Trevstar
Club Member
    258
1 Follower
About Trevstar
  • Birthday 05/29/1995
    West Sussex
  • Build Thread
    106402
32409 profile views
Trevstar's Achievements
Member (4/8)
  1. No worries mate!
  2. Wow. Just wow. 😳 Bloody well done mate! As Ozzy Osbourne once said, if your gonna go, go strong, go proud, go hard, go loud or go homeπŸ‘πŸ»
  3. Thanks @Pikey009, and thanks again @akyakapotter for helping me get back into my account, highly appreciated! Now the show may continue 😎
  4. I know this is an old thread but for future reference if you're lucky enough to have obtained some OEM deflectors with the clips; the window rubber needs to be pulled down from the top of the door frame, then push the clips up onto the edge of the door frame positioning them where the need to be in relation to the square cut outs on the inside of the deflector. Then mark out the edges of the deflector on the door frame with some making tape for positioning the deflector and then remove the clips. Then reposition the deflector on the door frame using the tape used to mark the position, and stick down the deflector with quality waterproof/weatherproof double sided foam tape and then push the clips back up onto the door frame so that the clip is clamping the deflector between the clip and the door frame, making sure that middle prong of the clip goes into the square holes on the inside of the deflector as shown below, and then push the window rubber back up into the door frame The clips fit into the deflector like this:
  5. Nice addition πŸ‘ŒπŸ»
  6. πŸ‘ŒπŸ» Lot of attention to detail as always!
  7. Woah! 😍 It's cleaned up really well! Looks amazing, well done πŸ‘πŸ»
  8. Good stuff Mark! I saw your manifold on Facebook, very keen to seeing how much this all makes with everything you've done
  9. Cheers buddy! βœŒπŸ»οΈπŸ™‚ Haha tell me about it! I easily spent over Β£100 on the model & materials to create it, but it was completely worth it I look forward to building them in the near future
  10. @Sam44 @Dale SR thank you lads, very much appreciated πŸ™πŸ»
  11. Ahh, yeah that's what I thought might be the case. We have a Autel maxisys so maybe it can but I can't be sure, if I see one cheap enough I'll give it a try ✌🏻️
  12. Very clean, nice work! quite liking the window tints, make it look like front and rear windows are all one piece. I've always wondered if those 22 pin toyota adapters would actually work, so perhaps I'll get one and give it a try one day
  13. Nice! Looking smart
  14. Cheers mate! Considering either a ME442 so that it fits in the original casing, if not that, then a Link G4X monsoon sounds like it would fit the bill Ohh that paint I used on the rails only gave false expectations, won't be using that again Tweed jacket!? 🀣 noo way you'll be seeing me in one of those, not for a very long time at least! I'm too young and 'one of those city boys' πŸ‘¨πŸ»β€πŸŒΎπŸ˜‚ I'm looking forward for you to come see it as well, naturally you're more than welcome to come up! Plus I'll probably need you and burty's help at some stage 😎 And thank you mate, that means a lot! πŸ™πŸ» And you're probably right, these models are the closest either of us are gonna get to owning the real thing now πŸ˜…πŸ˜­
  15. Just a little update where we're at: - I'm still waiting on the cylinder head to come back from being cerakote'd. Its been a long while now, but they've explained why, which I fully understand (fortunately I'm not in a rush) - I haven't yet decided whether or not to go with the flat faced valves due to the cost, but if I did it might also be better to go further and get Colsibro valve guides to suit, then I would need to get them fitted & valve seats cut (which would need doing either way), but as I say this would be further added cost - I also think I have come to the decision not to go ahead with the emanage ultimate, and instead go down a standalone route as this will give me better control to suit my requirements. Mainly a standalone unit will provide more accurate adjustments, slightly better features, and it enable me to use knock control, whereas the EMU only monitors knock, not manage it, which is important when running a high compression like I plan to - Both the of the front Recaro seats have had all the bolsters replaced with brand new genuine Recaro foam, and I padded out the support bars on the frames to add a little bit more rigidity. I also had some material replaced where it was wearing thin Here's what the old bolsters looked like: And here's what they were replaced with: Whilst the seats were apart I noticed one of the upper seat frames had some cracks in it, so I took one to be welded which he struggled with because they were made of 'crap' metal (bit disappointing for a Recaro seat if I'm honest). Having already left with one repaired, I then noticed the other one was actually worse, and rather than go back and pay him again, I thought I would try TIG weld it myself with a recent mma & tig welder I had acquired from someone I did some work for. I'm not gonna lie, the welds are pretty shit. Excuses being: frames made of thin pot metal, cheap welder, shit tungsten, welding outside, and lack of experience. That said, the welds should hold as the didn't break when I tried, plus I did add some reinforcement. With these cracks welded up it immediately made the seats noticeably more ridged than before. Obviously I gave them a spray of self etch primer and some black paint before reassembling - I have also decided that I'm not happy with the paint I used on the seat rails because its become apparent that it easily chips off. So I am having the entire rails blackened (which is what I think they were originally), which is a metal surface treatment rather than a coating and will be more durable and resistant to corrosion. Also the stripped mounting point threads that I re-tapped to M12 make it difficult to get the rails mounted properly, so I am going to weld up the holes and re-tap them again back to the original M10 size Now for the big news, unfortunately this progress thread will be having a bit of another go slow for a while. But this isn't a bad thing! Because I am actually moving house soon to another location which has considerably more space where I have the opportunity to build my own garage/workshop, which will enable me to take on bigger jobs such as engine removal etc. and actually make some real progress, so stay tuned! In other news, if your interested, I finally completed my replica model of my late friend Shahid's car that I made as a tribute to him, and I have to say I'm pretty chuffed with it I've enjoyed making it soo much I bought more
