Levin twinpots
Celica st202 carriers
astra 1.7tdci 277mm discs
Spigot ring to center/locate disc.
Longer brake lines
Celica pads.
Instant 277mm disc upgrade no machining needed.
why longer brake lines morgey?....i run this exact set up, but then again i have braided lines,,,i never checked to see if they were longer than stock when i changed over years ago
  • Replies 84
  • Created
  • Last Reply
Top Posters In This Topic
Due to them being further away. They might not be required but i did this setup on my corolla which went from 256>276mm and needed longer lines. I did however end up using some longer ones i had leftover from my starlet.
I have fatty EP91 also, can test some day. Point was that Levin disks are same offset, only little bit bigger and thiker than MR2 disks, so this don't help anything to 5mm spacer under disk thing.
Here carriers and calibers from left ZZW30 MR2, AE82 Gti Corolla and AE111 Levin Corolla.
Can test EE100 Corolla carriers some day, I have that spare car also. SW20 MR2 tested also, won't fit anyway
Are the AE111 and the st202 caliper the same but different carrier?
I have twin pots but don't know what car they are from or what carriers I have.
Discs are 260mm
Tested my old n/a SW20 carriers years ago, won't fit anyway to P7 hub. And what I remember calibers are different too, pads are same. Can take pictures tomorrow...
Discs are 260mm
Edited by gorganl2000
Here are red n/a SW20 MR2 -1990 Rev1 vs Levin AE111 carriers and calibers. Brakepads are same, but other parts can't mix between. And MR2 arriers won't fit to any Starlet or Paseo hub. Calibers maybe to ST202 carriers, but not on Levin carriers what I looked fast. I don't have turbo SW20 calibers and carriers, because went straight to four piston Brembo calibers and custommade carriers. Pads are same anyway...
Was talking to a mate of mine who is clued up about Corolla's and MR2's, he was telling me there's a way of using a 275mm disc with Levin twins.
Whether that would be better than the single ST185 I don't know, as the ST165/early ST185 had twins, and late ST185 singles. I would presume the latter is better, but that may also be due to the increase in disc diameter
  • 5 months later...
  • 1 year later...
Read through this thread and no better understanding than before haha.
Have Glanza V ep91, want bigger brakes has to be all bolt on less the need for spigot rings and or grinding.
What calipers and what discs?
Many thanks.
  • 4 months later...
Many thanks.
I concur with this.
As someone who isn't the most technically minded [and wants it as easy as possible!], I just want to buy stuff and fit it.
If there is anyone out there who makes these kits, I'd certainly buy one.
Many thanks.
YUP LEVIN BZR twinpot calipers and cariers and corsa c  gsi 260mm disks ( check disk height as some differ ) is direct bolt on no messing with spacers or longer studs
ive guided a few members on here to that setup direkt fit
That’s good To know as my set up is getting ready for some new discs.
Just out of interest, why wouldn't you just go with the WMS setup route?
I got a used set on my Starlet, didn't pay much more than the Astra disc setup and with no modifications just bolt on.
Now I have heard not great stuff about the WMS setup, and I can't say my car "feels" like it's on four pots. That said, I couldn't bleed the ST202 calipers yet the WMS bled instantly and passed the MOT.
