Rob H's TD05 16G 4EFE SR Inlet and 8 injectors!! 256.7hp@ Wheels
  • Replies 640
Cheers for the comments lad except that Wallace bloke!
Well since I fitted the OS Giken clutch the pedal has been right at the bottom which I thought was normal for that clutch but after 35,000 miles and hours of dyno time it had got to the point I could not get gears at all, So I pulled the box today and this is what I found! this clutch was apparently a factory recon that I very much doubt now!
This is the friction plate notice the gap between the ruler and the drive spline hub, the hub should be higher than the face of the disc! its like a bowel!!
29423723-3BEE-4494-A075-472AD163226D_zps
BD447208-7001-4F3F-93B2-0DC38A69A876_zps
Same for the pressure plate disc! That should be flat!
B2B364C2-3200-4CDB-ACFB-CA3E1EB1171A_zps
16364B78-FFA5-4A95-A9A8-965D365C2D51_zps
So into the lathe it went! I used the tool grinder in the lathe to grind the surface flat.
BCFEA848-BA14-4A6D-979C-752FB0C852B6_zps
94F7F028-5135-4170-BA48-056F0BB5E696_zps
05C09882-C5D1-4810-9D63-DB408F9BDA63_zps
This is a spare plate I had for the clutch on the pressure plate side of the disc you could see it had only been working on the first 10mm of the outside edge of the disc, this is how I know the clutch must have been like this before I fitted it to my car!! but at least this one was flat still! you can see the ruler sits on the drive hub NOT the outside edge of the disc.
883E2AF3-42DF-49DD-8A4C-6AD58C7E12FE_zps
So I put it all back together and its like a new car!! I dont need half as much travel to clear the gears and the bite point is where it should be now! Im going to order some new parts for the clutch now I know what was wrong with it but at least now I know it will get me to japfest!!!!
  On 4/29/2015 at 12:05 PM, Nanglebadger said:
I really must take a spin over some day with Mr Bower to nosey at this beast in the flesh!
nice update sir!
Phil.
best get your ass over then lol
