aaddzz123 Posted September 18, 2014 Posted September 18, 2014 @aaddzz123 I don't have better photos of the rails being converted other than this (it was kind of hard to take photos while the rails were being welded). But essentially the main thing we did was strip off all of the reclining mechanism and then relocated the rear mounting points slightly (turns out Sparco mounting points weren't that far off) and re-spot welded them onto the rails. This particular photo was for the driver side rails. We retained the seat height mechanism to be used as a "tilt" adjuster for the fixed bucket seat. Hope this helps! I'll try to see if I can get you better photos tomorrow. Clever stuff mate. And much more cost efficient over buying a new rail... How low does the seat sit as the standard seats are pretty high... I want to do something similar but it depends how high it sits really. I may end up making a whole fixed mount if it's not particularly low.Cheers mate Quote
mindless Posted September 18, 2014 Author Posted September 18, 2014 @aaddzz123 they do sit pretty high because i didnt modify the brackets that bolt on the floor. But it works with these particular sparco seats that I bought because seat sinks pretty deep so I guess they cancel themselves out. Also I like seeing a bit of the bonnet to use as reference when cornering. So i guess you can make it lower if you want but it also depends on the seat of your choice. Quote
mindless Posted September 18, 2014 Author Posted September 18, 2014 There has been quite some progress on different fronts in the build. Both seats finally mounted on stock rails! Reusing the original plastic seat trims to cover the gutted/converted rails. Also we finally got the refreshed engine back! New clutch going into the refreshed tranny! We also got around to painting the roofliner black with some VHT vinyl paint ...and installing it Finally started painting the converted dash too! Recreating the texture where we had to use body filler to smooth out the joins during conversion Also started prepping the other dash bits for paint Quote
mindless Posted September 20, 2014 Author Posted September 20, 2014 So here's what the painted converted dash looks like mounted Didn't realize the oil filter actually had its own heatshield Painted the remaining heatshields vht flameproof silver + flameproof top coat Painting/cleaning the remaining bits on the engine getting ready for install. Quote
Japscrapno1 Posted September 21, 2014 Posted September 21, 2014 Great progress mate and that dash looks factory great job on it;) Quote
Armand Posted September 24, 2014 Posted September 24, 2014 Awesome work man! The attention to detail is immense Quote
mindless Posted September 28, 2014 Author Posted September 28, 2014 So a quite a number of things happened in the past few days... Transmission, fuel rail and a other small bits cleaned and painted Replaced the old worm gear clamps with T-Bolt for the brand new OEM intercooler. The rest of the dash panels painted We've decided to two-tone the rest of the rear interior panels. Getting ready to mount the engine. Transmission mated! Here we go! TADA! Engine in! With the axles in place we did for a quick test fit with the TE37V's just to see how it looks. Needs Needs to be lowered a bit more but that can wait. Other than that the wheels fit perfectly! Test fitted the gold tape wrapped OEM intercooler to see if the T-Bolts will cause any clearance issues Quote
mindless Posted September 30, 2014 Author Posted September 30, 2014 Thanks guys! still a long ways to go. Quote
mindless Posted October 1, 2014 Author Posted October 1, 2014 More detail work... repainted the valve cover with some VHT engine enamel paint! Quote
mindless Posted October 1, 2014 Author Posted October 1, 2014 (edited) All together now! Edited October 1, 2014 by mindless Quote
jimmymac101 Posted October 2, 2014 Posted October 2, 2014 I love build to bits so fresh and nice to see someone treating a car to so much love One question though ......... All that work yet you have stuck with a standard engine set up, any reasons for this ? James Quote
mindless Posted October 2, 2014 Author Posted October 2, 2014 (edited) I love build to bits so fresh and nice to see someone treating a car to so much love One question though ......... All that work yet you have stuck with a standard engine set up, any reasons for this ?James I already have a full blown EP82 race car. I don't feel the need so much for a powerful street car so I opted to go the opposite route - 1 bar ct9 + oem intercooler + emanage Actually I have a friend who bought a glanza race car tuned from japan with the exact same setup (including the OEM intercooler) running at 1 bar with an emanage blue. And its putting to shame b18 civics. This was sort of the inspiration for my engine mod route... Plus this isn't a racecar but will be more of alternate street car to share daily driving duties with my EK9 Edited October 2, 2014 by mindless Quote
Japscrapno1 Posted October 2, 2014 Posted October 2, 2014 Didn't think the stock intercooler was capable of cooling a ct9 at 1bar? Quote
mindless Posted October 2, 2014 Author Posted October 2, 2014 I didn't think so myself before, but here I saw a race prepped glanza straight from japan with that setup. Quote
Rich-k Posted October 5, 2014 Posted October 5, 2014 Holy shit this is awesome its like the car is brand new will look great in those wheels also Quote
mindless Posted November 14, 2014 Author Posted November 14, 2014 Apologies for the lack of updates... I've been caught up with real life issues like moving to a new place among other things. That said, a lot has happened to the car from last time Let me just give you the major highlights. We've continued fitting the rest of the interior trim: The whole harness has been cleaned up converted from RHD to LHD and tested Started wiring everything up: Check out those fat ass cables that will relocate the battery to the boot That's all for now. In the meantime let me just leave you with this ;) >https://www.youtube.com/watch?v=PbQYfKJXf3M Quote
Gainzy Posted November 14, 2014 Posted November 14, 2014 I already have a full blown EP82 race car. I don't feel the need so much for a powerful street car so I opted to go the opposite route - 1 bar ct9 + oem intercooler + emanage Actually I have a friend who bought a glanza race car tuned from japan with the exact same setup (including the OEM intercooler) running at 1 bar with an emanage blue. And its putting to shame b18 civics. This was sort of the inspiration for my engine mod route... Plus this isn't a racecar but will be more of alternate street car to share daily driving duties with my EK9Any pics of the tuned glanza from Japan? This build is amazing so much care and bringing back the oem bay look love it Quote
mindless Posted November 15, 2014 Author Posted November 15, 2014 @Gainzy I don't have a lot of photos of my friend's Glanza (the one tuned from Japan) but here are a few: Quote
mindless Posted February 2, 2015 Author Posted February 2, 2015 (edited) Apologies for the lack of updates, but between getting the build done, selling of my EK9 and buying an R34 Skyline I had too much going on to focus on documenting the rest of the build. That said, the good news is that – SHE'S FINALLY DONE!!! Here are some photos of her: Hanging out with a friend's Celica GT205 With her Skyline big brother Edited February 2, 2015 by mindless Quote
