T-dog
Club Member
    657
1 Follower
About T-dog
  • Birthday 07/08/1993
  • AIM
    honda-repsol@hotmail.co.uk
    Isle Of Wight
14803 profile views
T-dog's Achievements
Boosting a Starlet
Boosting a Starlet (5/8)
  1. Both sold . Thanks
  2. Bump . Offers
  3. Bump , offers
  4. Bump
  5. Two an8 rocker covers for sale , one red and one white . A fresh painted AN8 Cam Covers in bright red and white they have been vapour degreased in Perchlorethylene to remove dirt and carbon build up and etch primed then painted using high quality durable paint. Β£100 for the red one and Β£80 for the white one ( the white one has a few marks in the paint but still looks good) Β£10 postage.Thanks Toby
  6. T-dog
    4pot brakes
    Yeah I fitted one of the first kits , was a great upgrade and straight fit. Anymore info pm me πŸ‘πŸΌ
  7. The wires you are after are - BLACK/RED = POWER BROWN/WHITE = GROUND YELLOW/RED = TPS SIGNAL
  8. Yeah that looks like the alternator plug and power cable . It’s will be around there have you anymore plugs ? It could well have been cut off ?
  9. Good find . Always good to keep the light working without taking the bulb out etc πŸ‘πŸΌ
  10. Most people these days just blank them off with a made bit of a metal and original gasket and then just loop the coolant hoses . Then just adjust the idle through the screw on top of the throttle body . I have done it on few of these cars now with no change to cold starting . If you don’t wanna do this have you taken it off and given it a good clean etc ? . Hope this helps πŸ‘πŸΌ
  11. I use red stuff or ds2500 both amazing for fast road and light track use πŸ‘πŸΌ
  12. I have fitted na starter motors before on a couple of glanza no problem . Slightly smaller in ah but still work fine . Also fitted a auto one year back just had to nut and bolt one of the holes . Lots of options if needed mate πŸ‘πŸΌ
  13. Try unplugging the emanage and see if will start up on stock ecu . Worth a try just then one more thing to role out πŸ‘πŸΌ
  14. Is it on stock ecu or aftermarket ?
  15. All earths on the loom put back on the engine ? Like idle control valve earth point , bulkhead near igniter , both earths on the gearbox and mount , other side on the mount to body , both front wing earths. It’s just a case of back tracking mate if it was running before It must be something simple . What did you take apart to sort the coolant leak ? πŸ‘πŸΌ
