  • Replies 1.5k
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
its gett there mate, when you cracking the engine open and starting the build? by the way those glanza dials wont be compatible with those looms i sent you. U should just sell them 2 me haha
Erm there may not be space for him mate best bet would be pop down to the stand and talk to Rob because hes organising it i wont be there then because im going up later.
  • 2 weeks later...
yess, it shall be there :D
started work on the engine tonightaa!
got all the ancilliaries off, and the bloody bottom inspection cover for the cams caught me out a cropper lmao, i was blind to the fact that is loops below the pulley, good job i didnt give it a good pull, otherwise i would have broken something
ive got 1 picture of it on the stand with a stupidly large torque wrench
was to busy faffing to take any more :D
also i lost my boost virginity to a rather sext gt :lol:
yoo dudes and dudettes, finally got the sump off, to my dissapointment!
we tried giving the crank a turn before the sump was off, but it would do almost a full turn and get jammed, so we tried opposite direction, same thing whipped the sump off to fnid this horror!
i rested the loose peice on the end of the casing, as if you'll miss it
rod wasnt even around the crank
rod number 1 (left hand side) is 'slightly' out of position compared to 2,3,4 lmao
and just a few other pics of the same damaged, suprisingly, the crank itself doesnt look all that bad. forgot to take a pic of that, i was was expecting it to be right mangled
i was glad to find out what the problem was, but ill be replacing the rods and pistons, and getting alot of work done to this engine, so hopefully, i can save it :thumbsup:
yeees!
there was alot of sealant around the sump, so im thinking a bit has come off, and jammed 1 of the oil pipes, causing the lack of oil so its heated up, and gone boom, it still smells of burnt metal
