karl. Posted June 27, 2018 Posted June 27, 2018 Are you sure you fitted the top mounts the right way around? Quote
Sefton-EP91 Posted June 27, 2018 Author Posted June 27, 2018 I would say so.. I didnt think you could get them wrong! As the bolts are spaced apart differently!? Quote
Sefton-EP91 Posted July 7, 2018 Author Posted July 7, 2018 On 27/06/2018, 08:52:37, jellybaby said: What’s ya camber at also did u losen the strut bolts in the hub when adjusting I haven’t got the readings but I set everything to 0. I didn’t undo the hub bolts but was going to do that if necessary! Quote
jellybaby Posted July 7, 2018 Posted July 7, 2018 When adjusting camber u should slacken the bolts off connecting the hub what equitment u use ? Hunter machine ? Quote
Sefton-EP91 Posted July 8, 2018 Author Posted July 8, 2018 I will bare that in mind in future, thank you! It’s a snap on 4 wheel alignment machine, unsure of the model but it’s pretty good! Quote
jellybaby Posted July 8, 2018 Posted July 8, 2018 Ok well I will look on my system 2 moz as I have the set up for glanza and send them to u but for camber always like to b -1.5 toe parallel Quote
bahnstormer Posted September 2, 2018 Posted September 2, 2018 Lovely car! Obviously a lot of time and hard work has gone into it Quote
Sefton-EP91 Posted January 13, 2019 Author Posted January 13, 2019 So, I’ve fell behind with this again so it’s time to update it. Ive sold my billet hybrid td04 kit to way for bigger things over winter. I thought over winter I would like to change my turbo setup and change some cosmetic things. i thought long and hard about the new turbo choice and soon came to the conclusion that it would be a Garrett despite some really good turbo kits coming up for sale and in production. This WEPR kit came up for sale and decided I had too have it. So I made a decision on a turbo and went for the Garrett GTX2860rs gen2 turbo so I got it ordered from BTN Performance and couple days later it had arrived I wanted to run external gate again and as id sold my complete turbo setup I no longer had an external gate so I set at buying a new external gate and getting the internal gate welded up on the new turbo, I also wanted the matching BOV so I bought that aswell, both genuine TiAL. The plan was to make the engine bay as clean as I could with the facilities I had so I bought another cylinder head from Tyler devonport and soon realised I’d bagged myself a bargain as it was mint! Photo was just after I had stripped it, so i could set at replacing the stem seals, re lapped the valves and painted it. I also bought i new Thermostat housing to save all the hassle of swapping it all over once my car was stripped. While i was there I replaced the thermostat with a TD low temp stat. No photos of the stat fitted unfortunately. I soon realised that with the new BOV I would need to get my WEPR intercooler pipeing modified to accomodate the new BOV. So thanks to my good from Luke Gittins for sorting this for me!! i decided I wanted to clean up the inlet aswell but instead of cleaning mine I bought another from Luke Gittins and painted it up! 2nd photo I had fitted the throttle body along with genuine Toyota seals. So my current rocker cover was looking abit tatty so I decided to sell it along with my zisco oil catch tank and bought another from luke Gittins along with a RW Developments catch tank. Although when the rocker cover arrived I had already made plans to paint it but unfortunately I don’t have any before photos. So this the finished product. Painted wrinkle red! I decided to test fit all the bits and see how they looked, I can honestly say I’m excited. New fuel rail aswell. Made up Some new AN6 fuel lines from the fuel filter and al the way round the engine bay. new adjustable cam pulley so I got my car stripped and set and getting it back together with all the following. New ARP Headbolts New Athena 1.2mm head gasket New Genuine Toyota gaskets where applicable. New inlet and exhaust manifold studs and nuts New Thermostat housing bolts and nuts New distributor bolts New genuine Toyota distributor cap and rotor arm New Rocker cover seals and nuts New magnecore 8.5mm HT leads New spark plugs New cambelt cover bolts New Genuine Toyota cambelt kit I bought a clear cambelt cover from Luke Gittins. I waned to remove the power steering aswell so I bought a loop pipe and got it fitted. There is so much happening I’m losing track what order it all goes in so I’m just going to throw it all in here. So now there is no particular order. Managed to also get my oil cooler setup fitted along with my mocal thermostatic sandwich plate. got hold of a rear bumper with optional lip so i got that fitted aswell. also got hold of a Glanza S Bonnet. So too some things up, she was sitting happy looking like this.. So too cut a long story short, she was suppose to go and have a new exhaust made up at speedfab on the 7th Jan but it was soon brought to my attention that there was an issue after starting her up. She had a major misfire, 2 cylinders were down on compression. So I set at investigating and soon found the valve clearances on cylinder 1+4 were too tight so I spent the good part of a day setting all the clearances. Unfortunately I didn’t have enough shims to make a good cylinder head out of the two heads I had so I’ve had too order 3 shims from work and 1 of them soon went too back order. So now it’s a waiting game.. she now sits like this.. more updates as things happen now! Quote
