Content Count
8788 -
Store
Calendar
As above. Must be from a turbo car with standard rear discs. No converted jobbies please. If possible posted next day delivery and to go in the post tomorrow (wednesday) Cash waiting.
Well no real surprise my rear brakes failed miserably 13% with a 40% difference between sides. Had a word and should be able to wing it through if I have another go at them. Going to change bias valves. Oil handbrake cables and Rebleed the whole system. Again! Literally giving up on ep rear discs they are the shittest thing known to man! How can freshly rebuild calipers that work perfectly by hand not work? Brand new discs and pads. Fresh fluid, cables operate freely etc. There's no means for them not to work! Arrrrggggghhhhhhhh drilled to the max!
From what I've seen Triumph t600 throttles remove a locating lug on the Tps to fit the 4efe Tps connector Cut up a 4efe inlet or get a 4efe inlet flange made with an inch of tube on it made. Get silicone joiners to go between the inlet flange and throttles Vacuum manifold with port for brake servo. Faff about with throttle cable Plug in and go. Chris green is the man to speak to as he done it on his but then sold it on
black glanza pistonheads run east anglia
morgey replied to morgey's topic in I Spy, Have You Been Spotted?
I think it's snetty track dude. Yeah I'm heading down on Friday with a mate. I'll be in the black Sr with black wheels -
New discs and pads. Checked cables were operating, adjusted cable to take up the slack and it's still barely working. nothing more I can do other than replace them!
I'm hoping they don't fail mine on handbrake cables. Cba with lying under the car ripping the exhaust off just to do them :/
Bloody things, at least I don't have abs to worry about, I plugged my airbag back in today, first time it's ever been connected was proper paranoid about it blowing up in my face!
Finally got around to booking my car in, been over it checked it out etc but I know it's going to fail just before japfest to cause me a mad rush! And even after refurbing my rear calipers, checking the cables etc my handbrake is still shocking to say the least. Couldn't feel it slow the car at all like they're just not trying to bite :/ might just go back to drums, at least they work on these cars!
I think it's the bank holiday at the end of the month actually if you see this. Hopefully my car passes it's mot tomorrow and I'll be about a lot more in it! -
Itb's and a justy turbo will be plenty I'll prob just have my ipod on shuffle tbf. Or if my mate takes over hard style and hard house lol
Could rebuild both yours for 60 or both for 140 if they needed be new pistons. Not too bad a job tbh and much cheaper than a new caliper.
Mine locks after I turn the ignition on but only if the door is closed. If the doors open it won't try and lock.
Looking and sounding good dude
Lol wtf! That's pretty cool
Anyone know what this is called?
morgey replied to brendonware's topic in Specific Images & Part Numbers
Axle nut retainer. -
You can use almost any image site. If using the full site (not the mobile version) you can insert images by its url I think. I don't know all the lingo but basically if it's already uploaded somewhere online then you can post it with the right link and right coding. All which can be found on the full version of the site
Ahh this will be why I had a Pm from him the other day
My car has an alarm with remote start. It doesn't work atm but I don't trust it plus it doesn't have a neutral switch either! Hence mines never left in gear lol
Use silicone grease on the sliders as normal (petroleum based) grease causes the rubbers to degrade and bind up on slider pins.
How many gauges haha
Haha very true. I got Mot on mine on Tuesday. Might have to have an emergency day off to make sure I make it! Haha
I had to use a bearing puller on my cv joint on my trueno. That thing was solid!
My ae111 trueno was a different 205 black to my starlet as well.
I had this for the exact same reason. I popped to the post office and they just needed an explanation of why it was untaxed and not Sorn'd.
