posted March 26, 2013 (edited) If it was on the rollers for 7hours then if they was something wrong with fueling then why didnt anything go wrong on the rollers? madness Its as if its been mapped and the map hasnt been saved or something lol cause if anything was to go wrong you would of thought it would of been within that 7hours it was on the rollers Also no tuner will admit there at fault it could put alot of people off going there to get there car turned so thats never going to happen! The only way your going to find out whats realy happend 100% is take it to another turner Ohh and im not saying TD are at fault here im just saying even if they are i cant see them admiting it Edited March 26, 2013 by micky boy Quote
Danb Posted March 26, 2013 Posted March 26, 2013 Also no tuner will admit there at fault it could put alot of people off going there to get there car turned so thats never going to happen! The only way your going to find out whats realy happend 100% is take it to another turner Ohh and im not saying TD are at fault here im just saying even if they are i cant see them admiting ityou obviously don't know nick and mike then - most honest people I know.Oh and if you tell another tuner that you think another tuner has fucked up, whether they have or not the vast majority will say they have fucked up (whether the have or not!) and charge you for fixing something that didnt need fixing.Oh I'm speaking from experience here also Quote
Taggy Posted March 26, 2013 Author Posted March 26, 2013 Well i will ask everyone to stop the blame game then, I have agreed with Mike to take it back and have a look at it and go from there. I hope to have it fixed by end of April. Quote
pick1 Posted March 26, 2013 Posted March 26, 2013 ^^^ total agree with danb above and have previously had experience with this when tuning the ford rs's something happend with a Friends motor so he took it somewhere closer for an inspection and bam had a laundry list of so called faults and a nice quote of how much it would cost to fix it (there way) .Tuning companies are like all other companies they are competition with each other in one way or another.Just hope u get the boxy sorted mate Quote
turbo Grant Posted March 26, 2013 Posted March 26, 2013 If he doesn't fit it I shall be driving up to Swansea with a 25lb trout. Then I will proced to slap him round the face with it Quote
ro55ifumi Posted March 26, 2013 Posted March 26, 2013 Well i will ask everyone to stop the blame game then, I have agreed with Mike to take it back and have a look at it and go from there. I hope to have it fixed by end of April. As above or this will be locked Quote
turbo Grant Posted March 26, 2013 Posted March 26, 2013 My mate lives on a trout farm. There are some massive ones Quote
Taggy Posted March 26, 2013 Author Posted March 26, 2013 Maybe we should make trophies out of them for this years JAE Quote
Starbo Moorley Posted March 26, 2013 Posted March 26, 2013 Maybe we should make trophies out of them for this years JAEEpic idea ! Quote
TrisK Posted March 26, 2013 Posted March 26, 2013 Maybe we should make trophies out of them for this years JAEYes Taggy! Special awards: 1. Most Automotive Pain/Worst Luck 2. Craziest Idea of the year 3. Longest Build of the year 4. Most powerful on standard internals (giviing them the most knackered forged piston, cause who needs it ) Quote
