Rob H's TD05 16G 4EFE SR Inlet and 8 injectors!! 256.7hp@ Wheels
Time for a bit more of an update!!! I have been working on a new inlet made by Dean @ R-W Developments but its no ordinary inlet!! the full details will be held back for now lol but hear are a few teasers and some of the other work that has gone into it, its taken some working out and making fit has been good fun to say the least but the reason why will become clear later on!
I will be running a Honda throttle body on the new inlet but the pulley for it works the wrong way round for my cable so I made a hybrid pulley from the toyota and honda.
The toyota pulley and a disc I cut out to use
then cut it to shape
I forgot to get photos of the honda one but I had to split the pulley from the rest of it as it also works the throttle return spring unlike the toyota one, I then cut the center out of the toyota pulley and welded it all together.
Then Drilled lots of holes to thin it down a bit, then some paint!
I also made this to go on the inlet for the vac feed for the brake sevo
Hear are some teaser picks of the inlet!!
  • Replies 640
  • Created
  • Last Reply
Top Posters In This Topic
Cheers lads for the comments!!
I got made this today to hold the fitting into the clutch master cylinder for the pipe to the remote res pot.
Bit of leg from a fishing box!
made a prototype first to make sure I got the holes where I wanted them!
Then the finished job!
Heres the pot for the other end!
more to come soon!!
  • 2 weeks later...
Got the boot floor finished over the last 2 days looks much better now!
Made some washers to screw onto the panels.
Made brackets with rivnuts in for the panels to screw down to.
I also moved my battery box to the side it also makes it so there is enough swing in the cables to move it to get the spare wheel out now too!
The finished job!! I only got the fabric one of the panels upside down lol!!
7C80FDBB-A104-44DC-9D80-BB242917FD1F_zps
thats about it for now!
Cheers lads!
John you know I will make you one no problem!! we will just have to sort a time out to do it!!
Morgey it does make it all nice and smooth it also gave me some where to put my amp for the speakers too!!
I also may have to put my sub back it as the fronts on there own just dont cut it for me!!! I like to ROCK hard!!!
