turbo Grant
    2479
  1. Well after the weekend of playing with little things I post a pic
  2. All gates belts are rated to 22,000 rpm
  3. If it's bouncing around the 2k mark I would say it's some thing to do with the tps signal. Even tho your not running one
  4. It could just make the repair more costly driving like it. If the crank pulleys loose it will fuck the end of the crank up. Then you need to sort out a new crank and what not.
  5. I would do it sooner rather than later. And I wouldn't even drive it was making noises from that area and you have pulleys running out
  6. It's made a good difference. Front end feels loads better in the corners now. Just need to get some coilovers on before fest It's doesn't do boost by gear or rpm. Just a basic boost controller. It's tiny! I call it cute lol only has 2 wires to solder in
  7. Was so funny. Will have to get the vids up
  8. Awesome. Get them stripped I want some parts
  9. Also fitted a matching cusco rear brace on Wednesday. Feels good now
  10. Got this in the post today Going to be fitting it tonight
  11. You sure it's not the water pump making the noise? That would cause a noise. If the crank pulley is wabling around it could be the rubber breaking up. They don't tend to make a rattle tho. You can check the crank pulley buy putting a line of tipex down the pully and then drive it for a bit. See if the tipex marks line up after. But I would start off by taking the aux belt off and feeling the pulleys by hand
  12. I put 3 silencers in mine so it will pass sound testing easy, I hope...
  13. If you want to run sequential you need an ecu that can run sequential and a cam sensor as well as a crank sensor. Semi sequential just needs a crack sensor.
  14. I keep changing stuff lol so it takes longer but I'm in no rush to get it done and cut corners. If I had lots of money to play with it would be done ages ago. But I'm just pottering along getting bits done In between other jobs. But I must admit I've not touched the car in about 3 months lol
  15. Got a new rad for the new cooling set up going on
  16. It's sat in the corner waiting for more love. Got lots on the go! Engines still needs to come apart for upgrades. Steering rack needs to come out for my manual rack. Need to finish the paint, waiting for nice weather
  17. I will be project leader on this. Keep the little man in 4wd track
  18. It's the black wire for knock sensors. White is for O2 sensor
  19. Thought that was you in the middle for a second Matt aha
  20. I use a plastic shield that sat next to the small rads you find on the 1e engine starlets. I just cut it in half an slid it in between the grill and filter and cable tied it to the slam panel. You can just any thing really. Bit of under tray or cut the corner off an old bumper any thing really
  21. It's not great! I made a plastic shield to go in front of mine for bad weather use
  22. I would start with a new battery first. You can get it tested at a garage to confirm its fucked. I wouldn't go throwing a starter on it just yet.
  23. Wheels are looking shiny
  24. I just make my own but there are several company who will make you one to spec. Google come up with a few
