  • Replies 992
  • Created
  • Last Reply
Top Posters In This Topic
Check your timing with a timing gun ollie. The vac line to the tb we set up is fine so wg should work fine aslong as that bolt is in to stop it leaking vac pressure. The timing being out will ruin any hope of boost if its out enough, and if the cams arnt timed properly you could be loosing boost there too!
also wont help if u stick 25mm on the front and 15mm on the back always been told to space front and back the same or your throwing stuff out
I have this exact stance and it has given me no troubles at all
I would also take the cam cover off and check the belt timing too. Done mine a tooth out once and drove it down the yard flat as a fart till boost came in. Drove it strait back in the work shop.
  • 2 weeks later...
this looks good fella, it a real shame about it not boosting,
like been sed check the timing and that the cams are in time, also check the wastegate is not suck open, sound stupid but you never know,
right though i should update this but have ni pics tonight
last weekend i finished off polybushing the anti roll bar drop links and bushes and thats made a small improvment to the steering, feels much nicer to drive
but i had forgot i put the spacers on the weekend before and hadnt tightened them so went for a drive and pulled over to find me wheel very loose and to the point nothing wast bolted on anymore lol
i also recieved a TRD quick shifter and TRD gear knob but havnt fitted it yet
and i have also got a OEM LSD gearbox coming
onto the boost issue
i got the car to boost fine today after fucking around for a while and it now dumps and chatters as its shouldbut is back to smoking like a whore
the oild seals have now gone on the turboso they shouldbe getting relpaced next weekend and the car will then be sorted
but if anyone is intrested the car is up for sale at £4,500 as it stands but the turbo will be fixed. if your intrested let me now can do it for 4k with no back seats and standard front seats
pics will be added tomorrow if i can be arsed
right here are some pictures then that i need to add
some of the polybushing taken place
the drop links i bought from tm developments are advertised as polybushed but the exact same ones are for sale on camskills and not polybushed so i changed on the droplink bushes to polybushes and they were much harded rubber then the ones supplied so not to impressed by that
also the TRD short shifter
fitted the gearknob but no the short shifter yet
and then i bought some new reservoir covers but wanted some blues ones so now have some genuine spoon reservoir covers on a toyota :thumbsup:
have a new 98spec bumper coming next week and a secret surprise that will probably make me keep this car
also got an OEM LSD box being fitted next month with a new clutch :(
