Content Count
2479 -
Setting tps on a custom intake and throttlebody.
turbo Grant replied to Duduglanza's topic in Electronics
It will just be the same as a stock one. Use the throttle stop to set it up. Night be a little out as throttle stop will be in a different place but will be close enough -
JUST DID THIS..TOOK ME TWO HOURS LOL
turbo Grant replied to mikey4410's topic in Intake, Turbo & Exhaust
Looks shiney. I'm sure I left a comp housing in cheap coke overnight and it came out pretty clean. -
BE CAUTIOUS WHEN USING ONE OF THESE
turbo Grant replied to mikey4410's topic in 4E-FTE Engine Discussions
I've never like the idea of alloy T adapter hanging out the block. Both my cars run remote T adapters. Would be fine iff the adapter was steel. -
Grant's ep70 4E-FTE daily Turbo-s bits :)
turbo Grant replied to turbo Grant's topic in EP70 & EP71 Progress Blogs
Might get a chance to finish fitting the brakes at the weekend. Got a few jobs on the go so time is tight! The brakes just fit behind the 15's -
As much as your happy to drive with. But my opinion it's got to be over 220. I need to turn the boost up over .95 on the 70. It's getting boring lol
Regrinds are easy to shim up with custom under bucket shims
Tein dampers discs & pads L@@k 5E pistons and rods added
turbo Grant replied to turbo Grant's topic in Starlet Parts For Sale
They got lost after I nabbed the top mounts years ago.- 10 replies
- price drop
- coilovers discs pads
(and 1 more)
Tagged with:
I think the lock ring threads might differ between the two- 10 replies
- price drop
(and 1 more)
Tagged with:
You will need ep82 sensors for the engine. The ep82 ecu is 2 plugs instead of the 3 on the 91. It's really simple to retrofit the engine loom into the cars original loom. That's what I done on my ep70 4efte convertion
grinding sound in reverse and 1st sometimes.
turbo Grant replied to aaddzz123's topic in Drivetrain & Transmission
Probably have a chipped tooth on on a couple of your gears. Also check your engine and box mounts, can cause damage to the gear box when worn -
shorty's new armchair with wheels.
turbo Grant replied to shorty's topic in Other Motors Progress Blogs
You should get your booster seat covered to match the floor mats. Now that would be a look... -
You would be much better off using the loom out of a GT has less wiring
Looks like you gained pony power not horsepower haha that's well random
They are from the vag group off the bam series cars -
If you pop the plastic cover off you will see the rivets. Both the wires connected to the light live 1 permant and 1 connected to the door switch. Take the wire off the door live. Or add a boot switch
Test fitted the rear brake upgrade yesterday. Need to take a grinder to the calipers and possible a small wheel spacers. But it's looking good apart from that -
I found on some it was the actual rivets that holds the contacts inside the light. I scraped round them with a screw driver and every thing was back working again
You can machine the inside of the bell out on the 256mm astra discs so they fit over your hubs. Then the twin pots will bolt straight on
interesting find on fuel cut I never heard of
turbo Grant replied to mikey4410's topic in Electronics
Lol, do how will the ecu do the loads side of fueling with no map sensor -
Anyone run a Fire extinguisher system
turbo Grant replied to thorpy36's topic in Performance & Track Days
Got mine from jjc race and ralley. Cost £200 for a 6 jet system. Cheap insurance just in case -
Hello- 10 replies
- price drop
(and 1 more)
Tagged with:
It shares the same feed as the injectors
So who's owned their ep the longest ?
turbo Grant replied to aleximport25's topic in Lifestyle General
Rocking a starlet since 08 -
The Facebook 24 C**K Sucking Chick
turbo Grant replied to Rock-Kick-Ass's topic in Not Work Safe - The Naughty Corner!
That popped up on my fb wall. The guys at work loved it haha
