turbo Grant
    2479
  1. I'm a professional door handle perv
  2. Aww bad times. When this happens it makes a nice low entry jack cheap
  3. It's a massive dildo gear stick
  4. So is this just a meet now not a rr thing? Confused
  5. On a auto box without stripping the box down an oil change is all you can do. Usually on the dipstick you have hot and cold messurmemts. To check the level have the car running. Go through the gear with you foot on the brake. Then put it in park and check the level.
  6. Cheap locking wheel nuts you can get off by banging a 12 point socket over it. Or if you have spinny outside one get some one with a welder and weld another wheel bolt onto the locking wheel nut. Done this 100's of times save someone beating your wheel up with a chisel
  7. I need to book this up tomorrow
  8. So still lots of love for this car. Just no time! Just been collecting bits really. Picked up some more Doobie stuff. No I have 1 rear lip/box 2 pairs of genuine side skirts 1 cut front lip and 1 mint mk2/3 front lip
  9. It will do the job till it melts and causes a fire haha
  10. Did you not wire the fogs up on a relay?
  11. Just buy some uprated 16v 4age ones off eBay. Sorted my car right out and they are cheap
  12. Don't panic another page will come
  13. You can use 4efte pistons and a fte head gasket. That would give you near stock fte compression depending on if head and block have been skimmed. Head gasket thickness all depends what you want to do with the car really
  14. I've got it in my head it's 24mm?
  15. Just name aday and I'll be there
  16. The self tune feature should only be used to fine tune a map. Other wise all your cells it's hasn't changed will be miles out
  17. Pic of the simple fix for the clutch hydrolic fault And got some old school greddy gauges in Still need to do the final trim on this plate. Will be handy for mounting a few switches in as well
  18. My 70 was a 2.5 odd hour drive away. I just insured it booked it in for mot and drive the bastard back. Felt well bad to drive. Been off the road for a while
  19. I used some 16v 4age uprated vales stem seals off eBay. £15 odd I think, cheap as chips if you ask me
  20. Japfest vids >http://youtu.be/xa2YRBnc7Y0 >http://youtu.be/XggMYp8LcQA
  21. Hi every one. If any one is interested in a mini meet possibly BBQ depending on the sky. People are welcome to come down the farm get some pics and stuff. Shorty and people come down mine Friday evening. Usually happens every Friday. If your bored and fancy poping down I will post up more details
  22. Even with the stat closed you still get a small circulation of oil round the cooler to prevent the engine being folded with cold oil when the stat opens. You shouldn't have any problems how it is
