Content Count
2479 -
Store
Calendar
I used the texa kit for about 4 years. It was a great bit of kit to use. Was great on fiats and stuff like that but for a ford or a jag it was a big nope. Our kit won't do it. Havnt used it for 2 years odd now tho. Does it do KAM test now?
You know the day will come when you get another starlet and can't find another set of these to put on it. You will be kicking your self agin haha If you sell them to me for half price you only have to pay half again to get them back
Have you had the miming belt off at all?
Grant's ep70 4E-FTE daily Turbo-s bits :)
turbo Grant replied to turbo Grant's topic in EP70 & EP71 Progress Blogs
And the test fitting of the disc. Going to order some nice new shiney ones so I know the calliper bracket will sit spot on. Look at that rusty arch! Need to sort that out soon -
They look a bit like the celica twin pots. Some better pics would help tho
I'll just give you half the money for them
You running GT map sensor. And you should always set your timing before driving. You could be retarded!
Can always put them on the green one? They are 8j mother fuckers and light!
Going to do a test for on the rear discs after work tonight. After I re-drill the disc so it's 4x100 fitment. It sure is a beast compared to stick lol -
Squirt wd40 or the like on the fittings before undoing them. Cars are getting on a bit now and the fittings can rust on the steel hard lines. Make sure it's not twisting the hard line round as you undo the union. If it does work it back and forwards. That's the only real problem you might come across
Easy enough. Don't do the fitting up murder tight. You will have to bleed the whole brake system. Use dot 5.1 fluid. Pressurise the brake system after bleeding and check for leaks
I didn't bother asking what my car tested at Japfest. I was just happy it passed lol. I do have 2 centre boxes and a back box tho lol
I'm just going to cut the disc off and true it back up in the lathe. Then you will be left with a nice hub to mount a disc on. I started cutting the disc off but had no oxygen pressure. Will finish it later now I've got some more gas -
The oem valves working. I've had them come in at work with the bias valve blocked up. Makes the car pull well bad lol We the other week my fan melted. So I fitted some new one. -
The rpm wire for the tacho is a spade connector on the side of the diagnostic port with a little rubber cover over it.
Rpm signal comes from the igniter pack. Just reads the pulses off the negative side of the coil. The little connector on the side of the diag plug is the under bonnet rpm pick up. Not sure how the actual gauge works. It has a spinny thing tho
I'm sure I've got a good set of valves I could dig out for you
Tein dampers discs & pads L@@k 5E pistons and rods added
turbo Grant replied to turbo Grant's topic in Starlet Parts For Sale
Hi- 10 replies
- price drop
- coilovers discs pads
(and 1 more)
Tagged with:
I will reveal all when I've got it all fitted and tested. I'm going to use vented discs tho lol -
I'm going to test the brake weight on the rollers before and after the rear brake upgrade. Callipers turned up today.... I had GT brakes on the front. But they didn't cut it for me. So stuck the wilwoods on. Now when you brake hard the back doesn't do a lot. Much better when you pull the hand brake on whilst braking. So going to fit larger discs to increase the effort. Then fit a bias adjuster if I need to dial it in better -
I've started on a rear brake upgrade. The stock GT rear discs and callipers aren't doing it for me. I'm going fit a bias adjuster last if needed. So watch this space -
Few bits to do. You can use the ep70 track rods and ends on the 82 hubs. That's what I'm running. With the fuel system you have a few options. Ditch all the oem stuff and fit a race cell with built in pump. Or fit an electronic lift pump that feeds a swirl tank then that feeds the high pressure injection pump. The 2 simplest ways of doing that. Intercooler and rad fitting is fun! Not much room after engine and turbo kit are in! In the fuse box you have a blanked off efi fuse space. Remove the blank and pop and female spade terminal in the back and you have a fuse efi power source that's wh
Crack on you will love it! Such light cars what bits you got left to get?
Item For Sale: Used tein type hr front dampers Item Condition & Description: Came off my old GT a few years ago. Only removed because of the broken spring locks. No leaks, perfect for fixing your blown set. Price: £30 each Pictures: Payment & Shipping Details: PayPal cash on collection bank xfer paying with pp +4% £15 uk mainland Item For Sale: Ep70 1e front discs and pads Item Condition & Description: Front discs and pads for sale. Brand new. Probable fit some ep80's not sure tho. Been in storage for a few months. Got a bit damp and a bit of surface rust. N
- 10 replies
- price drop
(and 1 more)
Tagged with:
Sounds like the boost controllers not doing it's job right. It should boost the same in all the gears. Not sure how you set up the blitz id boost controller. I've always used greddy ones
