triple j Posted February 4, 2014 Posted February 4, 2014 U can test it at the map sensor on the two wires or the ecu side, as its not starting with the plug and play compare voltages between both ecu's on turn over, unplug king lead and take out efi fuse on the stock ecu testing just to get an even reading if u get me. Quote
daniel_g Posted February 4, 2014 Posted February 4, 2014 The seal on the Mines is broken, have you opened up the ECU ? I had one of these and its a beast of an ECU, i really hope you can get it working. Quote
corofin12345 Posted February 4, 2014 Posted February 4, 2014 theres a simple way to check to see if the ECU is compatible with your car.. put the 2 ECU's together and check the pins to see if they are the same Quote
corofin12345 Posted February 4, 2014 Posted February 4, 2014 (edited) alternatively you can check it this way.. 89/92 pins differ to 92/96 pins.. some wires are different and some are not there at all between ECU's check your wires on your loom to ECU to make sure it matches all the pins.. PDF below shows the differences in the EP82 ECU's.. http://homepage.ntlworld.com/dub.se7en/TGTT/ecus_4E-FTE.pdf Edited February 4, 2014 by corofin12345 Quote
Chris Green Posted February 4, 2014 Posted February 4, 2014 The best option for electrical/technical advise is TGTT. Although I would call UKSO my 'home' I tend to go to TGTT for really technical stuff. A few wizards on there tend not to use UKSO. Quote
Sandham Posted February 5, 2014 Author Posted February 5, 2014 Yeah the starting issue turned out to be plugs... I bought it like that i wouldnt know what i was looking at if i did open one lol!Ill try get a multi meter to do the map sensor and ill ask on tgtt also didnt think of that chris Quote
Socks Posted February 8, 2014 Posted February 8, 2014 Have you opened this ECU up? As seals are torn? Some of these plug and play ECU's have light sensitive chips in them. If exposed to light, they wipe themselves I believe... Quote
Idrees Posted February 8, 2014 Posted February 8, 2014 Come and try it in my EP82, I'm only in Huddersfield Quote
mikey4410 Posted February 9, 2014 Posted February 9, 2014 why the heck would you buy after market ecu with seals open ?? Quote
Sandham Posted February 10, 2014 Author Posted February 10, 2014 (edited) It was sold to me with the seals broken "tested working" by a member on here with good positive feedback..I havent done anything with it other than plug it into my car. Edited February 10, 2014 by Sandham Quote
Jamie5414 Posted February 10, 2014 Posted February 10, 2014 Take a run down to Idrees and test it out mate... Best thing you can do at this point.. If it works then at least you know it's not the ECU thats at fault. If it doesn't work then return it it's quite simple. Quote
dangeestarlet Posted February 10, 2014 Posted February 10, 2014 It's a lot of money for it not to work, I'm gutted for you mate hope you get it sorted Quote
jimmymac101 Posted February 10, 2014 Posted February 10, 2014 Take a run down to Idrees and test it out mate... Best thing you can do at this point.. If it works then at least you know it's not the ECU thats at fault. If it doesn't work then return it it's quite simple. I'd do exactly this mate James Quote
Sandham Posted February 11, 2014 Author Posted February 11, 2014 (edited) No worries paypal have refunded me my money, will be posting the ecu back tomorrow. Micky boy has been very understanding of the issue however so i dont want this to be interpreted as bad feedback as i would still deal with him in a breath if needs be Edited February 11, 2014 by Sandham Quote
micky boy Posted February 11, 2014 Posted February 11, 2014 No worries paypal have refunded me my money, will be posting the ecu back tomorrow. Micky boy has been very understanding of the issue however so i dont want this to be interpreted as bad feedback as i would still deal with him in a breath if needs be Cheers buddy glad this can be put to rest tbh. Ill send you a message when i receive the ecu Quote
