Content Count
2479 -
Store
Calendar
Welder springs to mind. It will fit then
water pump differences (up to '92 and from '93 onwards)
turbo Grant replied to EPnick22's topic in Engines
If you go to toyoto you will only get a pressed on pully for all years now. You can still get aftermarket bolt on pully pumps -
Rough guess on power before I have her dyno'd
turbo Grant replied to thorpy36's topic in Lifestyle General
160 170 I recon. Need to get my 70 on the dyno before I stuck the emu on. See what the greddy td05 kicks out -
Got a 1e engine and box, coil and bits like that. Nothing exciting really New discs and pads as well
O2 sensor is the one closest to the turbo. Best to have it in there. The bottom one is a cat temp sensor. Try planking the pcv valve off. They can cause a high idle when broken.
Best place/way to mount a FPR? - Now mounted - help again!
turbo Grant replied to Zeldoz's topic in Ignition & Fueling
You just want to nip it up with a spanner. Don't go mad with it tho -
They are the same engine. Stronger in some cases. Just use the sensors off your original engine
I've also ran t1rs and parada spec 2 found them both to be sketch in the wet
I'm on falken 912 finding them a great tyre in the wet and the dry
Just cut the stock springs. Job done
need some help with wireing want to fit my engine into a jimny 4x4
turbo Grant replied to boosting24/7's topic in Electronics
You need to wire it up via a couple of relays and fueses. Bits not hard at all. On the ignition switch IG2 is 12v with the ignition on, and ST1 is 12v on cranking This is what I used. Cut all the wiring out of a GT loom -
Wirings easy, fuel cut relay is boles to the dash around the Clive bod area and the efi relay is in the fues box Google 4efte wiring looms. Quite a few of them floating about -
You would need to cut the end of the inlet off and weld a flange on it. I put a 55mm tb on my old GT and had to grind the inlet opening bigger if you get what I mean.
2k?
You should see 4 black rectangle pads on each corner on the sills. They are the jacking points. Some times the pads fall off so you might not have all 4
Think they reverses into something?
That's what you got to do! Friends with benefits is the best way. You just got to tell them at the very start so they know what they are in for. And when you get bored move on haha
Get them out your life and then fuck a fat girl to make you feel better about your self haha
Think it's about 600 a shaft for the manuals. If it's clicking your getting on a lock it outer. Iner ones usually cause a vibration driving straight. You can always send the shafts off for recon if you want inners and outers doing
You could try toyota. Be over 1k for 2 I recon lol
MG ZS TD04 project, new wheels :)
turbo Grant replied to ste91's topic in Other Motors Progress Blogs
That's the one -
The do go well when tuned a bit. I fitted a bigger turbo and injectors to my mates mg zr deisel. Think it's around the 190bhp mark now. Smokes like a trooper haha -
white glanza v in Southampton
turbo Grant replied to EP91crazy's topic in I Spy, Have You Been Spotted?
Guy I knows got a while v a couple of mouths ago. Could be him. Not sure of his reg tho -
Grant's ep70 4E-FTE daily Turbo-s bits :)
turbo Grant replied to turbo Grant's topic in EP70 & EP71 Progress Blogs
Your car must have 100s of hour work time, it's an absolute credit to you. I see what you done with the fuel pumps. I did have this as a thought as well. I poped the cover off and looked inside. I wanted to keep my fuel gauge sender and decided I couldn't fit an baffled intank pump and keep the sender. So opted for the good old swirl pot set up But also adding to this I had to get this done fast. The car was off the road for 8 days. I did also think of making an L shaped intank baffle setup. The but would mean cutting the hole out bigger in the tank to keep the gauge -
I was thinking about sumping the fuel tank and just running the one in-line pump. But decided I wanted to keep a good ground clearence. And it saved me from welding my mint tank lol
