Rob H@RCH Engineering Posted February 4, 2014 Posted February 4, 2014 put it in a spray bottle and spray it around the joints that should work, but by the sound of that I would not say it was not a leak because the idle would be high too and yours sounds quite stable. I would say it was just one of those things lol Quote
morgey Posted February 4, 2014 Posted February 4, 2014 Regarding the welds. It's aluminium which is harder to weld than steel so is much harder to get a good Finish with. The other welds shown in the link later on are steel hence a better Finish. Quote
Jamie5414 Posted February 4, 2014 Posted February 4, 2014 Can still get a good finish on alu Looks are everything IMO with exhuasts/inlets/intercooler piping etc http://i.imgur.com/kg7I3JBl.jpg Quote
Beastmode panda Posted February 4, 2014 Author Posted February 4, 2014 Yeah but 'one of those things' is no good when I'm just about to have it mapped and going for 300+ bhp haha I need it to be all perfect how it was!! Lol. The reason why I don't think it's a leak either is because as you said the idle is spot on, not too high and not hunting either. So I'm really not sure. As said, will change the gasket and see where that leaves me. Fucking annoying though especially as it's something since the new inlet has been put on!!! Quote
Socks Posted February 5, 2014 Posted February 5, 2014 Put your boost pipes on Rbz. Put your hand over the end of the turbo... If the car dies, you don't have a leak... If it keeps running you'll hear a loud sucking noise coming from the area or place its leaking from... Works for me everytime when ive had a leak... Quote
kavan-k Posted February 5, 2014 Posted February 5, 2014 Put your boost pipes on Rbz. Put your hand over the end of the turbo... If the car dies, you don't have a leak...If it keeps running you'll hear a loud sucking noise coming from the area or place its leaking from...Works for me everytime when ive had a leak...Get that in the guides section lol Quote
Beastmode panda Posted February 5, 2014 Author Posted February 5, 2014 Put your boost pipes on Rbz. Put your hand over the end of the turbo... If the car dies, you don't have a leak... If it keeps running you'll hear a loud sucking noise coming from the area or place its leaking from... Works for me everytime when ive had a leak... Awesome!! But, where do I put my hand over haha? The intake side I'm assuming, where the mesh is? Quote
dangeestarlet Posted February 5, 2014 Posted February 5, 2014 No you will have your hand sucked in the turbo , take the intercooler pipe off the inlet and out your hand over the inlet and don't rev it lol Quote
TurboTobz Posted February 5, 2014 Posted February 5, 2014 No you will have your hand sucked in the turbo , take the intercooler pipe off the inlet and out your hand over the inlet and don't rev it lolnot sure if srs? Quote
Beastmode panda Posted February 5, 2014 Author Posted February 5, 2014 Lol, I don't think a gt28 turbo is going to suck my hand into in on idle dude.. Anyway, I tried it and turbo is too big to cover my hand over it haha. Need to find something big enough to cover the turbo good. Hmmm! Quote
Beastmode panda Posted February 5, 2014 Author Posted February 5, 2014 That would suck in straight away lol. Needs to be something solid I think. Quote
Chris_GlanzaV98 Posted February 5, 2014 Posted February 5, 2014 I wouldnt use paper lol use somethong that wont have the possibility of going i to the turbo Other than that good review rob ! Cant wait for the fitted pics ! Hows it running prior to the map im not fitting mine untill its at the mappers as mile at td said itll run like a bag of shit lol Quote
kavan-k Posted February 5, 2014 Posted February 5, 2014 I mean like a newspaper lol full thing just hold it over the front, or cardboard lol Quote
Beastmode panda Posted February 5, 2014 Author Posted February 5, 2014 I wouldnt use paper lol use somethong that wont have the possibility of going i to the turbo Other than that good review rob ! Cant wait for the fitted pics ! Hows it running prior to the map im not fitting mine untill its at the mappers as mile at td said itll run like a bag of shit lol Thanks mate! Runs fine, except for the weird noise it runs like normal . Mine isn't mapped yet, will be going to have my ultimate fitted and mapped this month. But see'ing as it's not mapped I wanted to get the inlet on ready for the day. And also due to it not being mapped yet it makes no difference. Not sure if yours is mapped, but if it is it could alter the map if you put the inlet on so yeah Mike is probably right there. Quote
TurboTobz Posted February 5, 2014 Posted February 5, 2014 Lol, I don't think a gt28 turbo is going to suck my hand into in on idle dude..Anyway, I tried it and turbo is too big to cover my hand over it haha. Need to find something big enough to cover the turbo good. Hmmm!a good ole ass cheek may do it Quote
TimD Posted February 7, 2014 Posted February 7, 2014 How do these affect the way the car drives? Sure it looks pretty enough, but how better is it over the original plenum? Quote
Beastmode panda Posted February 8, 2014 Author Posted February 8, 2014 How do these affect the way the car drives? Sure it looks pretty enough, but how better is it over the original plenum? I couldn't answer that until the car is mapped. That's why i left the question blank to be filled in after . Quote
Beastmode panda Posted February 25, 2014 Author Posted February 25, 2014 how did you get on ? Well I've sorted out the whistling noise! I changed the throttle body gasket and sure as hell it fixed that problem. I've got a boost leak somewhere in the intercooler system, so having my pipework made up and welded together with a joiner either end so reduce risk of boost leaks when 1.4bar or whatever it going through it when it gets mapped. Intercooler pipes will be sorted this week, then it's off for mapping after it's sorted. Hard cause I don't got much spare time. But going as fast as I can! . Not long now guys. Quote
mark-tozer Posted February 26, 2014 Posted February 26, 2014 im glad you have sorted the whistling noise. I have got a new throttle body gasket to try on mine. ive thought about doing the same with my boost pipes so illuminate leaks but not sure were to get it down. can you post a pic up when you have got them Quote
Beastmode panda Posted February 26, 2014 Author Posted February 26, 2014 im glad you have sorted the whistling noise. I have got a new throttle body gasket to try on mine. ive thought about doing the same with my boost pipes so illuminate leaks but not sure were to get it down. can you post a pic up when you have got them Hopefully that will solve your issue as it did mine dude! I was surprised it was only the gasket though. Crazy that a thin bit of gasket material stuff can make such a difference between issues and no issues. Ok mate yeah no problem, i'll take as many pics as I can for ya . Quote
