turbo Grant
    2479
  1. If love some sm wheels for my crm. When I've got a spare 700 Ill get a set
  2. Will get some better pics over the weekend. But for now And I call this the car bomb 2 fuel pumps fitted under the car
  3. Ep82's don't have the restrictor
  4. I'm going to look at fitting a tactical duck from the lower grill. So it directs the air to the cooler. That's what I've been thinking. But I might change to a air > water cooler at some point. On another not. Got it fired up last night. Need to finish the exhaust off tonight set the timing and take it out for a spin
  5. Good effort dude. Much better than shortys attempt lol I should have my 70 convertion done tomorrow. 7 days after starting it...
  6. You can't use a 10mm stud in an m12 hole.
  7. Helicoils are really easy to fit. Can get a bit for about £12 on eBay. Think the thread is m10x1.25 off the top of my head
  8. Put a helicoil in. Probs be stronger than factory
  9. If they keep a record going back a few years so you can see if the cars been off the road for any period would be good. You can always check tax online by punching the reg in, so only lazy people will moan about not being able to see the tax disc when viewing a car. It might affect some old people who don't do computers. It's not all bad really, change is good
  10. The hot hope is a bit close for my liking as well. But there is not a lot of room so meh, it will do. Going to make a copper heat shield for it and lag the pipe a bit. Got a cusco front brace for it as well. Just need to take the drill to it before fitting haha Plan is to have it back on the road over the weekend. Will be a 7 day engine conversion then
  11. Cut the front springs and block the rear axel haha
  12. Done a few bits to the car over the weekend. Loaded the car up with some tools after work Saturday afternoon. Then got home and took the engine out. Shorty and deebo gave me a hand slipping the new engine in Then Sunday morning I went for a ride on the bike Then I done some wringing, making intercooler. Start on exhaust. LSD box Took a bit of time sorting out intercooler piping so it all fitted in nice More to come
  13. It did require the lip round the servo to be rolled. I drilled the bolt holes out a bit to give it some more room. And a hammer on the chassis leg and a ridge on the bulk head. Master bolts on fine to original pipes. Real easy upgrade
  14. turbo Grant
    TPS
    Search around for megasquit on 4efte. You will have to go to the dark side. Shows how to wire the auto one up to manual ecu
  15. Just spotted this. Nice to see that turbo kit put to good use. Love the colour it has gone
  16. Incorrect institution is usually why they snap. People not libeling up the right parts and cleaning the bolt holes out
  17. If your low in coolant as well then I'd say it's defiantly heater matrix
  18. I've got RC injectors in mine
  19. The pully the vacum pipe off the servo and stick a cable tie down the bottom see if it's wet when you pull it out. Seen quite a few leaking masters on them.
  20. Measured the throw on the short shifter last night. Works out to be about 110mm 3rd to 4th movement from the top of the knob
  21. Added in about 15mm but just done it by eye. It's made it a considerably shorter throw now. Can get some rough measurements tonight from stock to how it is now if you like
  22. Presume the alternator one will go back to the big alt fues in the fues box. Can double chech later at home
  23. Pop the rubber boot off see if it's all wet behind it. And stick your head under the dash see if it's leaking inside the car
