Rob H@RCH Engineering Posted April 8, 2014 Author Posted April 8, 2014 Time for a bit more of an update!!! I have been working on a new inlet made by Dean @ R-W Developments but its no ordinary inlet!! the full details will be held back for now lol but hear are a few teasers and some of the other work that has gone into it, its taken some working out and making fit has been good fun to say the least but the reason why will become clear later on! I will be running a Honda throttle body on the new inlet but the pulley for it works the wrong way round for my cable so I made a hybrid pulley from the toyota and honda. The toyota pulley and a disc I cut out to use then cut it to shape I forgot to get photos of the honda one but I had to split the pulley from the rest of it as it also works the throttle return spring unlike the toyota one, I then cut the center out of the toyota pulley and welded it all together. Then Drilled lots of holes to thin it down a bit, then some paint! I also made this to go on the inlet for the vac feed for the brake sevo Hear are some teaser picks of the inlet!! Quote
Rob H@RCH Engineering Posted April 8, 2014 Author Posted April 8, 2014 O and please be nice about the welding on the pulley!! I run out of gas for the welder!! Quote
Socks Posted April 8, 2014 Posted April 8, 2014 Awesome Handywork as usual Mr Rob! Your car needs a civic rad big time tho.. Will lower your oil temps Quote
Rob H@RCH Engineering Posted April 8, 2014 Author Posted April 8, 2014 It will be getting a new rad Matt in good time! but im not into the civic rads it will be much bigger than that! and it will be more of Deans work! Quote
Socks Posted April 8, 2014 Posted April 8, 2014 It will be getting a new rad Matt in good time! but im not into the civic rads it will be much bigger than that! and it will be more of Deans work! The access/space and lower water and oil temps make it more then worth it imo Quote
Rob H@RCH Engineering Posted April 8, 2014 Author Posted April 8, 2014 Im not short of space so im going for surface area, much more efficient cooling and maybe a oil cooler if I ever get the urge to take it on the track, but im more likely to be stuck in traffic than on the track lol Quote
Matts Posted April 9, 2014 Posted April 9, 2014 Absolute quality right there rob! Always good to check in on this build and see what's occurring! Quote
Rob H@RCH Engineering Posted April 9, 2014 Author Posted April 9, 2014 Cheers lads for the comments!! I got made this today to hold the fitting into the clutch master cylinder for the pipe to the remote res pot. Bit of leg from a fishing box! made a prototype first to make sure I got the holes where I wanted them! Then the finished job! Heres the pot for the other end! more to come soon!! Quote
morgey Posted April 9, 2014 Posted April 9, 2014 Great work as usual dude.I'm under the assumption there's an o-ring built In the cylinder to stop it leaking? I've never had one apart before lol Quote
Rob H@RCH Engineering Posted April 9, 2014 Author Posted April 9, 2014 Cheers lads! Its a fancy stepped grommet type seal Morgey that just needs a bit of pressure to seal it. Quote
Rob H@RCH Engineering Posted April 10, 2014 Author Posted April 10, 2014 Cheers John! I think I enjoy it too much to do it as a full time job tho as I think it spoils it when your doing something you enjoy that much as a full time job. Quote
Flaminsam Posted April 10, 2014 Posted April 10, 2014 All the gear with loads of ideas! Spot on rob. Sorry didn't get chance to chat at MFN Quote
Rob H@RCH Engineering Posted April 10, 2014 Author Posted April 10, 2014 Cheers Sam! Yer sorry we missed you 2, we should be at the June one next! I'm working for the May one. Quote
Rob H@RCH Engineering Posted April 12, 2014 Author Posted April 12, 2014 Made a thermal TB gasket the other day but I think Im going to remake it in thinner ptfe as the 6mm is a bit OTT lol Quote
Rob H@RCH Engineering Posted April 26, 2014 Author Posted April 26, 2014 Got the boot floor finished over the last 2 days looks much better now! Made some washers to screw onto the panels. Made brackets with rivnuts in for the panels to screw down to. I also moved my battery box to the side it also makes it so there is enough swing in the cables to move it to get the spare wheel out now too! The finished job!! I only got the fabric one of the panels upside down lol!! thats about it for now! Quote
Rob H@RCH Engineering Posted April 27, 2014 Author Posted April 27, 2014 Cheers Matt! got some more bits to sort out before Japfest but nothing major! Quote
ro55ifumi Posted April 27, 2014 Posted April 27, 2014 (edited) Looking good Rob, rear brace cough cough And if you make me one i may take the rear out John Edited April 27, 2014 by ro55ifumi Quote
Rich-k Posted April 27, 2014 Posted April 27, 2014 Such a superb job! Just read the entire thread Quote
morgey Posted April 27, 2014 Posted April 27, 2014 Looks smart that. Hides all the untidy lines of the metal work nicely Quote
Rob H@RCH Engineering Posted April 27, 2014 Author Posted April 27, 2014 Cheers lads! John you know I will make you one no problem!! we will just have to sort a time out to do it!! Morgey it does make it all nice and smooth it also gave me some where to put my amp for the speakers too!! I also may have to put my sub back it as the fronts on there own just dont cut it for me!!! I like to ROCK hard!!! Quote
