maerijn
    267
About maerijn
  • Birthday 02/22/1994
    Netherlands
3528 profile views
maerijn's Achievements
Member (4/8)
  1. that looks awesome! no way, i think the wheels look great, what type are they?
  2. did you check the fuse
  3. try a different relay?
  4. fixed, can lock this.
  5. Maybe it's yours which is on the wrong side instead 😋
  6. thick ground wire from gearbox mount to battery negative terminal another ground is on the back of the inlet manifold additionally you could add a ground from the right engine mount to the chassis
  7. very clean, I love it! 😲
  8. that looks clean 😄
  9. its a strange colour but glad to see something different every once in a while! toyota PN for the oil pump seal is 90029-21007, so you might wanna get an original one while its still accessable. thermostat housing can be fitted with normal black sealant throttle body gasket is 22271-11030
  10. EP82 wing will have a tiny hole in the center of the wheel arch to clip on the wheel arch plastic and possibly an EP80 wing will have a hole for a side indicator light
  11. It would probably be better to find a good used original Toyota part from a scrapper. If you dont mind the postage from my country, I could sell you one.
  12. Check if there is any alternative partnumbers on the seal you couldn't order, thats how I found mine
  13. What the name of this block to collect wires?
  14. thats pretty cool, havent seen that before
