  1. Just got some bits. Quick replies, well packaged and tracked delivery. Top lad cheers
  2. Put them up to about 20 front and 15-16 rear for track. Its a much smoother surface than on road so you can get away stiffer. I wouldnt worry about camber for one session
  3. This was in my passengers footwell glued to the floor. Wasnt very professionally installed. Not like yours has proper brackets and everything
  4. Looks a bit different from my levin one. Cd changer and other stuff etc Soo many wires!!
  5. Gutted. Should have bought a micra they change without:P But seriously matey boy was right you'd stuff yourself up if you got rear ended. A cars replacable you or your back isnt
  6. Stuck in park? Whats wrong with neutral?
  7. Yeah you tried it with the gearbox on there? Im assuming you'll have to cut the firewall away and rebuild the tunnel abit?
  8. Yeh friction should be. Almost any toyota 212mm friction plate should work. but I dont know if the rwd flywheels are deeper or anything or if you could use the later 212mm f/w from a post 90 4age. I think your main task atm is getting it in and running then worry about thar stuff later lol
  9. Yes afaik. 8 bolt cranks on all. There is 2 different clutch sizes though. Earlier are 200mm which I think 86's use and from smallport onwards had 212mm clutches. Not sure if the f/wheels are interchangable between fwd and rwd platforms though.
  10. Blocks are interchangable between heads. They do about 4 different blocks and 4 different heads iirc 3 rib. Very early bigport tvis engines 40mm main journals. (Everything after these were 42mm) 7 rib later bigport tvis engines. (87ish to 90) 7 rib small port non tvis (has oil squirters under pistons) 90-92ish 7 rib 20v. Sump has different bolt pattern to 16v all 20v have oil squirters. Then you get the 4agze but they use the same block as the year they were produced but have different internals.
  11. Lol if you look on the inlet side of the block theres reinforcing ribs running vertically. Early 4a's onky had 3 later had 7. They are stronger and can handle more boost.
  12. Want a 7 rib block? ;)
  13. Right this is for the drivers seat. Obvs passengers would be opposite and excuse the mess its been an open shed 3 or 4 years. Rear left. Drill out spot weld spin bracket 90degress Bend bracket so hole is vertical then reinforce once happy with position. Rear right was untouched. Just with the bolt hole stretched Front right is the same. Front left needs to be rotated inwards slightly. I think theres some locating pegs that need removing but thats about it.
  14. Id need to rebuild my 16v first haha
  15. Id say so. On the button mine had like a 3mm bar half way around it. That pushed agaisnt the boss/edge of the wheel and acted as the earth. Put the wire on one spade and touch the frame of the button on something metal. If it sounds try it on the other one, hopefully that shouldnt sound unless you press the button.
  16. Drill out the spot welds on the feet. Rotate and bend the rear left (driver seat) twist the front too slightly and enlarge the holes. Camt remember the rear rhs. Wasnt too bad but we did weld them back in place and reinforce the feet as we cut grooves in them to help bend them. They sit quite far forward so if you're lanky youd be better off with different seats (im 5'9ish and was just right) Also when you slide them forward they catch the carpet on the exhaust tunnel. I've still got one seat here i can get pictures of the feet if you want as they are mega comfy seats.
  17. On mine it earthed itself out with the little metal bracket around the horn. One spade connector is connected to earth (same as that metal bracket thing) so if its connected to that it will sound as soon as it comes in contact with the wheel. The other went through the button so that you had to press the button for it to sound. But you dont need to connect the other to anything.
  18. Uurrrrrmmeeehhhhhhguuuurrrrdddddd Actually hate you so much right now! Was seriously contemplating this the other day! Lol
  19. I cant wait, will be a nice boost from whats probably 80hp at best now to 155-160 and a nice short ratio 6 speed box to keep it revving away when having some fun in it But Im keeping it completely stock other than a stainless cat back that I got for 100 notes and a hks panel filter that was in my trueno. So to the untrained eye it should look like a factory engine
  20. Look for a Yaris sr backbox. Same tip and can be modded to fit our cars
  21. Needed to be done haha. Big downside about the FL is the zz engines, Im using about 1L of oil every 800-1000 miles. Toyota did issue an extented dipstick but mine doesn't have it. But I dont need to worry about that much longer lol
  22. Thought id start this just because its taking most my attention at the moment. Had the car 5 years now put 41k of hard miles on it and for the best part its just lapped up all the abuse I've thrown at it. Other than blowing a nearly new rear shock on a pot hole its been the perfect beater. However as of late the gearbox has started to sound like its developed straight cut gears so rather than throwing in the towel and scrapping the car or spending £350 on another box I've decided I may as well make use of the spare 4age 20v and 6 speed LSD box I have floating around So this is the build up to it. 2000 corolla vida 112k 1.4 5 speed Sr front lip Sr mirrors Sr fog lights Sr full interior incl electric windows 6 speed gearknob Speedlines When I first got it. Pre Sr stuff, dumped on corolla gti lowering springs. After it got its full Sr overhaul (minus mirrors) cost of Sr stuff... £80 bargain. One with its big brother. And yes that is what became the donor car as I stacked it Anyway I've almost finished collecting any bits i need that I had sold from the trueno. Just waiting on a flywheel and alternator then ill order a clutch kit. 6 speed is getting inspected today so I can order some new parts for that to make it run smooth. Once thats back together its full speed ahead 20v zze11 (or to be ae111) hopefully in time for JAE so I can have both 20v motors there! Updates will follow as progress is made.
  23. Who said it was a 1.3 ;)
  24. Nope
  25. Welcome and use photobucket or similar site and paste the IMG code in your thread. And T and T? Trinidad and Tobago? Or somewhere else?
