8788 -
Did you quote you vin number. My local toyota pulled up all my trueno's details from that
I do 2 types of stickers. Printed or cut vinyl Printed are supposed to last 5 years the cut type I dont know about but id expect a bit longer. You have the cut vinyl type currently.
NOS TESTING VIDS TRD Group A 2E-E
morgey replied to Clinternational's topic in EP70 & EP71 Progress Blogs
Thats a pretty big difference. You going to test it till it breaks? -
bit confused about this ebay item
morgey replied to mikey4410's topic in eBay, BidJDM, Yahoo Auction Finds
Yeah that's just a oem corolla strut brace. Got one on my zze111 from an SR and Got a spare in the shed from my trueno also have an old ae92 one in the scrap pile too as the bolt holes are a few mm out of place to later models. -
Congrats dude, thats some going.
This seems the general census on things Outside the time (sunrise to sunset) the exemptions apply so: OFFENCE Max fine £1,000 - no points. Options of Plod verbal warning and VDRS, or Fixed penalty,or Summons to Court If a bulb blows duing the day you can get away with a warning. If its blown at night its instantly one of the above options. Chances are she hasn't met her quota of fines handed out this month so is getting a bit harsh on people. Guess you just got unlucky. Not sure why she changed the fine though? Maybe because you knew about it? If you got a ref number you can call up and chase down what shes put down the fine as on record and what thats booked down as might have the reason for the change?
Should have tried to wiggle it as you were oblivious to the problem. They might have told you to get it sorted and let you go. But whats the deal with hid's? Arent they meant to be fitted to cars with headlight washers only? Maybe they just didnt mention it and added it to your fine.
Welcome. Get it a good clean and a clay to get that paint gleaming again
BE CAUTIOUS WHEN USING ONE OF THESE
morgey replied to mikey4410's topic in 4E-FTE Engine Discussions
I done exactly the same thing haha Still havent fitted a replacement years later lol -
Well if socks or who ever see's it they can either move it to the how to section or put it in the wiki. Only reason I posted it in here is so more people saw it.
I knowwwwwwwww dont remind me! Ps4 and xb1 have 64 player but whilst the games broken im not too fussed. Anyway theres a game on ps3 called M.A.G that was 256 player iirc. That was a bit mental lol
Theyre standard M 8 washers. 8mm id x 16mm od (it measures 15.78mm) Like these http://pages.ebay.com/link/?nav=item.view&id=110911256882&alt=web
I cant take any credit other than sharing it but Thought it would be a much cheaper option when I saw it. Solid shifter bushing are there too. So since im on a sharing spree... And on the subject... For the shifter it's self.. Because I cant be bothered making / selling shifter bushes anymore here is an cheap and easy solution. Shifter mount, solid bushes AE111 What you need. 16 x 3/8 panel washers. (~3/8 ID and 1 OD) I got these at Mitre 10 Mega. First remove the shifter from the car Now remove the factory rubber / metal bushes. Now separate the two parts. (You can discard the rubber bit) Now get a file / dremel / drill bit and increase the ID of the washers to 12mm. I found a file the quickest. What you are trying to do it make the washer fit onto the steel part of the factory bush. Like this Repeat with all 16 washers. Now place 2 washers on each of the metal factory bits. Then the shifter goes on Then 2 more washers go on. Now your all done, so reinstall in the car and enjoy how much better the shifter feels.
Dont confuse me with pc jargen haha, well if they make a game that plays as well as either of the Bf BC games then ill be loving it. 3 was good, really good actually and it worked smoothly even on the ps3, bf4 though you either have a good day or you dont. Think out of the 46 hours of online game time I've had 2 or 3 matches that were genuinely balanced and close. The rest its either frozen or booted me out from matches etc. If hardlines any good ill make the leap to ps4 I think. Not up enough on Pc tech to bother with a gaming setup.
Taken from http://s15.zetaboards.com/AE111_Forum/topic/7331067/1/#new Been meaning to write this up for a while. Bushes for shifter cable linkages AE111. Enhance your shift feel!! Required: 2 x 608-2RS or 608-ZZ bearings (can be found in most skateboard or scooter wheels) 8mm ID x 22mm OD x 7mm wide. Panel washers 8 x ~25mm OD and 4 x ~15mm OD all ~8mm ID. Washer Washer Bearing Remove shifter cables from gearbox Remove / lever out the factory rubber bushes Using a nut, bolt and some washers or a g clamp press a bearing into the linkage end. Should now look like this (they are a perfect press fit) Place 2 big washers on the gearbox linkage arm pin thing Then place a small washer on Then slide the linkage cable with the new bearing on Then another small washer Then 2 big washers Then put the original split pin back in. Repeat the process for the other shifter cable. (Number of washers will vary depending on the width of the individual washers use a bit of common sense) The smaller OD washers are used against the bearing so they only touch the inner race allowing the baring to move freely. And this makes up for the fact the bearing is slightly recessed into the end of the shifter cable.) Now go for a drive, should feel nice and mechanical now. Gearbox should do what its told. No more pretending to go into reverse. I would recommend replacing the bushes for the shifter mount as well. (directions to follow)
Skate board bearings. Cheap as chips 8mmPenny washer 8mm washer Bearing 8mm washer 8mm penny washer Split pin Cost less than £5 Levin forums ftw!
BF 4 is so broken compared to 3. Hugely rushed with too many glitches. Glad to hear hardline has been pushed back so now hopefully they can release a finished game.
That would have been vicki I saw her down riverside. Dont think shes on here though
Stunning
Can you get a picture through the center?
Haha still yet to race a t sport tbf. Top end you'd prob pull
940kgs and 182 na powaaaaaaazzzz