BMX-RIG Posted January 14, 2019 Posted January 14, 2019 What an annoying set back! All good progress though. Still got a few months until the weather picks up! Quote
akyakapotter Posted January 15, 2019 Posted January 15, 2019 Turbo kit looks sexual. Only a small set back pain in the bum though. Keep plugging away at it. Quote
Sefton-EP91 Posted January 15, 2019 Author Posted January 15, 2019 On 1/14/2019 at 2:45 PM, BMX-RIG said: What an annoying set back! All good progress though. Still got a few months until the weather picks up! 9 hours ago, akyakapotter said: Turbo kit looks sexual. Only a small set back pain in the bum though. Keep plugging away at it. Thanks for the kind words guys, yes it was a small setback and nothing that can’t be sorted! Quote
Sefton-EP91 Posted January 15, 2019 Author Posted January 15, 2019 The shim has arrived it’s fitted and going back together, the cambelt is on, cams are in and rocker cover is in along with new genuine camshaft oil seal, distributor is in along with new dust seal and oil seal, also new genuine dizzy cap and arm fitted. Hopefully I can have it running tomorrow!! Quote
jellybaby Posted January 15, 2019 Posted January 15, 2019 4 minutes ago, Sefton-EP91 said: The shim has arrived it’s fitted and going back together, the cambelt is on, cams are in and rocker cover is in along with new genuine camshaft oil seal, distributor is in along with new dust seal and oil seal, also new genuine dizzy cap and arm fitted. Hopefully I can have it running tomorrow!! I have this task to do my self how easy did u find doing it ? Any guide u used ? Quote
H_D Posted January 16, 2019 Posted January 16, 2019 Looks real good buddy. Keep us updated on how the new turbo setup works. Quote
glanzadude Posted January 16, 2019 Posted January 16, 2019 Thats one sexy engine bay, best off luck with her Quote
LeonL Posted January 16, 2019 Posted January 16, 2019 What brand catch tank is that? Looking for similar one myself, that mounts nicely to the strut Quote
Sefton-EP91 Posted January 16, 2019 Author Posted January 16, 2019 On 1/15/2019 at 9:28 PM, jellybaby said: I have this task to do my self how easy did u find doing it ? Any guide u used ? It’s surprisingly easy, I have a conversion chart at work to work out what shim you need. You just use a feeler gauge with the cam lobe facing upwards and measure your gap between the camshaft follower and lower part of the cam lobe, then you measure the shim that’s already in place, Then use the conversion chart to work out what shim you need. Ill get pics tomorrow and drop them in here for you! With the conversion chart your life will be a lot more simple Quote
Sefton-EP91 Posted January 16, 2019 Author Posted January 16, 2019 14 hours ago, H_D said: Looks real good buddy. Keep us updated on how the new turbo setup works. 13 hours ago, glanzadude said: Thats one sexy engine bay, best off luck with her Thank you so much for the kind words guys, appreciate it very much. I’m hoping to keep this updated as much as I can now so keep your eyes peeled! Quote
Sefton-EP91 Posted January 16, 2019 Author Posted January 16, 2019 9 hours ago, LeonL said: What brand catch tank is that? Looking for similar one myself, that mounts nicely to the strut It’s an RW Developments catch tank! Mounts up perfectly on the strut, the only thing with mine is it touches my BOV so I’ve had to bend it up slightly although hardly noticeable! Quote
jellybaby Posted January 16, 2019 Posted January 16, 2019 17 minutes ago, Sefton-EP91 said: It’s surprisingly easy, I have a conversion chart at work to work out what shim you need. You just use a feeler gauge with the cam lobe facing upwards and measure your gap between the camshaft follower and lower part of the cam lobe, then you measure the shim that’s already in place, Then use the conversion chart to work out what shim you need. Ill get pics tomorrow and drop them in here for you! With the conversion chart your life will be a lot more simple That will save me slot of time feller cheers Quote
LeonL Posted January 17, 2019 Posted January 17, 2019 11 hours ago, Sefton-EP91 said: It’s an RW Developments catch tank! Mounts up perfectly on the strut, the only thing with mine is it touches my BOV so I’ve had to bend it up slightly although hardly noticeable! Brilliant thanks, spent ages yesterday trying to find it Quote
jellybaby Posted January 20, 2019 Posted January 20, 2019 DID ya manage to get a pic of the conversion chart as I have identified some shims that neee to be adjusted Quote
Sefton-EP91 Posted January 21, 2019 Author Posted January 21, 2019 On 1/20/2019 at 3:32 PM, jellybaby said: DID ya manage to get a pic of the conversion chart as I have identified some shims that neee to be adjusted I’ve set a reminder in my phone so I’ll get it tomorrow for you Quote
Sefton-EP91 Posted January 23, 2019 Author Posted January 23, 2019 11 hours ago, jellybaby said: Cheers dude Quote
